Using PRU¶
TI provided examples for the L138
http://processors.wiki.ti.com/index.php/PRU_Linux_Application_Loader
References¶
The 335x has a similar PRU and some of its documentation should be usable with minor tweaks.
http://elinux.org/Ti_AM33XX_PRUSSv2
http://processors.wiki.ti.com/index.php/PRU-ICSS_FAQ
http://processors.wiki.ti.com/index.php/PRU_Projects
Examples Setup:¶
Note need the latest version of the svn repo.  Revision 24 requested by the TI guide segfaults right away for the 3.2 kernel driver.
Note If asked for password, leave blank
svn co --username anonymous https://gforge.ti.com/svn/pru_sw/trunk pru_sw
cd pru_sw
make CCTOOL_PREFIX=$TARGET_PREFIX libprussdrv
cd example_apps
make CCTOOLS=${TARGET_PREFIX}gcc
Copy all files in created bin folder to L138 /home/root/bin_pru
Running examples¶
Running through all the examples.
Note: Several of the examples directly access the DDR memory and can cause a system segfault if an application or linux itself is using that memory. A safe design that wanted to use shared DDR would probably have to either reserve some memory similar to how the DSP does by using mem= in bootargs. Or the application could malloc some memory and pass the physical memory address to the PRU to use. Unsure if userspace can determine the physical address of malloc'd memory so might need to be done within the driver.
root@mityomapl138:~/bin_pru# ls PRU_ARMtoPRU_Interrupt PRU_memAccessL3andDDR.bin PRU_ARMtoPRU_Interrupt.bin PRU_memAccessPRUDataRam PRU_PRU0toPRU1_Interrupt.bin PRU_memAccessPRUDataRam.bin PRU_PRU1toPRU0_Interrupt.bin PRU_memCopy PRU_PRUtoARM_Interrupt PRU_memCopy.bin PRU_PRUtoARM_Interrupt.bin PRU_miscOperations PRU_PRUtoPRU_Interrupt PRU_miscOperations.bin PRU_access_const_table PRU_multiply PRU_access_const_table.bin PRU_multiply.bin PRU_edmaConfig.bin PRU_pscConfig.bin PRU_edmaInterrupt.bin PRU_semaphore PRU_gpioToggle PRU_semaphore.bin PRU_gpioToggle.bin PRU_timer2Interrupt PRU_mem1DTransfer PRU_timer2Interrupt.bin PRU_mem1DTransfer.bin pinmux.bin PRU_memAccessL3andDDR pinmux_reset.bin
root@mityomapl138:~/bin_pru# ./PRU_ARMtoPRU_Interrupt
INFO: Starting PRU_ARMtoPRU_Interrupt example.
        INFO: Initializing example.
File ./PRU_ARMtoPRU_Interrupt.bin open passed
        Generate interrupt
        INFO: Waiting for HALT command.
        INFO: PRU completed transfer.
Example completed successfully.
root@mityomapl138:~/bin_pru# ./PRU_PRUtoARM_Interrupt
INFO: Starting PRU_PRUtoARM_Interrupt example.
        INFO: Executing example.
File ./PRU_PRUtoARM_Interrupt.bin open passed
Example executed succesfully.
^C
root@mityomapl138:~/bin_pru# ./PRU_PRUtoPRU_Interrupt
INFO: Starting PRU_PRUtoPRU_Interrupt example.
        INFO: Executing example on PRU0.
File ./PRU_PRU0toPRU1_Interrupt.bin open passed
                INFO: Executing example on PRU1.
File ./PRU_PRU1toPRU0_Interrupt.bin open passed
        INFO: PRU0 completed transfer.
                INFO: PRU1 completed transfer.
root@mityomapl138:~/bin_pru# ./PRU_access_const_table
INFO: Starting PRU_access_const_table example.
        INFO: Executing PSC configuration code .
File ./PRU_pscConfig.bin open passed
File ./PRU_access_const_table.bin open passed
root@mityomapl138:~/bin_pru/bin# ./PRU_gpioToggle
INFO: Starting PRU_gpioToggle example.
INFO: Executing pinmux configuration.
File ./pinmux.bin open passed
File ./PRU_gpioToggle.bin open passed
INFO: Example executed succesfully.
        INFO: Executing pinmux reset.
File ./pinmux_reset.bin open passed
root@mityomapl138:~/bin_pru# ./PRU_mem1DTransfer
INFO: Starting PRU_mem1DTransfer example.
File ./PRU_mem1DTransfer.bin open passed
root@mityomapl138:~/bin_pru# ./PRU_memAccessL3andDDR
INFO: Starting PRU_ARM_memAccessL3andDDR example.
File ./PRU_memAccessL3andDDR.bin open passed
root@mityomapl138:~/bin_pru/bin# ./PRU_memAccessPRUDataRam
INFO: Starting PRU_memAccessPRUDataRam example.
File ./PRU_memAccessPRUDataRam.bin open passed
root@mityomapl138:~/bin_pru/bin# ./PRU_memCopy
INFO: Starting PRU_memCopy example.
INFO: Initializing aligned example.
File ./PRU_memCopy.bin open passed
INFO: Initializing same offset example.
INFO: Initializing different offset example.
root@mityomapl138:~/bin_pru/bin# ./PRU_miscOperations
INFO: Starting PRU_miscOperations example.
File ./PRU_miscOperations.bin open passed
Masking and bit_shift operations were executed succesfully
Bubble sort was executed succesfully
Thresholding functionality was executed succesfully
root@mityomapl138:~/bin_pru/bin# ./PRU_multiply
INFO: Starting PRU_multiply example.
File ./PRU_multiply.bin open passed
root@mityomapl138:~/bin_pru/bin# ./PRU_semaphore
Starting PRU PRU_semaphore example.
        INFO: Current Transfer size = 4 bytes.
PRU has permission
        INFO: Loading and executing transfer in PRU.
File ./PRU_semaphore.bin open passed
        INFO: Current Transfer size = 14 bytes.
ARM has permission
Segmentation fault
root@mityomapl138:~/bin_pru/bin# ./PRU_timer2Interrupt
INFO: Starting PRU_timer2Interrupt example.
File ./PRU_timer2Interrupt.bin open passed
root@mityomapl138:~/bin_pru/bin# ./PRU_memAccessL3andDDR
