FTCannot run multiple times my ARM/DSP application
Added by François Tremblay about 14 years ago
I don't know if somebody has seen this kind of issue. I have a ARM/DSP application based on the "DSP HelloWorld". I added some message queues and tasks. The ARM/DSP application is messages intensive. After boot, everything is going fine. The first time I run the application, there is no problem. The next time I run the same application, the ARM application is no able to get buffer from a tcIPCOutbound object after short period of time. I need to reboot my board
I read on web that LPM (Local Power manager) may be needed for DSP/BIOS 5.x application if we want to run differents DSP applications. However, theses pages refers to OMAP3530 and I don't seen anything for the OMAP-L138. Also, in LPM source code, there is no support to OMAP-L138.
http://software-dl.ti.com/dsps/dsps_public_sw/sdo_sb/targetcontent/lpm/index.html
http://ossie.wireless.vt.edu/trac/wiki/BeagleBoard_DSPLink#BuildingLPMModules
http://ossie.wireless.vt.edu/trac/wiki/BeagleBoard_DSPLink#RunningandExecutingSampleApplications
On the last link, they talking about cache issue when load differents DSP application. I don't know if I got something related to that.
I tried theses trick but it doesn't help me
  • unload/reload dsplinkk.ko module between each time
  • added a sleep into my arm application before unloading DSP application to allow DSP application to process all its incoming message queues.
Any comments/ideas/experiences/suggestions?
Thanks
-François
Replies (7)
MW RE: Cannot run multiple times my ARM/DSP application - Added by Michael Williamson about 14 years ago
Hello François,
On the DSP side, if you are using the tcIPCInbound class, are you calling the ReturnBuffer() method in your callback handler? You need to do this or else the underlying POOL objects used by the GetBuffer() calls are not returned to the pool and the DSPLINK queue. This is not symmetrical in the ARM side our wrapper class, unfortunately, as the ARM Inbound class will return the buffer following the callback -- a result of 2 authors writing each side of the interface...
I'm not sure this is the case of what you are describing, though. I would think tearing down the entire DSPLINK structure and starting it back up would clear the state of the Pools, unless you are leaving the DSP code running.
We haven't had too much trouble running applications more than once if they are shut down cleanly, and the OMAP-L138 DSPLINK code seems fairly diligent about flush CACHEs at the appropriate times, but I can't claim that there may not be an issue here.
Any chance you have some simple example code you might be willing to post?
FT RE: Cannot run multiple times my ARM/DSP application - Added by François Tremblay about 14 years ago
Mike,
Thanks for your answer.
Yes, I am already using the ReturnBuffer() method in DSP side.
Also, while purging our code to remove our intellectual property before posting the code in this forum, I found an important bug in our code. So, you helped me indirectly by asking me some code!
Anyway, the behavior of our code changed since the bug fix. I am analyzing and comparing the result between the full version and the purged version of our application. Still see some problem(s) but I am not sure from where it comes from.
Regards,
-François
EM RE: Cannot run multiple times my ARM/DSP application - Added by Edwin McKay over 10 years ago
I know this is an old thread, but I am having similar issues. This is the first time I have head about the "ReturnBuffer()" call. I searched the Hello World could and could not find any reference to it. The header file is not really clear about what buffer I am returning in the incoming message handler. I assume I'm supposed to 'return' the buffer that came in?
Is there a similar Return Buffer for the ARM side?
I am simply trying to send a few messages back and forth. I can get the DSP to send the initial message to the ARM, the ARM to send a message to the DSP, the DSP to return an updated message. Then I receive a series of ASSERTS. Which I assume are from the GetBuffer() call. Perhaps the HelloWorld program is configured to really small memory or queue sizes? I'm sending maybe about 400 bytes.
I have something like this:
// Create the object used to send messages to the DSP
lpMessageOutbound = new tcIPCOutbound((char*)"DSPMSGQ0");
// Wait for the DSP to finish initialization (really just waiting for first message, which indicates DSP set up ok)
while(false == gbDone) {
sleep(3); //printf("waiting for DSP\n");
// Reset bool in preparation for next received message from DSP
gbDone = false;
// Get a buffer for a message to the DSP
lpMessageBuffer = (char*)lpMessageOutbound->GetBuffer(sizeof(messageA2D));
allTypes messageA2D;
messageA2D.library.header.command = eWriteToDSP;
messageA2D.library.header.type = eLibrary;
messageA2D.library.FeatureCount = 0;
messageA2D.library.SQCBatchSize = 9;
// Copy the message to the dsplink buffer
memcpy(lpMessageBuffer, &messageA2D, sizeof(messageA2D));
// Send the message to the DSP
printf("Sending a message to the DSP.\n");
lpMessageOutbound->SendMessage(lpMessageBuffer);
Now to send another message, I was calling lpMessageBuffer = (char*)lpMessageOutbound->GetBuffer(sizeof(messageA2D)); again. But this is where the ASSERTs occur.
Assertion failed (((drvObj != NULL) && (IS_OBJECT_VALID (drvObj, SIGN_DRV))) || ((drvObj NULL) && (cmdId CMD_PROC_ATTACH))). File : drv_api.c Line : 501
inbound:GPPMSGQ1: Status = 0x80008002
inbound:GPPMSGQ1: Terminating
MW RE: Cannot run multiple times my ARM/DSP application - Added by Michael Williamson over 10 years ago
Would it be possible for you to post a copy of your example code, including the BIOS configuration files?
If you want you could send it directly via email offline...
I think these are the files you need. Basically, just the HelloWorld files. Let me know if you need anything else.
Various small errors contributed to the problem. things seem to work better now. I can send & Recv 3 messages and I discovered the debugMsg print queue as well.
    (1-7/7)
