3.3V Supply Requirements¶
The MityDSP-L138F and the MityARM-1808F are powered by an external 3.3 Volt power supply as well as an optional 3 volt RTC battery backup supply. The 3.3V power supply is used to derive several additional voltages on the module. Actual power utilization of these modules is highly dependent on the application and factors such as:
- CPU clock rate
- FPGA clock rates (if present)
- FPGA logic density (if present)
- CPU Peripheral utilization
- Utilization of CPU and FPGA power down / low power modes
The following section outlines several use cases and the measured power consumption. It would seem that most designs with SOMS including FPGAs we have encountered consume, typically, between 1 to 2 watts. Critical Link recommends, for power sensitive applications, developers consider assembling a prototype and measuring power consumption with the MityDSP-L138F SOM in a configuration that roughly matches the end application in order to better assess power performance.
Measured 3.3V power draw for various uses¶
This section attempts to give you a better feel for module power draw under various configurations. The power consumption here includes the entire module, not just the OMAP-L138. It includes the on Module DC to DC converters, power good and FPGA status LEDs , the OMAP or AM1810, the NAND FLASH, SPI FLASH, and miscellaneous crystals, etc.
Module | CPU Clock | Peripherals Enabled in Kernel | ARM Load | DSP Load (%) | Notes | I (mA) | Power (mW) |
MityDSP-L138 | N/A | 3 Uarts, SPI, MII, MDIO, RTC, EMIFA, 2xUSB, McASP | N/A | Reset | Sleep to Memory | TBS | TBS |
MityDSP-L138 | 96 MHz | 3 Uarts, SPI, MII, MDIO, RTC, EMIFA, 2xUSB, McASP | 5% | Reset | Running Linux | 170 | 561 |
MityDSP-L138 | 300 MHz | 3 Uarts, SPI, MII, MDIO, RTC, EMIFA, 2xUSB, McASP | 5% | Reset | Running Linux | 230 | 759 |
MityDSP-L138 | 300 MHz | 3 Uarts, SPI, MII, MDIO, RTC, EMIFA, 2xUSB, McASP | 100% | Reset | network I/O test | 270 | 891 |
MityDSP-L138 | 456 MHz | 3 Uarts, SPI, MII, MDIO, RTC, EMIFA, 2xUSB, McASP | 3% | Reset | Running Linux | 250 | 825 |
MityDSP-L138 | 456 MHz | 3 Uarts, SPI, MII, MDIO, RTC, EMIFA, 2xUSB, McASP | 100% | Reset | network I/O test | 300 | 990 |
MityDSP-L138F (LX16) | 300 MHz | 3 Uarts, SPI, MII, MDIO, RTC, EMIFA, 2xUSB, McASP | 5% | Reset | Running Linux | 300 | 990 |
MityDSP-L138F (LX16) | 300 MHz | 3 Uarts, SPI, MII, MDIO, RTC, EMIFA, 2xUSB, McASP, DVI, Camera | 2% | Idle | Running Linux and GUI Vision Dev Kit No Camera Displayed | 325 | 1063 |
MityDSP-L138F (LX16) | 372 MHz | 3 Uarts, SPI, MII, MDIO, RTC, EMIFA, 2xUSB, McASP, DVI, Camera | 2% | Idle | Running Linux and GUI Vision Dev Kit No Camera Displayed | 335 | 1095 |
MityDSP-L138F (LX16) | 300 MHz | 3 Uarts, SPI, MII, MDIO, RTC, EMIFA, 2xUSB, McASP, DVI, Camera | 54% | Bayer Color Conversion DSP | Running Linux and GUI Vision Dev Kit | 340 | 1111 |
MityDSP-L138F (LX16) | 300 MHz | 3 Uarts, SPI, MII, MDIO, RTC, EMIFA, 2xUSB, McASP, DVI, Camera | 95% | Idle | Running Linux and GUI Vision Dev Kit FPGA Based Grayscale | 340 | 1111 |
MityDSP-L138 | 300 MHz | 3 Uarts, SPI, MII, MDIO, RTC, EMIFA, 2xUSB, McASP, DVI | 2% | Idle | Running Linux and Vision Dev Kit GUI with DSP programmed but Idle | 310 | 1013 |
MityDSP-L138F (A735) | 300 MHz | N/A | 5% | Reset | uBoot IDLE, FPGA not programmed | 210 | 693 |
MityDSP-L138F (A735) | 300 MHz | 3 Uarts, SPI, MII, MDIO, RTC, EMIFA, 2xUSB, McASP, DVI | 5% | Reset | Running Linux, FPGA not Programmed | 300 | 990 |
MityDSP-L138F (A735) | 300 MHz | 3 Uarts, SPI, MII, MDIO, RTC, EMIFA, 2xUSB, McASP, DVI | 5% | Reset | Running Linux, FPGA Programmed with Industrial IO reference project, DVI active | 310 | 1023 |
