AM62x Enable UART2
Added by Tim Troester over 1 year ago
On the AM62x how do we enable UART2 during the Yocto build? We have created our own machine variation of k3-am62x-mitysom and created a dts file for it per the wiki instructions you provided. We thought we need to add this...
&main_uart2 {
pinctrl-names = "default";
pinctrl-0 = <&main_uart2_pins>;
status = "okay";
main_uart2_pins: main-uart2-pins {
pinctrl-single,pins = <
AM62X_IOPAD(0x1d4, PIN_OUTPUT, 3) /* (B15) UART2_TXD Console */
AM62X_IOPAD(0x1d0, PIN_INPUT, 3) /* (A15) UART2_RXD Console */
We also removed those pins from "main_gpio_p3_pins_default" since we muxed them.
It doesn't seem to be working when I cat /proc/tty/driver/serial.
I also see the below error at boot so it may be related.
[ 1.509258] omap8250 2820000.serial: failed to get alias
Any help would be appreciated.
Tim
Replies (6)
RE: AM62x Enable UART2 - Added by Bob Duke over 1 year ago
Tim,
What you have shown looks OK. Can you share your entire device tree file ? Nathan has access to our private project if you prefer to post the information there. You could also share your boot log and the output of cat /proc/tty/driver/serial.
-Bob
RE: AM62x Enable UART2 - Added by Jonathan Cormier over 1 year ago
I'm not sure why but it seems like setting the serial alias is required.
8250_omap.c:
ret = of_alias_get_id(np, "serial");
if (ret < 0) {
dev_err(&pdev->dev, "failed to get alias\n");
return ret;
There are currently several serial aliases set in the k3-am62x-mitysom-som.dtsi file, I'd recommend skipping a few numbers to prevent conflicts in the future if more serial aliases are added.
aliases {
serial0 = &mcu_uart0;
serial1 = &wkup_uart0;
serial2 = &main_uart0;
Example of adding the alias
diff --git a/arch/arm64/boot/dts/ti/k3-am62x-mitysom-devkit.dts b/arch/arm64/boot/dts/ti/k3-am62x-mitysom-devkit.dts
index 229f95f7c292..d900051e56c1 100644
--- a/arch/arm64/boot/dts/ti/k3-am62x-mitysom-devkit.dts
+++ b/arch/arm64/boot/dts/ti/k3-am62x-mitysom-devkit.dts
@@ -10,6 +10,10 @@
#include "k3-am62x-mitysom-som.dtsi"
+ aliases {
+ serial10 = &main_uart2;
vcc_12v: vcc_12v {
Then the port will show up as ttyS10 since we set the alias to serial5
root@mitysom-am62x:~# dmesg | grep serial [ 1.476861] 2800000.serial: ttyS2 at MMIO 0x2800000 (irq = 238, base_baud = 3000000) is a 8250 [ 1.507633] 2820000.serial: ttyS10 at MMIO 0x2820000 (irq = 240, base_baud = 3000000) is a 8250
RE: AM62x Enable UART2 - Added by Tim Troester over 1 year ago
Bob,
Thanks for the response. I was getting ready to reply saying that I was able to get it working. Here is what I did in case it helps others.
- Removed the previous mapping of the pins we wanted to use for UART2. There were being muxed as GPIO pins.
AM62X_IOPAD(0x01d0, PIN_INPUT_PULLDOWN, 7) /* (A15) UART0_CTSn.GPIO1_22 */AM62X_IOPAD(0x01d4, PIN_INPUT_PULLDOWN, 7) /* (B15) UART0_RTSn.GPIO1_23 */ - Muxed the pins to be part of UART2.
main_uart2_pins: main-uart2-pins { pinctrl-single,pins = < AM62X_IOPAD(0x1d4, PIN_OUTPUT, 3) /* (B15) UART2_TXD Console */ AM62X_IOPAD(0x1d0, PIN_INPUT, 3) /* (A15) UART2_RXD Console */ >; }; - Altered main_uart2 to use the pins that were repurposed and to enable it.
&main_uart2 { pinctrl-names = "default"; pinctrl-0 = <&main_uart2_pins>; status = "okay"; }; - Added an alias for uart2 (this is what I missing in my original question). This serial port will now be at /dev/ttyS4 (I would have used "serial2" but it was being used by something else).
&{/} { aliases { serial4 = &main_uart2; }; };
Jonathan,
Thanks for the additional info. I didn't see your response before I submitted mine. However, it looks like we are on the same page with the solution.
Tim
RE: AM62x Enable UART2 - Added by Jonathan Cormier about 1 year ago
Note to capture some of this information, we made a wiki page for it. https://support.criticallink.com/redmine/projects/mitysom_am62x/wiki/Example_-_uart2_Serial_CONSOLE
