Double boot u-Boot
Added by Oleh Mela almost 7 years ago
I run myfile.out on the MityDSP-L138 (L138-DX-225-RI) module (not MityDSP-L138F). Linux not use (according to DSP Quick Start). myfile.out is compiled in CCS and works fine. At startup (according to Autoload DSP during boot from SPI NOR) there is a double launch of the u-Boot, and then myfile.out is functioning fine. There was no such problem on the MityDSP-L138F module.
Why does this occur? Is it possible to avoid double boot?
OMAP-L138/AM-1808/AM-1810 initialization passed!                      <---------------- Power on (first boot)
Configuring 128MB mDDR
                      Booting TI User Boot Loader
        UBL Flashtype: SPI
Starting SPI Memory Copy...
   DONE
U-Boot 2009.11 (Jan 13 2014 - 11:14:02)
I2C:   ready
DRAM:  128 MB
NAND:  256 MiB
MMC:   davinci: 0
In:    serial
Out:   serial
Err:   serial
ARM    Clock : 300000000 Hz
DDR    Clock : 150000000 Hz
EMIFA  CLock : 100000000 Hz
DSP    Clock : 300000000 Hz
ASYNC3 Clock : 150000000 Hz
Enet  config : 2
MMC 0 Enable : 0
Resetting ethernet phy
Net:   No ETH PHY detected!!!
Loading coff data from address 0xc0700000
... loading 512 bytes to address 0xc62f7c00
... loading 21888 bytes to address 0xc62de200
... loading 294784 bytes to address 0xc628e280
... loading 19540 bytes to address 0xc62e8a68
... loading 1284 bytes to address 0xc62f6b20
... loading 124 bytes to address 0xc62f8360
... loading 1952 bytes to address 0xc62f58e0
... loading 12 bytes to address 0xc62f7af4
... loading 21218 bytes to address 0xc62e3780
... loading 4 bytes to address 0xc628e27c
... loading 512 bytes to address 0xc62f7e00
... loading 24 bytes to address 0xc62f8578
... loading 16 bytes to address 0xc628e26c
... loading 1984 bytes to address 0x11808800
Starting DSP at address 0xc62f5e60
OMAP-L138/AM-1808/AM-1810 initialization passed!                    <--------------Second boot
        UBL Flashtype: SPI
   DONE
I2C:   ready
DRAM:  128 MB
NAND:  256 MiB
MMC:   davinci: 0
In:    serial
Out:   serial
Err:   serial
Enet  config : 2
MMC 0 Enable : 0
Starting DSP at address 0xc62f5e60                        <----------------- Fine working
U-Boot >
Replies (7)
RE: Double boot u-Boot - Added by Jonathan Cormier almost 7 years ago
Oleh,
Could you provide your u-boot environment?  printenv
Does this processor reset happen when the DSP program isn't automatically loaded? Does it happen if you try to load a simple hello world dsp program?
RE: Double boot u-Boot - Added by Oleh Mela almost 7 years ago
U-Boot > printenv
bootargs=mem=96M console=ttyS1,115200n8 root=/dev/mtdblock0 rw rootwait
bootdelay=3
baudrate=115200
bootfile="uImage"
flashubl=tftp 0xc0700000 mityomap/UBL_SPI_MEM.ais; sf probe 0; sf erase 0 0x10000; sf write 0xc0700000 0 0x10000
flashrootfs=tftp 0xc2000000 mityomap/mityomap-base-mityomapl138.jffs2; nand erase 0 0x08000000; nand write.jffs2 0xc2000000 0 ${filesize}
serverip=10.0.0.23
autoload=no
mtdids=nand0=nand
filesize=1732CC
bootcmd=sf probe 0; sf read 0xc0700000 0x100000 0x300000;bootdsp 0xc0700000;
stdin=serial
stdout=serial
stderr=serial
ethaddr=00:50:c2:fc:6c:cf
ver=U-Boot 2009.11 (Jan 13 2014 - 11:14:02)
Environment size: 1070/65532 bytes
No.
No, with simple hello world dsp program working fine.
Jonathan,
with simple hello world dsp program following is:
        UBL Flashtype: SPI
   DONE
        UBL Flashtype: SPI
   DONE
I2C:   ready
DRAM:  128 MB
NAND:  256 MiB
MMC:   davinci: 0
In:    serial
Out:   serial
Err:   serial
Enet  config : 2
MMC 0 Enable : 0
... loading 512 bytes to address 0x11811800
... loading 17152 bytes to address 0x118058a0
... loading 12 bytes to address 0x1180f7f4
... loading 22688 bytes to address 0x11800000
... loading 4004 bytes to address 0x1180dfc0
... loading 76 bytes to address 0x1180f798
... loading 1376 bytes to address 0x11810000
... loading 12 bytes to address 0x118117f4
... loading 4032 bytes to address 0x1180d000
... loading 905 bytes to address 0x11810e78
... loading 4 bytes to address 0x1180ef64
... loading 512 bytes to address 0x11811588
... loading 48 bytes to address 0x118117c4
... loading 48 bytes to address 0x11811ce8
Starting DSP at address 0x11810380
U-Boot >
That is very strange. Could you comment out pieces of your code until it starts working again? To see if you can determine a section of the code that causes this and we can look at it to see if we can determine what is going wrong.
Jonathan,
Could be my problem connected with to the that there is no pull-up on SPI1 on the own carrier board?
Thanks
Oleh Mela wrote:
Jonathan,
Could be my problem connected with to the that there is no pull-up on SPI1 on the own carrier board?Thanks
Looking at our devkit, we don't put any pull-ups on the spi1 pins. https://support.criticallink.com/redmine/attachments/download/15416/80-000268RI-3_SCH_RevC.PDF
Thank Jonathan,
The problem is resolved. The problem was in hardware.
