DSPLink library sources
Added by Rafał Krawczyk about 12 years ago
I have a question. Is there any way I could access the source code of DSPLink libraries on DSP side ? Are there the files either on the TI sides in Critical Link's/ MDK ? What I am particularly interested in is the HWI interrupts level which are taken by DSPLink, i.e. 4 and 5 in the DSP/BIOS and I would like to see if it is possible to change these. Moreover, sending the message to shared buffer takes approx. 45 microseconds (a bit less in the release version than in the debug version, but the difference is insignificant) and I would like to check if I could make it quicker in my non-generic solution.
Best regards
Rafal Krawczyk
RE: DSPLink library sources - Added by Michael Williamson about 12 years ago
All the dsplink source code should be in the 3rdparty folder of the BSP/MDK.
RE: DSPLink library sources - Added by Rafał Krawczyk about 12 years ago
Thank you very much. That will do
Best regards
