VITo make the connection between DSP / ARM cores on MityDSP-L138
Added by Vasya Ivanov over 9 years ago
Good day!To make the connection between DSP / ARM cores on MityDSP-L138, can we use your MDK with a previously developed project in Studio Composer Studio on PSP and DSP / BIOS written in C (and not with C ++)?
AB RE: To make the connection between DSP / ARM cores on MityDSP-L138 - Added by Alexander Block over 9 years ago
Our MDK provides an example utilizing TI's DSPLINK software to share data between the ARM and DSP cores of the OMAP-L138 processor. Other example DSP example code is also included in the MDK.
This wiki page (https://support.criticallink.com/redmine/projects/arm9-platforms/wiki/DSP_Quick_Start) describes what example is included in the MDK and how to use it under the "Quick Start using ARM/linux to load Application via DSPLINK" section at the bottom of the page.
The MDK can be downloaded from this wiki page (https://support.criticallink.com/redmine/projects/arm9-platforms/wiki/Board_Support_Package) with the latest release still being the Jan-2014 release.
Please let us know if you still have questions after reviewing the above information.
Thank you,
Alex
