MitySOM-335x Development Kit¶
Overview¶
The AM335X Development kit consists of a mother board and accessories that Critical Link includes with our Development Kit for the MitySOM-335X family of System On Modules. Full details regarding the AM335X Development kit, including the datasheet, may be found on the Critical Link website.
Included in each kit is a Quick Start Guide
Host Board Interfaces¶
- Gigabit Ethernet Interface (RJ-45)
 - RS-232 Debug console serial port
 - LCD/Touchpanel connector (for Critical Link LCD and DVI Display Solutions)
 - 2 x External UART expansion headers
- 1 x RS-232 I/O board
 - 1 x 422/485 I/O board
 - 2 x CAN interfaces with isolated +5V supply
 - DVI port (using HDMI connector) - Default support 800x600 Displays
 - SD card slot
 - 2 channel audio headphone output
 - Microphone audio input
 - 12 Boot Jumpers for boot peripheral order
 - I2C0 Current Monitor IC
 - 8 x Analog inputs (0 - 10V)
 - USB 2.0 Host Port
 - USB 2.0 Client Port (mini-B connector)
 - Expansion header for WiFi network interface
Note: Both the HDMI/DVI display output and LCD display header (J700) may used be simultaneously but only a single output resolution/timing is supported. I.E. both displays must support 1024x768 if that is the setting currently programmed.
Errata and Revision Information¶
Errata
Schematics for Development Kit including Revision Information
Helpful links¶
