Industrial board USB mini-B connector problem
Added by Zoltan Csizmadia about 14 years ago
Sorry I post my problem here, but there is no forum for the industrial board.
We had issues with some USB devices using the mini-B USB connector, and it seems the pin-out is wrong, and the ID (pin4) and GND (pin5) is swapped.
(based on http://en.wikipedia.org/wiki/Universal_Serial_Bus)
Would you mind to check if my findings are correct?
Best regards,
Zoltan
RE: Industrial board USB mini-B connector problem - Added by Thomas Catalino about 14 years ago
Hi Zoltan -
You are correct. Thank you for pointing this out!
This fix will go into the next build of boards. I apologize for any inconvenience.
Tom
