DSP / ARM Hello World CCS 5.5¶
We recommend utilizing Code Composer Studio 7 as documented in this wiki
 - DSP / ARM Hello World CCS 5.5
This guide will step you through setting up your MityDSP-L138 system and build environment so that you can run a hello world program on both the DSP and ARM which sends a message, "Hello DSP", from the DSP to the ARM processor. This uses the dsplink driver for inter-processor communications:
ARM received a message from the DSP:
        DSP Message = "Hello Word. DSP Received Message = 'Hello DSP'"
Prerequisites¶
- Make sure your system and build environment are setup to run a Hello World program on the ARM side.
- See Starter Guide for a step by step guide of this process.
- Make sure your MityDSP-L138 module has the latest Kernel and Filesystem to match the MDK you are using
- See Updating devkit to latest MDK fpr a step by step guide of this process.
- Make sure that you have the necessary library and include files from Critical Link:
- The 2014-01-13 MDK, which can be downloaded from the Files section on this site.
- If you are registered and logged in, there should be a "Files" tab at the top of this page.
 - Note: If you are having trouble installing the MDK see this post.
 - To install the MDK on a Windows machine (for using CCS on the windows machine), you should use cygwin to install the .run file to an appropriate directory.
 - You will need to set up your environment variables to point to this MDK directory.
 - On your Linux Virtual Machine provided by Critical Link you will need:
- attachment:arm_main.cpp - Hello World code for the ARM ($MDK/examples/DspHelloWorld/ARM/)
 - dsplinkk.ko - Can be found in the latest MDK release ($MDK/images/modules/) or you can rebuild DSPLink. See details at DSP Link Configuration.
 - dsplink.lib - Can be found in the latest MDK release ($MDK/lib/ARM/Release/) or you can rebuild DSPLink. See details at DSP Link Configuration.
 - libdsp.a and libdsp.so.* - Can be found in the latest MDK release ($MDK/lib/ARM/Release/) or you can rebuild the libdsp library.
 - attachment:main_dsp.cpp - Hello World code for the DSP ($MDK/examples/DspHelloWorld/DSP/HelloWorldDSP/)
 - dspcore.lib, dsplink.lib, etc. - Can be found in the latest MDK release ($MDK/lib/DSP/Release)
 - Platform.tci - Can be found in the latest MDK release ($MDK/sw/DSP/templates/criticallink/platforms/MityDSP-L138/)
 - SYS/BIOS must be installed before Code Composer Studio (If you are using the 2018 Virtual Machine image this is already installed)
- SYS/BIOS version 5.42 is the version on the unified VM. Other versions of SYS/BIOS have not been tested.
 - SYS/BIOS installers can be found on the TI downloads site
Compiling for the ARM¶
This process documents how to compile/build the application for the ARM processor (arm_main.cpp)
- Download and utilize the attachment:Makefile if you prefer to work from the command line.
- Or, if you prefer to use an IDE, Open Eclipse or Code Composer and create a new C++ project
- Follow the procedure outlined in Starter Guide for creating a new project
 - Alternatively you can use Qt Creator. https://support.criticallink.com/redmine/projects/arm9-platforms/wiki/QT_Starter_Guide#Tip
- Add the arm_main.cpp file to the project
- This can be accomplished by simply moving the file to the project's directory and refreshing the project.
 - This can also be accomplished by importing the file. See Help - Eclipse SDK for details.
- Set up Build Variables
- In project properties, under 'C/C++ Build' click on 'Build Variables'
 - Click 'Add...' and type variable name, Check "Apply to all configurations", set 'Type' to 'Directory', enter path and click 'Ok'
 - Add the paths shown in the following image
| Variable Name | Type | Value |
| MDK | Directory | ${HOME}/MDK_2014-01-13 |
| LIBARM | Directory | ${MDK}/lib/ARM/Debug |
| LIBDSP | Directory | ${MDK}/sw/ARM/linux/libdsp |
- Note: As you follow through this guide, please follow closely the use of quotations when using build variables. Differing use could lead to build errors which are difficult to diagnose.
- Add the path to $MDK/sw/ARM/linux/libdsp to the include path
- In project properties, under 'C/C++ Build' click on 'Settings'
 - Under the 'Tool Settings' tab, expand 'Cross G++ Compiler' and click on 'Directories'. Called 'Includes' in some versions.
 - Click the Add button and enter the path to "${MDK}/sw/ARM/linux/libdsp" or "${LIBDSP}" if defined build variables
- Link against the libdsp and libpthread libraries
 - Under the 'Tool Settings' tab, expand 'Cross G++ Linker' and click on 'Libraries'
 - In the 'Libraries (-l)' window pane use the add button to add 'dsp' and 'pthread'
 - In the 'Library search path (-L)' window pane add the path to "${MDK}/lib/ARM/Release" or "${LIBARM}" if defined build variables
- Link against dsplink.lib
 - Under the 'Tool Settings' tab, expand 'Cross G++ Linker' and click on 'Miscellaneous'
 - In the 'Other objects' window pane click add and add the path to "${MDK}/lib/ARM/Release/dsplink.lib" or "${LIBARM}/dsplink.lib" if defined build variables
- Build the project.
- Copy libdsp.so.* to the MityDSP-L138
- Copy the library ($MDK/lib/ARM/Release/) to the /lib directory
 - See Starter Guide for details on copying files to the MityDSP-L138
- Copy the built ARM executable from the CCS/Eclipse project (i.e. "HelloWorldDSP") to the MityDSP-L138
- If CCS on the VM was used with the default workspace the file can be found in the /home/mitydsp/workspace_v7/HelloWorldDSP/Debug/ directory
Compiling for the DSP - CCSv5.5 on Windows¶
Setup¶
Please note that the Code Composer Studio section in which the DSP code will be built applies to, and was originally performed on, a Windows PC.
 It is possible to install Code Composer on the linux VM. See Installing CCS5 for L138 DSP for details.
- Install Code Composer Studio v5.5 on your PC.
- Installer can be download here
Create a new CCS project¶
- File->New->CCS Project
If CCS Project isn't listed, check under Other -> Code Composer Studio.
 - Give the project a name
 - Set 'Output type:' to 'Executable'
 - Set 'Device Family:' to C6000
 - Set 'Device Variant:' to 'Generic devices' followed by 'Generic C674x Device'
 - Expand the 'Advanced settings menu':
- Set 'Device endianness' to 'little'
- Expand 'Project templates and examples':
- Inside 'DSP/BIOS v5.xx Examples' open up 'evmOMAPL138 Examples' and select 'hello example'
 - Click 'Finish'
 - Delete the hello.c file that was auto-generated when the project was created by right clicking the file within your project in the 'Project Explorer' and selecting 'Delete'
- Add the main_dsp.cpp file to the project. <MDK>/examples/DspHelloWorld/DSP/HelloWorldDSP/main_dsp.cpp
- This can be accomplished by copying main_dsp.cpp to the project directory
 - This can also be accomplished by right clicking on the project and selecting 'Link Files to Project...' or 'Add Files to Project...'
- Create a DSP/BIOS Configuration file
- Delete any created tcf file for the hello example. "hello.tcf"
 - File->New->DSP/BIOS v5.x Configuration File
- Note: If 'DSP/BIOS v5.x Configuration File' is not an option, you will need to select 'Other...' and search for 'bios'
 - Click 'Next' on the window that pops up (default name is fine)
 - Click Modify
 - Browse to the directory which contains Platform.tci. <MDK>/sw/DSP/templates
 - Select criticallink.platforms.MityDSP-L138 (Description = 'MityDSP-L138 (300 MHz)')
 - Click 'Finish'
 - Save and close the window that pops up
Add environment variables which point to the necessary libraries for the DSPL138/EDMA3 (Suggested)¶
- Note: Please be careful where and when you use quotes around path names, especially if you are using Macros
- Quotes will be required if a path name has a space in it (otherwise it will be read as two separate paths by the compiler).
 - However, you should only encase the actual include specification in quotes and not the macro itself.
 - Here's an example of what can go wrong:
- You create a Environment Variable ${MDK} = "c:/my work/MDK"
 - You specify a search path as "${MDK}/sw/DSP/templates"
 - However, this derefences to ""c:/my work/MDK"/sw/DSP/templates" where the quotes are no longer surrounding the space in your path name
- Right click on project and select 'Properties'
 - Click on 'Build'
 - Click on the 'Environment' tab
 - Add variables - relevant paths are shown in the picture below
- If using the MDK the header files should be stored in ${MDK}/sw/DSP/lib and the libraries should be stored in ${MDK}/lib/DSP
 - Depending on where the EDMA package (downloaded as a prerequisite) installed, your TI_EDMA3 path may differ
MDK <dir to MDK> MITYDSPL138_LIBDBG ${MDK}/lib/DSP/Debug MITYDSPL138_SW_LIB ${MDK}/sw/DSP/lib TI_EDMA3 ${MDK}/sw/3rdparty/edma3lld_01_11_00_03/packages/
 - Click apply
- Specify the project Include Options
- Right click on the project and select 'Properties'
 - Expand 'Build'
 - Expand 'C6000 Compiler' and select 'Include Options'
 - Add the appropriate directories, or the Environment Variable(s) you created in the above step (i.e. "${MityDSPL138_LIBDBG}"), to the Include Options. Note quotes are important.
"${MITYDSPL138_LIBDBG}" "${MITYDSPL138_SW_LIB}" "${TI_EDMA3}" "${TI_EDMA3}/ti/sdo/edma3"
- Specify the linking options
 - Expand 'Build'
 - Expand 'C6000 Linker' and select 'File Search Path'
 - In the "Include library file or command file as input (--library, -l)" pane, add the following:
- "dspcore.lib"
 - "edma3_drv_bios.lib"
 - "edma3_drv_bios_sample.lib"
 - "edma3_rm_bios.lib"
 - "dsplink.lib"
 - "dsplinkdata.lib"
 - "dsplinkmpcs.lib"
 - "dsplinkmplist.lib"
 - "dsplinkmsg.lib"
 - "dsplinknotify.lib"
 - "dsplinkpool.lib"
 - "dsplinkringio.lib"
 - In the "Add <dir> to library search path (--search_path, -i)" pane, add the directories, or Environment Variable(s) created above, that contain the above libraries
- These libraries are located in ${MDK}/lib/DSP/Debug or ${MDK}/lib/DSP/Release if you are pulling them from the MDK (shown using the "${MityDSPL138_LIBDBG}" Environment Variable)
"${TI_EDMA3}/ti/sdo/edma3/drv/sample/lib/omapl138/Debug" "${TI_EDMA3}/ti/sdo/edma3/rm/lib/omapl138/Debug" "${TI_EDMA3}/ti/sdo/edma3/drv/lib/Debug" "${MITYDSPL138_LIBDBG}" "${MITYDSPL138_SW_LIB}"
- Specify the location of ${MDK}/sw/DSP/templates directory, where the criticallink/platforms/MityDSP-L138/Platform.tci file is located:
 - Expand 'Build'
 - Expand 'TConf' and select 'General Options'
 - Set to the path to the location of ${MDK}/sw/DSP/templates on your machine, which contains contains criticallink/platforms/MityDSP-L138/Platform.tci
 - Note: you must specify the location of the ${MDK}/sw/DSP/templates directory and not any deeper as the criticallink/platforms/MityDSP-L138/ path is expected in parts of the build process.
Final steps¶
- Build the project
- Copy the built executable from the CCS project (i.e. "HelloWorldDSP.out") to the MityDSP-L138
Running the ARM/DSP programs¶
- Insert (insmod) the DSPLink drivers
root@mityomap# insmod /lib/modules/$(uname -r)/extra/dsplinkk.ko
- The pre-built MityDSP-L138 MDK filesystems include the dsplinkk.ko driver. If missing you can copy and/or rebuild the driver from the MDK
- The pre-built copy is located in the $MDK/images/modules/ directory
- Execute the ARM (HellowWorldDSP) and DSP (HellowWorldDSP.out) programs
root@mityomap# ./HelloWorldDSP HelloWorldDSP.out
- Example output
root@mityomapl138:~# ./HelloWorldDSP HelloWorldDSP.out Loading file HelloWorldDSP.out PROC Load successful Starting application. ARM received a message from the DSP: DSP Message = "DSP Initialization finished." Sending a message to the DSP. Waiting for DSP response (type 'q' to quit)... ARM received a message from the DSP: DSP Message = "Hello Word. DSP Received Message = 'Hello DSP'" Exiting application.
Note: There is currently a bug in the destructors of ipc_inbound and ipc_outbound that cause assert statements to get hit. The delete statements have been skipped as a way of removing the error messages. This is a decent solution for now as most applications shouldn't need to be shutdown and restart large numbers of times.
