NWrealtime linux on am62x
Added by Nathan Wright over 1 year ago
Hi guys,
With TI we can specify ARAGO_RT_ENABLE=1 and the layer will switch from preferring linux-ti-staging to linux-ti-staging-rt.
Is there something comparable for linux-cl-ti-staging?
If not, what would be the recommended path forward for getting PREEMPT_RT on am62x?
Nathan
Replies (8)
JC RE: realtime linux on am62x - Added by Jonathan Cormier over 1 year ago
Hi Nathan, Sorry for the delayed response. I am working on created an -rt version of our kernel recipe. Just waiting on builds to finish and to confirm it actually built the rt kernel.
Pushed kernel branch: https://support.criticallink.com/gitweb/?p=linux-ti.git;a=shortlog;h=refs/heads/mitysom-rt-linux-6.6.y
Updated 62xx-build.sh script to include the ti_rt configs as well
root@mitysom-am62x:~# uname -a
Linux mitysom-am62x 6.6.58-rt45-01858-g52ba4fa38e62 #20 SMP PREEMPT_RT Thu Mar 27 17:39:32 EDT 2025 aarch64 GNU/Linux
root@mitysom-am62x:~# zcat /proc/config.gz | grep PREEMPT_RT
CONFIG_PREEMPT_RT=y
Still working on the yocto recipe part. It built but the kernel was missing the RT configs. Probably missing something simple.
Hi sorry for the delay. I am a bit swamped. This is still on my TODO list.
NW RE: realtime linux on am62x - Added by Nathan Wright over 1 year ago
Hi Jon,
Just checking in, we are rapidly approaching being able to know if we need this or not. I thought I would ping you and see if you made any progress on it.
Nathan
Hi Nathan, I never heard back from you so this dropped off my todo list. I can try to pick it back up next week to see what the status is.
Please do.
There is a chance we won't need it, but I would like to have it my back pocket in the case that we do need it.
On the am57x family we did need the RT patch to keep up.
Confirmed that the yocto build is still not enabling the RT config options
Tested using processor-sdk-scarthgap-11.00.09.04-cl-config.txt
Edit 62x-build.sh and add ARAGO_RT_ENABLE
export MACHINE=mitysom-am62x
export ARAGO_RT_ENABLE=1
./docker.sh ./62x-setup.sh
./docker.sh ./62x-build.sh
Booted ti-base-image-rt and no RT extensions
Linux mitysom-am62x 6.6.58-g-rt-g7a2fa4c23070 #1 SMP Tue Apr 29 13:30:39 UTC 2025 aarch64 GNU/Linux
root@mitysom-am62x:~# zcat /proc/config.gz | grep CONFIG_PREEMPT_RT
root@mitysom-am62x:~# cat /sys/kernel/realtime
cat: can't open '/sys/kernel/realtime': No such file or directory
Will look into this more. Likely I'm selecting the wrong defconfig somehow
JC RE: realtime linux on am62x - Added by Jonathan Cormier about 1 year ago
I got the linux-cl-ti-rt-6.6 recipe working
CONFIG_PREEMPT_RT=y
1
Also the linux-cl-ti-rt-6.12 recipe. Note in 6.12 the RT patches are now part of the mainline code, so no separate branch. It also looks like they got rid of the /sys/kernel/realtime file.
I'd recommend using the 6.12 kernel if possible.
Linux mitysom-am62x 6.12.17-g-rt-g7ea23b3f9c47 #1 SMP PREEMPT_RT Thu Aug 14 21:04:03 UTC 2025 aarch64 GNU/Linux
CONFIG_PREEMPT_RT=y
    (1-8/8)
