MitySOM-5CSX VDK for Basler dart BCON Revision History
Note : To access files you need to have a registered account on this site. You can register for an account using the link on the top right of this page.
Date Single Camera SW Single Camera SD-Card Image Dual Camera SW Dual Camera SD-Card Image Tool Kit Download
08-03-2017 40-000120-pre-release sd_card.img.gz N / A N / A See Files Tab
08-21-2017 40-000120-1 sd_card.img.gz 40-000131-1 sd_card_dual.img.gz linux 64-bit installer
40-000120-1 / 40-000131-1 [2017-08-21]
Change Log
The following toolchain was used to build the FPGA and bootloader software.
  • FPGA built with Quartus 17.0
  • ARM software built with DS-5 tools provided with Quartus SoC EDS 17.0
  • Linux software built using gcc 5 under the yocto krogoth filesystem release
  • All libraries and header files are included in yocto installation package to support building example projects
Added Features
  • Added basic support for dual camera operation using daA1280-54bm cameras.
Bugs Fixed
  • Catch exceptions on startup that may be thrown by Pylon library more gracefully.
  • cleaned up several marked "todo" items in the code base.
Known Issues
  • The M.2 PCIe interface is not yet tested.
  • There is no clean way to identify the position of installed cameras (i.e., slot 0 or 1) aside from serial number or using unique camera types.
  • The MityCAMBconAdapter library abstraction for streaming has a couple of open items related to setting timestamp and offset information.
  • The meta layer and relevant source tarballs are not yet published to support building entire yocto filesystems from scratch.
