GPIO Usage Overview¶
In Critical Link kernels we enable GPIO support by default and almost every design will make use of a GPIO for some function (Ethernet reset, status LED, etc.). Please note that the TI Linux GPIO Wiki concerning the GPIO driver is a great resource to reference.
GPIO Pin Muxing¶
As for all AM335x pins the pin-mux must be configured in the kernel for every processor pin. For any pin that can be configured as a GPIO the mode is always the last mode, 7 (base of 0), as each pin can support up to 8 different pin-mux modes. This wiki page Creating a custom baseboard provides further details about this process.
- GPIO1_13 as an output
{"gpmc_ad13.gpio1_13", AM33XX_PULL_ENBL | AM33XX_PIN_OUTPUT}, - GPIO1_12 as an input
{"gpmc_ad12.gpio1_12", AM33XX_PIN_INPUT_PULLUP},
GPIO Mapping¶
The AM335x processor features 4 banks of GPIO's, with up to 32 GPIO's each.
For example Module Pin 114 when pin-muxed as a GPIO is GPIO2[20]. That means that to access that GPIO at the Userspace level it is referenced as GPIO# 84. This is based on the 2[20] portion of the GPIO mode name.
2 (GPIO Bank #) * 32 (# of GPIO's per bank) = 64
64 (Base number for bank 2) + 20 (index of this specific GPIO in the bank) = 84.
#define GPIO_TO_PIN(bank, bank_gpio) (32 * (bank) + (bank_gpio))
Example Userspace Usage (for development kit and development kit Kernel)¶
J506 (10-pin shrouded header) - Pin 1 (Module pin 114 - GPIO2[20])
https://www.kernel.org/doc/Documentation/gpio/sysfs.txt
- Login to Linux through the console serial port using the user name of "root" with no password
- This will export the GPIO and allow you to use it
echo "84" > /sys/class/gpio/export
- Set the direction as an output
echo "out" > /sys/class/gpio/gpio84/direction
- Enable the GPIO - 3.3V driven on this bus
echo "1" > /sys/class/gpio/gpio84/value
- Disable the GPIO - 0V
echo "0" > /sys/class/gpio/gpio84/value
Example userspace c++ command and library¶
Building libdaq example applications libraries
The gpio and gpiosingle binaries allow testing/controlling gpios from the command line by handling the above sysfs steps. These classes can also be used as libraries in your c++ application to make it easier to control gpio.
Example, assume we have a blue led connected to GPIO1_13:
#include "gpiosingle.h"
const int GPIO_LED_BLUE = GPIO_TO_PIN(1, 13);
void main() {
tcGpioSingle ledBlue(GPIO_LED_BLUE);
int ledOn = 0;
ledBlue.setDirection(1, ledOn); // Output Low
while (true) {
ledOn = !ledOn;
ledBlue.setValue(ledOn);
