Configure U-Boot Splash Screen¶
U-Boot can be configured to display a splash screen before the Linux kernel boots. This is typically used to display a product logo.
Enabling the splash screen in U-Boot 2013.10¶
The AM335x devkit's U-Boot has a branch (u-boot-2013.10) with integrated splash screen support. This branch supports the NEC NL6448BC20-21D, a 640x480 display when connected to the MitySOM-335x Dev Kit baseboard. A sample splash image has been provided. If you are using a custom baseboard and you want to use these instructions, please verify that your pinmux for the display pins matches the MitySOM-335x Dev Kit.
In order to enable the display of the splash screen, please note that you have to uncomment the relevant section of include/configs/mityarm335x.h to define the CONFIG_VIDEO option.
Adding your display configuration¶
The display driver (DA8xx) needs to be configured to support a specific display.
Display configurations are found at board/cl/mityarm335x/som.c.
For an example see the NEC NL6648BC20-21D's configurationstatic const struct da8xx_panel lcd_panel = {
.name = "640x480",
.width = 640,
.height = 480,
.hfp = 13,
.hbp = 45,
.hsw = 63,
.vfp = 11,
.vbp = 32,
.vsw = 2,
.pxl_clk = 25175000,
.invert_pxl_clk = 0,
LCD Panel configuration fields¶
| Field | Description |
name |
Name of the LCD panel. Must be less than 24 characters. This should be in the form of <vendor>_<model> to be descriptive but could be the panel's resolution. |
width |
Width of the panel in pixels. |
height |
Height of the panel in pixels. |
hfp |
Horizontal front porch. |
hbp |
Horizontal back porch. |
hsw |
Horizontal sync pulse width. |
vfp |
Vertical front porch. |
vbp |
Vertical back porch. |
vsw |
Vertical sync pulse width. |
pxl_clk |
Pixel clock frequency. |
invert_pxl_clk |
Set to 1 to invert the pixel clock, 0 otherwise. |
This information is provided on the LCD's datasheet although names may differ.
Warning: Running an LCD panel with incorrect clock settings may damage the panel.
Adding your own splash image¶
U-Boot will automatically pull in a splash image into its binary it builds. To use this feature, the splash image must be added to the tools/logos directory and must have the same name as the build target.
For example, the patch adds a splash image to the mityarm335x board so its image is found at: tools/logos/mityarm335x.bmp
The splash image must be saved as an 8-bit palletized BMP.
This can best be done in Microsoft Paint by saving the image as a "256 Color Bitmap".
Other tools such as ImageMagick's convert may not produce a compatible image.
The image's file type can be checked with the file command:PC bitmap, Windows 3.x format, 640 x 480 x 8
Make sure the width and height match the screen's resolution and that the bit depth is 8.
Note: Due to the low palette size, images with many colors or gradients may have their colors distorted.
