MityCam B2521 CAL / WCAL commands
Added by Kyle McKinney about 4 years ago
Is it possible to remove/reset (set to zero) the calibration coefficients that are set by running the CAL and WCAL commands? Is there a way to figure out what they are set to?
Kyle
MityCam B2521 CAL / WCAL commands - Added by Michael Williamson about 4 years ago
Hi Kyle,
You can operate the sensor without calibration gain or offset data set
using the SGAN command.
<SGAN 3> is high gain only (no corrections)
<SGAN 4> is low gain only (no corrections)
<SGAN 5> is combined high / low gain (no corrections)
If you want to replace the files with the default files prior to
corrections, you will need to use the USB 2.0 port (which presents and
RNDIS interface as described in section 13 of the user manual) and use a
program such as winscp to replace the calibration data with default data.
Let me know if you need help with that.
On Tue, Mar 16, 2021 at 10:03 AM <redmine@criticallink.com> wrote:
RE: MityCam B2521 CAL / WCAL commands - Added by Kyle McKinney about 4 years ago
I think knowing that they are not applied in the uncorrected modes is sufficient. What about CDS? Are there any differences in how that functions between the modes? Basically I am attempting to get as RAW and uncorrected data as possible.
Kyle
