BNQuartus v23.1 errors building mitysom 5csx project
Added by Bob Nayar about 2 months ago
I am using Quartus 23.1 running on Windows 11 Pro.
I have WSL installed, set to mirrored mode with Ubuntu 20.x)
I am getting these errors when building my project (after I modified in Platform Designer in Windows):
2026.09.17.12:00:28 Error: s0: Error during execution of "{C:/intelfpga/23.1std/quartus/../nios2eds/Nios II Command Shell.bat} make all 2>> stderr.txt": child process exited abnormally
2026.09.17.12:00:28 Error: s0: Execution of command "{C:/intelfpga/23.1std/quartus/../nios2eds/Nios II Command Shell.bat} make all 2>> stderr.txt" failed
2026.09.17.12:00:28 Error: s0: /mnt/c/intelfpga/23.1std/quartus/bin64/uniphy_mcc.exe -ac_code sequencer_mc/ac_rom.s -inst_code sequencer_mc/inst_rom.s -ac_rom ../dev_5cs_fpga_ddr_s0_AC_ROM.hex -inst_rom ../dev_5cs_fpga_ddr_s0_inst_ROM.hex -header sequencer/sequencer_auto.h -vheader ../sequencer_auto_h.sv -ac_rom_init sequencer/sequencer_auto_ac_init.c -inst_rom_init sequencer/sequencer_auto_inst_init.c -DAC_ROM_USER_ADD_0=0_0000_0000_0000 -DAC_ROM_USER_ADD_1=0_0000_0000_1000 -DAC_ROM_MR0=0001000110001 -DAC_ROM_MR0_CALIB= -DAC_ROM_MR0_DLL_RESET=0001100110000 -DAC_ROM_MR1=0000000000000 -DAC_ROM_MR1_OCD_ENABLE= -DAC_ROM_MR2=0001001001000 -DAC_ROM_MR3=0000000000000 -DAC_ROM_MR0_MIRR=0001001001001 -DAC_ROM_MR0_DLL_RESET_MIRR=0001011001000 -DAC_ROM_MR1_MIRR=0000000000000 -DAC_ROM_MR2_MIRR=0001000110000 -DAC_ROM_MR3_MIRR=0000000000000 -DQUARTER_RATE=0 -DHALF_RATE=1 -DFULL_RATE=0 -DNON_DES_CAL=0 -DAP_MODE=0 -DGUARANTEED_READ_BRINGUP_TEST=0 -DMEM_ADDR_WIDTH=13 -DHARD_PHY=0
2026.09.17.12:00:28 Error: s0: UniPHY Sequencer Microcode Compiler
2026.09.17.12:00:28 Error: s0: Copyright (C) 2024 Intel Corporation. All rights reserved.
2026.09.17.12:00:28 Error: s0: Info: Reading sequencer_mc/ac_rom.s ...
2026.09.17.12:00:28 Error: s0: Info: Reading sequencer_mc/inst_rom.s ...
2026.09.17.12:00:28 Error: s0: Info: Writing ../dev_5cs_fpga_ddr_s0_AC_ROM.hex ...
2026.09.17.12:00:28 Error: s0: Info: Writing ../dev_5cs_fpga_ddr_s0_inst_ROM.hex ...
2026.09.17.12:00:28 Error: s0: Info: Writing sequencer/sequencer_auto_ac_init.c ...
2026.09.17.12:00:28 Error: s0: Info: Writing sequencer/sequencer_auto_inst_init.c ...
2026.09.17.12:00:28 Error: s0: Info: Writing sequencer/sequencer_auto.h ...
2026.09.17.12:00:28 Error: s0: Info: Writing ../sequencer_auto_h.sv ...
2026.09.17.12:00:28 Error: s0: Info: Microcode compilation successful
2026.09.17.12:00:28 Error: s0: /mnt/c/intelfpga/23.1std/quartus/../nios2eds/sdk2/bin/nios2-bsp hal sequencer_bsp .. --default_sections_mapping sequencer_mem --use_bootloader DONT_CHANGE
2026.09.17.12:00:28 Error: s0: nios2-bsp: Using /mnt/c/intelfpga/23.1std/nios2eds/sdk2/bin/bsp-set-defaults.tcl to set system-dependent settings.
2026.09.17.12:00:28 Error: s0: nios2-bsp: Updating existing BSP because sequencer_bsp/settings.bsp exists.
2026.09.17.12:00:28 Error: s0: nios2-bsp: Using SOPC design file /mnt/c/Users/560057615/AppData/Local/Temp/alt0713_9118986005145505356.dir/0017_s0_gen/qsys_pre_compile//pre_compile.sopcinfo found in /mnt/c/Users/560057615/AppData/Local/Temp/alt0713_9118986005145505356.dir/0017_s0_gen/qsys_pre_compile/
2026.09.17.12:00:28 Error: s0: nios2-bsp: Running "nios2-bsp-update-settings.exe --settings sequencer_bsp/settings.bsp --bsp-dir sequencer_bsp --sopc c:/Users/560057615/AppData/Local/Temp/alt0713_9118986005145505356.dir/0017_s0_gen/qsys_pre_compile//pre_compile.sopcinfo --script c:/intelfpga/23.1std/nios2eds/sdk2/bin/bsp-set-defaults.tcl default_sections_mapping sequencer_mem use_bootloader DONT_CHANGE "
2026.09.17.12:00:28 Error: s0: INFO: Updating BSP settings...
2026.09.17.12:00:28 Error: s0: INFO: nios2-bsp-update-settings --settings sequencer_bsp/settings.bsp --bsp-dir sequencer_bsp --sopc c:/Users/560057615/AppData/Local/Temp/alt0713_9118986005145505356.dir/0017_s0_gen/qsys_pre_compile//pre_compile.sopcinfo --script c:/intelfpga/23.1std/nios2eds/sdk2/bin/bsp-set-defaults.tcl default_sections_mapping sequencer_mem use_bootloader DONT_CHANGE
2026.09.17.12:00:28 Error: s0: INFO: Initializing BSP components...
2026.09.17.12:00:28 Error: s0: INFO: Finished initializing BSP components. Total time taken = 3 seconds
2026.09.17.12:00:28 Error: s0: INFO: Searching for BSP components with category: os_software_element
2026.09.17.12:00:28 Error: s0: INFO: Initializing SOPC project local software IP
2026.09.17.12:00:28 Error: s0: INFO: [Info] <b>C:/Users/560057615/AppData/Local/Temp/alt0713_9118986005145505356.dir/0017_s0_gen/qsys_pre_compile/*</b> matched 5 files in 0.00 seconds
2026.09.17.12:00:28 Error: s0: INFO: [Info] <b>C:/Users/560057615/AppData/Local/Temp/alt0713_9118986005145505356.dir/0017_s0_gen/qsys_pre_compile/*/*_sw.tcl</b> matched 0 files in 0.00 seconds
2026.09.17.12:00:28 Error: s0: INFO: [Info] <b>C:/Users/560057615/AppData/Local/Temp/alt0713_9118986005145505356.dir/0017_s0_gen/qsys_pre_compile/ip/**/*_sw.tcl</b> matched 0 files in 0.00 seconds
2026.09.17.12:00:28 Error: s0: INFO: [Info] <b>C:/Users/560057615/AppData/Local/Temp/alt0713_9118986005145505356.dir/0017_s0_gen/ip/**/*_sw.tcl</b> matched 0 files in 0.00 seconds
2026.09.17.12:00:28 Error: s0: INFO: Finished initializing SOPC project local software IP. Total time taken = 2 seconds
2026.09.17.12:00:28 Error: s0: INFO: Searching for BSP components with category: driver_element
2026.09.17.12:00:28 Error: s0: INFO: Searching for BSP components with category: software_package_element
2026.09.17.12:00:28 Error: s0: INFO: Loading drivers from ensemble report.
2026.09.17.12:00:28 Error: s0: INFO: Finished loading drivers from ensemble report.
2026.09.17.12:00:28 Error: s0: INFO: Tcl message: "No STDIO character device"
2026.09.17.12:00:28 Error: s0: INFO: Tcl message: "No system timer device"
2026.09.17.12:00:28 Error: s0: INFO: Tcl message: "Default linker sections mapped to sequencer_mem"
2026.09.17.12:00:28 Error: s0: INFO: Default memory regions will not be persisted in BSP Settings File.
2026.09.17.12:00:28 Error: s0: INFO: Generated file "C:\Users\560057615\AppData\Local\Temp\alt0713_9118986005145505356.dir\0017_s0_gen\qsys_pre_compile\dev_5cs_fpga_ddr_s0_software\sequencer_bsp\settings.bsp"
2026.09.17.12:00:28 Error: s0: INFO: BSP settings updated
2026.09.17.12:00:28 Error: s0: INFO: Generating BSP files...
2026.09.17.12:00:28 Error: s0: INFO: Generating BSP files in "C:\Users\560057615\AppData\Local\Temp\alt0713_9118986005145505356.dir\0017_s0_gen\qsys_pre_compile\dev_5cs_fpga_ddr_s0_software\sequencer_bsp"
2026.09.17.12:00:28 Error: s0: INFO: Generated file "C:\Users\560057615\AppData\Local\Temp\alt0713_9118986005145505356.dir\0017_s0_gen\qsys_pre_compile\dev_5cs_fpga_ddr_s0_software\sequencer_bsp\summary.html"
2026.09.17.12:00:28 Error: s0: INFO: Generated file "C:\Users\560057615\AppData\Local\Temp\alt0713_9118986005145505356.dir\0017_s0_gen\qsys_pre_compile\dev_5cs_fpga_ddr_s0_software\sequencer_bsp\mem_init.mk"
2026.09.17.12:00:28 Error: s0: INFO: Generated file "C:\Users\560057615\AppData\Local\Temp\alt0713_9118986005145505356.dir\0017_s0_gen\qsys_pre_compile\dev_5cs_fpga_ddr_s0_software\sequencer_bsp\public.mk"
2026.09.17.12:00:28 Error: s0: INFO: Generated file "C:\Users\560057615\AppData\Local\Temp\alt0713_9118986005145505356.dir\0017_s0_gen\qsys_pre_compile\dev_5cs_fpga_ddr_s0_software\sequencer_bsp\linker.x"
2026.09.17.12:00:28 Error: s0: INFO: Generated file "C:\Users\560057615\AppData\Local\Temp\alt0713_9118986005145505356.dir\0017_s0_gen\qsys_pre_compile\dev_5cs_fpga_ddr_s0_software\sequencer_bsp\linker.h"
2026.09.17.12:00:28 Error: s0: INFO: Generated file "C:\Users\560057615\AppData\Local\Temp\alt0713_9118986005145505356.dir\0017_s0_gen\qsys_pre_compile\dev_5cs_fpga_ddr_s0_software\sequencer_bsp\memory.gdb"
2026.09.17.12:00:28 Error: s0: INFO: Generated file "C:\Users\560057615\AppData\Local\Temp\alt0713_9118986005145505356.dir\0017_s0_gen\qsys_pre_compile\dev_5cs_fpga_ddr_s0_software\sequencer_bsp\alt_sys_init.c"
2026.09.17.12:00:28 Error: s0: INFO: Generated file "C:\Users\560057615\AppData\Local\Temp\alt0713_9118986005145505356.dir\0017_s0_gen\qsys_pre_compile\dev_5cs_fpga_ddr_s0_software\sequencer_bsp\system.h"
2026.09.17.12:00:28 Error: s0: INFO: Generated file "C:\Users\560057615\AppData\Local\Temp\alt0713_9118986005145505356.dir\0017_s0_gen\qsys_pre_compile\dev_5cs_fpga_ddr_s0_software\sequencer_bsp\Makefile"
2026.09.17.12:00:28 Error: s0: INFO: Finished generating BSP files. Total time taken = 2 seconds
2026.09.17.12:00:28 Error: s0: INFO: BSP files generated in "C:\Users\560057615\AppData\Local\Temp\alt0713_9118986005145505356.dir\0017_s0_gen\qsys_pre_compile\dev_5cs_fpga_ddr_s0_software\sequencer_bsp"
2026.09.17.12:00:28 Error: s0: /mnt/c/intelfpga/23.1std/quartus/../nios2eds/sdk2/bin/nios2-app-generate-makefile.exe --bsp-dir sequencer_bsp --app-dir sequencer --elf-name sequencer.elf --set OBJDUMP_INCLUDE_SOURCE 1 --set APP_CFLAGS_DEFINED_SYMBOLS -DSTACK_POINTER=0x10fff0 --set APP_CFLAGS_OPTIMIZATION \"-Os --param max-inline-insns-single=1000 -fno-partial-inlining -fno-zero-initialized-in-bss\" --set APP_CFLAGS_WARNINGS \"-Winline -Wall\" --src-files sequencer.c sequencer.h tclrpt.c tclrpt.h sequencer_auto_ac_init.c sequencer_auto_inst_init.c
2026.09.17.12:00:28 Error: s0: INFO: nios2-app-generate-makefile --bsp-dir sequencer_bsp --app-dir sequencer --elf-name sequencer.elf --set OBJDUMP_INCLUDE_SOURCE 1 --set APP_CFLAGS_DEFINED_SYMBOLS -DSTACK_POINTER=0x10fff0 --set APP_CFLAGS_OPTIMIZATION -Os --param max-inline-insns-single=1000 -fno-partial-inlining -fno-zero-initialized-in-bss --set APP_CFLAGS_WARNINGS -Winline -Wall --src-files sequencer.c sequencer.h tclrpt.c tclrpt.h sequencer_auto_ac_init.c sequencer_auto_inst_init.c
2026.09.17.12:00:28 Error: s0: INFO: Generating application makefile
2026.09.17.12:00:28 Error: s0: INFO: Generated file "C:\Users\560057615\AppData\Local\Temp\alt0713_9118986005145505356.dir\0017_s0_gen\qsys_pre_compile\dev_5cs_fpga_ddr_s0_software\sequencer\Makefile"
2026.09.17.12:00:28 Error: s0: INFO: Application makefile generated
2026.09.17.12:00:28 Error: s0: make -C sequencer_bsp clean altera_nios2_qsys_hal_driver_ASM_LIB_SRCS=HAL/src/crt0.S hal_C_LIB_SRCS=HAL/src/alt_main.c hal_C_LIB_SRCS+=HAL/src/alt_load.c altera_nios2_qsys_hal_driver_C_LIB_SRCS=HAL/src/altera_nios2_qsys_irq.c altera_nios2_qsys_hal_driver_C_LIB_SRCS+=HAL/src/alt_icache_flush_all.c altera_nios2_qsys_hal_driver_C_LIB_SRCS+=HAL/src/alt_dcache_flush_all.c
2026.09.17.12:00:28 Error: s0: make1: Entering directory '/mnt/c/Users/560057615/AppData/Local/Temp/alt0713_9118986005145505356.dir/0017_s0_gen/qsys_pre_compile/dev_5cs_fpga_ddr_s0_software/sequencer_bsp'
2026.09.17.12:00:28 Error: s0: [BSP clean complete]
2026.09.17.12:00:28 Error: s0: make1: Leaving directory '/mnt/c/Users/560057615/AppData/Local/Temp/alt0713_9118986005145505356.dir/0017_s0_gen/qsys_pre_compile/dev_5cs_fpga_ddr_s0_software/sequencer_bsp'
2026.09.17.12:00:28 Error: s0: make -C sequencer clean all altera_nios2_qsys_hal_driver_ASM_LIB_SRCS=HAL/src/crt0.S hal_C_LIB_SRCS=HAL/src/alt_main.c hal_C_LIB_SRCS+=HAL/src/alt_load.c altera_nios2_qsys_hal_driver_C_LIB_SRCS=HAL/src/altera_nios2_qsys_irq.c altera_nios2_qsys_hal_driver_C_LIB_SRCS+=HAL/src/alt_icache_flush_all.c altera_nios2_qsys_hal_driver_C_LIB_SRCS+=HAL/src/alt_dcache_flush_all.c
2026.09.17.12:00:28 Error: s0: make1: Entering directory '/mnt/c/Users/560057615/AppData/Local/Temp/alt0713_9118986005145505356.dir/0017_s0_gen/qsys_pre_compile/dev_5cs_fpga_ddr_s0_software/sequencer'
2026.09.17.12:00:28 Error: s0: [sequencer clean complete]
2026.09.17.12:00:28 Error: s0: Info: Building /mnt/c/Users/560057615/AppData/Local/Temp/alt0713_9118986005145505356.dir/0017_s0_gen/qsys_pre_compile/dev_5cs_fpga_ddr_s0_software/sequencer_bsp
2026.09.17.12:00:28 Error: s0: make --no-print-directory -C /mnt/c/Users/560057615/AppData/Local/Temp/alt0713_9118986005145505356.dir/0017_s0_gen/qsys_pre_compile/dev_5cs_fpga_ddr_s0_software/sequencer_bsp
2026.09.17.12:00:28 Error: s0: Compiling alt_dcache_flush_all.c...
2026.09.17.12:00:28 Error: s0: nios2-elf-gcc.exe -xc -MP -MMD -c -I./HAL/inc -I. -I./drivers/inc -pipe -D__hal__ -DALT_NO_C_PLUS_PLUS -DALT_NO_CLEAN_EXIT -D'exit(a)=_exit(a)' -DALT_NO_EXIT -DALT_USE_DIRECT_DRIVERS -DALT_NO_INSTRUCTION_EMULATION -DALT_USE_SMALL_DRIVERS -DSMALL_C_LIB -DALT_SINGLE_THREADED -Os -g -Wall -mno-hw-div -mno-hw-div -mno-hw-mul -mno-hw-mulx -mgpopt=global -o obj/HAL/src/alt_dcache_flush_all.o HAL/src/alt_dcache_flush_all.c
2026.09.17.12:00:28 Error: s0: make1: Leaving directory '/mnt/c/Users/560057615/AppData/Local/Temp/alt0713_9118986005145505356.dir/0017_s0_gen/qsys_pre_compile/dev_5cs_fpga_ddr_s0_software/sequencer'
2026.09.17.12:00:28 Error: s0: child process exited abnormally
ERROR: Cannot find sequencer/sequencer.elf
2026.09.17.12:00:30 Error: s0: Cannot find sequencer/sequencer.elf
2026.09.17.12:00:30 Error: s0: An error occurred
while executing
"error "An error occurred""
(procedure "_error" line 8)
invoked from within
"_error "Cannot find $seq_file""
("if" then script line 2)
invoked from within
"if {[file exists $seq_file] == 0} {
(procedure "alt_mem_if::util::seq_mem_size::get_max_memory_usage" line 14)
invoked from within
"alt_mem_if::util::seq_mem_size::get_max_memory_usage [file join "sequencer" "sequencer.elf""
invoked from within
"set calc_mem_size [alt_mem_if::util::seq_mem_size::get_max_memory_usage [file join "sequencer" "sequencer.elf"]]"
invoked from within
"if { !$do_only_rw_mgr_mc && !($bfm_mode || $hps_mode)} {
set calc_mem_size [alt_mem_if::util::seq_mem_size::get_max_memory_usage [file join "sequenc..."
(procedure "generate_qsys_sequencer_sw" line 943)
invoked from within
"generate_qsys_sequencer_sw $prepend_str $protocol $pre_compile_dir $fileset $inhdl_dir $rdimm $lrdimm 0 0 $nios_hex_file_name $ac_rom_init_file_name ..."
invoked from within
"set seq_mem_size_list [generate_qsys_sequencer_sw $prepend_str $protocol $pre_compile_dir $fileset $inhdl_dir $rdimm $lrdimm 0 0 $nios_hex_file_name ..."
("if" else script line 2)
invoked from within
"if {[::alt_mem_if::util::qini::qini_value alt_mem_if_seq_size_request 0] > 0} {
set seq_mem_size [::alt_mem_if::util::qini::qini_value alt_mem_if_se..."
(procedure "alt_mem_if::gen::uniphy_gen::generate_qsys_sequencer" line 238)
invoked from within
"alt_mem_if::gen::uniphy_gen::generate_qsys_sequencer "${name}" $protocol $tmpdir $fileset {}"
invoked from within
"set qsys_sequencer_files_list [alt_mem_if::gen::uniphy_gen::generate_qsys_sequencer "${name}" $protocol $tmpdir $fileset {}]"
(procedure "alt_mem_if::gen::uniphy_gen::generate_sequencer_files" line 3)
invoked from within
"alt_mem_if::gen::uniphy_gen::generate_sequencer_files $name "DDR3" $tmpdir QUARTUS_SYNTH"
invoked from within
"foreach generated_file [alt_mem_if::gen::uniphy_gen::generate_sequencer_files $name "DDR3" $tmpdir QUARTUS_SYNTH] {
set file_name [file tail $genera..."
(procedure "generate_synth" line 8)
invoked from within
"generate_synth dev_5cs_fpga_ddr_s0"
2026.09.17.12:00:31 Info: s0: "<b>fpga_ddr</b>" instantiated <b>altera_mem_if_ddr3_qseq</b> "<b>s0</b>"
2026.09.17.12:00:31 Error: Generation stopped, 361 or more modules remaining
2026.09.17.12:00:31 Info: dev_5cs: Done "<b>dev_5cs</b>" with 93 modules, 98 files
2026.09.17.12:00:32 Error: qsys-generate failed with exit code 1: 78 Errors, 12 Warnings
2026.09.17.12:00:32 Info: Finished: <b>Create HDL design files for synthesis</b>
make: *** [stamp/20.1/qsys.stamp] Error 3
Please advise.
Thanks.
Bob N
Replies (5)
MF RE: Quartus v23.1 errors building mitysom 5csx project - Added by Mike Fiorenza about 2 months ago
Hi Bob,
I think this is an issue with WSL 2. Altera explicitly states that WSL 2 is not supported here
You mentioned mirrored mode, which is a WSL 2 only feature, so I believe you're running WSL 2. Ubuntu 20.x should be okay, however Altera's note above also shows using Ubuntu 18.x.
The following should confirm your WSL version:
wsl -l -v
If this reports version 2, I think you'll need to flip this to 1:
wsl --set-version Ubuntu-20.04 1
Altera also calls for installing these packages:
sudo apt update sudo apt install wsl dos2unix make build-essential
Before and after, a quick check. Open the Nios II Command Shell on its own (C:\intelfpga\23.1std\nios2eds\Nios II Command Shell.bat) and run:
nios2-elf-gcc.exe --version make --version dos2unix --version
If all three report versions and it still fails, the real compiler error is being hidden. The command Quartus runs ends in 2>> stderr.txt, so the actual message goes to a file rather than the transcript, in your case under:
C:\Users\560057615\AppData\Local\Temp\alt0713_9118986005145505356.dir\0017_s0_gen\qsys_pre_compile\dev_5cs_fpga_ddr_s0_software\stderr.txt
Platform Designer cleans that temp directory up on exit, so you'll need to grab it while the generation is still up. Post that file and we'll take a look.
Let me know if you're still stuck after trying the details above!
- Mike
BN RE: Quartus v23.1 errors building mitysom 5csx project - Added by Bob Nayar about 2 months ago
Thank you so much, Mike.
Flipping WSL to 1 fixed it
Bob N
Thanks, Mike.
Flipping WSL to 1 fixed it 😊
(I posted the above in the forum)
I now have a smaller annoying problem. I getting this compiler error:
(even though Signal Tap is not enabled in this project)
Error (262009): Can't open Signal Tap Logic Analyzer. Verify that the license file exists and is stored in the correct location. If you are using the Quartus Prime Lite Edition software, you must turn on the TalkBack feature to use the Signal Tap Logic Analyzer.
Error: Quartus Prime Signal Tap was unsuccessful. 1 error, 0 warnings
Error: Peak virtual memory: 4642 megabytes
Error: Processing ended: Thu Sep 17 17:45:58 2026
Error: Elapsed time: 00:00:06
Error: Total CPU time (on all processors): 00:00:06
Can I comment out the quartus_stp $(QUARTUS_BASE) line in the Makefile?
Please advise.
Thanks.
Bob,
Are you using Quartus Standard 23.1? Not Prime Lite correct?
I tried to reproduce this here and couldn't quite land on your combination. I can get error 262009 out of Standard 23.1 with no license at all, but in that case synthesis fails first, so you'd never make it to this step. And Prime Lite doesn't produce that error at all, with or without a license. Since your synthesis is clearly running, my guess is you're on Standard with a license that covers the compile flow but not Signal Tap specifically.
That said - You can comment out that line in the Makefile like you suggested. There is nothing in the reference design that uses signal tap.
- Mike
Mike,
I am using Standard, but with a floating license, not a physical license.dat file.
And yeah, commenting the line out fixed the problem. Thanks
Bob N
