Specification TPS power sully design inthe AM3359 carrier board
Added by ABDUL SALAM over 14 years ago
HI,
Could you please send me the Specification TPS power sully design inthe AM3359 carrier board.
Regrds
salam
Replies (5)
RE: Specification TPS power sully design inthe AM3359 carrier board - Added by Alexei Shkurko over 14 years ago
Hi Salam,
the SOM module requires 3.3V input voltage with up to 1Amp input current, our Dev Kit board based on TPS5430 IC to generate 3.3V supply, the input cicrcuit can handle up to 20V as we are using MOSFET for reverse polarity protection
Regards,
Alexei
RE: Specification TPS power sully design inthe AM3359 carrier board - Added by ABDUL SALAM over 14 years ago
Hi alexi,
as per your Carrier board design guidline,the Typical input voltage of the SOM module is 5v, so we are planning to give 5v ,0.7A supply to SOM module( coz we are usuing 5V for some other section also)
And for all peripharals we are giving 3.3 v,, so Can use the same power supply circuit from your carrier board
regards
salam
gentile reminder for the above question
RE: Specification TPS power sully design inthe AM3359 carrier board - Added by Michael Williamson over 14 years ago
Hi Salam,
If you are asking if you can use our reference DevKit 3.3V supply design to power other 3.3V devices, then answer is likely "yes" assuming you are providing the same input voltage capabilities to the supply as are supplied on our DevKit mainboard. Perhaps if you sent a sketch of your supply design (we can do this offline via email if you like) it would be easier for us to review?
