VIdata exchange
Added by Vasya Ivanov over 9 years ago
Help me please. How can I configure the data exchange with the Linux 3.2 kernel without using the Internet cable (com-port only)? Thank you.
JC RE: data exchange - Added by Jonathan Cormier over 9 years ago
I've not really tried to send files over the terminal. But it should be possible using xmodem. The L138 filesystem has the rx program which is used to receive xmodem file streams. sx would be used on the other side. I'm not sure exactly how to run these commands though to get them working.
https://www.systutorials.com/docs/linux/man/1-sz/
http://k.japko.eu/serial-transfers.html
Do you have an sd card slot which you could use to transfer files? Or usb?
