MMC/SD Card Throughput¶
Below are test results using a L138-FG-225-RC module.
The instructions found here (http://support.criticallink.com/redmine/projects/arm9-platforms/wiki/Setting_CPU_Speed) were followed to change the CPU clock frequency for each test.
The Class 10 Card was a PNY Professional 8GB SD Card.
The Class 4 Card was a Kingston 4GB MicroSD Card in a full size SD card adapter.
Each test was performed at 300MHz, 372MHz and 456MHz on the same development kit PCB with the same SoM. The tests were performed using the linux 'dd' utility. However note that the tests were performed without respect to a particular filesystem type (I.e. FAT, EXT2, etc.) so these speeds are best case and will be slower when writing to a file system.
Write Speed Tests¶
Class 10 Linux PC Write Speed = 13.X MB/s
Class 4 Linux PC Write Speed = 5.X MB/s
300MHz¶
Class 10 SD Card
time sh -c "dd if=/dev/zero of=/dev/mmcblk0p1 bs=64k count=10240 && sync" 10240+0 records in 10240+0 records out 671088640 bytes (671 MB) copied, 73.0217 s, 9.2 MB/s real 1m 13.17s user 0m 0.15s sys 0m 14.21s
Class 4 SD Card
time sh -c "dd if=/dev/zero of=/dev/mmcblk0p1 bs=64k count=10240 && sync" 10240+0 records in 10240+0 records out 671088640 bytes (671 MB) copied, 127.457 s, 5.3 MB/s real 2m 7.61s user 0m 0.14s sys 0m 15.20s
372MHz¶
Class 10 SD Card
time sh -c "dd if=/dev/zero of=/dev/mmcblk0p1 bs=64k count=10240 && sync" 10240+0 records in 10240+0 records out 671088640 bytes (671 MB) copied, 64.2673 s, 10.4 MB/s real 1m 4.43s user 0m 0.08s sys 0m 12.36s
Class 4 SD Card
time sh -c "dd if=/dev/zero of=/dev/mmcblk0p1 bs=64k count=10240 && sync" 10240+0 records in 10240+0 records out 671088640 bytes (671 MB) copied, 125.338 s, 5.4 MB/s real 2m 5.47s user 0m 0.16s sys 0m 13.80s
456MHz¶
Class 10 SD Card
time sh -c "dd if=/dev/zero of=/dev/mmcblk0p1 bs=64k count=10240 && sync" 10240+0 records in 10240+0 records out 671088640 bytes (671 MB) copied, 67.4358 s, 10.0 MB/s real 1m 7.52s user 0m 0.13s sys 0m 10.80s
Class 4 SD Card
time sh -c "dd if=/dev/zero of=/dev/mmcblk0p1 bs=64k count=10240 && sync" 10240+0 records in 10240+0 records out 671088640 bytes (671 MB) copied, 122.894 s, 5.5 MB/s real 2m 2.99s user 0m 0.16s sys 0m 13.33s
Read Speed Tests¶
Class 10 Linux PC Read Speed = 19.X MB/s
Class 4 Linux PC Read Speed = 18.X MB/s
300MHz¶
Class 10 SD Card
time sh -c "dd of=/dev/null if=/dev/mmcblk0p1 bs=64k count=10240 && sync" 10240+0 records in 10240+0 records out 671088640 bytes (671 MB) copied, 48.3621 s, 13.9 MB/s real 0m 48.47s user 0m 0.18s sys 0m 20.13s
Class 4 SD Card
time sh -c "dd of=/dev/null if=/dev/mmcblk0p1 bs=64k count=10240 && sync" 10240+0 records in 10240+0 records out 671088640 bytes (671 MB) copied, 51.963 s, 12.9 MB/s real 0m 52.17s user 0m 0.29s sys 0m 21.40s
372MHz¶
Class 10 SD Card
time sh -c "dd of=/dev/null if=/dev/mmcblk0p1 bs=64k count=10240 && sync" 10240+0 records in 10240+0 records out 671088640 bytes (671 MB) copied, 45.9785 s, 14.6 MB/s real 0m 46.06s user 0m 0.13s sys 0m 10.29s
Class 4 SD Card
time sh -c "dd of=/dev/null if=/dev/mmcblk0p1 bs=64k count=10240 && sync" 10240+0 records in 10240+0 records out 671088640 bytes (671 MB) copied, 44.5213 s, 15.1 MB/s real 0m 44.60s user 0m 0.21s sys 0m 15.75s
456MHz¶
Class 10 SD Card
time sh -c "dd of=/dev/null if=/dev/mmcblk0p1 bs=64k count=10240 && sync" 10240+0 records in 10240+0 records out 671088640 bytes (671 MB) copied, 46.1925 s, 14.5 MB/s real 0m 46.26s user 0m 0.08s sys 0m 16.34s
Class 4 SD Card
time sh -c "dd of=/dev/null if=/dev/mmcblk0p1 bs=64k count=10240 && sync" 10240+0 records in 10240+0 records out 671088640 bytes (671 MB) copied, 49.8998 s, 13.4 MB/s real 0m 49.97s user 0m 0.12s sys 0m 15.15s
