MMC/SD Card and USB Throughput
Testing was performed on a 3354-HX-X38-RC module in a devkit rev. 3A, running the filesystem from the mitysom-335x-devkit-MDK-2017-03-06.sh Yocto based MDK.
The real speeds were calculated by dividing the amount of data transferred by the real time taken for the transfer as reported by the time command.
Conclusions:
Write Speed
Memory Device Data Transferred Real Time Taken Real Speed = Real Time / Data Transferred
Card 1 671 MB 98.751 s 6.79 MB/s
Card 2 671 MB 233.585 s 2.87 MB/s
Card 3 671 MB 530.657 s 1.26 MB/s
USB 1 671 MB 146.429 s 4.58 MB/s
USB 2 671 MB 78.453 s 8.55 MB/s
Read Speed
Card 1 671 MB 34.039 s 19.68 MB/s
Card 2 671 MB 37.137 s 18.07 MB/s
Card 3 671 MB 51.866 s 12.94 MB/s
USB 1 671 MB 119.528 s 5.61 MB/s
USB 2 671 MB 113.329 s 5.92 MB/s
This test evaluated writing to, and reading from, a file in an 'ext3' partition of a SD card. The USB drives used were formatted in FAT32. The following memory devices were used for the test:
  • Card 1 -- Class 10 Sandisk micro SD card in a Kingston Adapter
  • Card 2 -- Class 4 Verbatim full size SD card
  • Card 3 -- Class 4 Kingston micro SD card in a Kingston Adapter
  • USB 1 -- Verbatim 4GB flash drive
  • USB 2 -- Patriot Memory 8GB flash drive
Note that the use of the command "dd if=/dev/zero of=/run/media/mmcblk0p3/outfile bs=64k count=10240 conv=fdatasync" was considered, however it was determined that the output of this command was equivalent to the amount of data transferred (671 MB) divided by the real time taken for the transfer as reported by the time command. T
h4. Write Speed Tests
Card 1
root@mitysom-335x:~# time sh -c "dd if=/dev/zero of=/run/media/mmcblk0p3/outfile bs=64k count=10240 && sync"
10240+0 records in
10240+0 records out
671088640 bytes (671 MB) copied, 95.5386 s, 7.0 MB/s
real    1m38.751s
user    0m0.130s
sys     0m14.290s
Card 2
10240+0 records in
10240+0 records out
671088640 bytes (671 MB) copied, 219.389 s, 3.1 MB/s
real    3m53.585s
user    0m0.040s
sys     0m13.820s
Card 3
10240+0 records in
10240+0 records out
671088640 bytes (671 MB) copied, 494.305 s, 1.4 MB/s
real    8m50.657s
user    0m0.080s
sys     0m14.650s
USB 1 -- Using Card 1 as the boot device
root@mitysom-335x:~# time sh -c "dd if=/dev/zero of=/run/media/sda1/outfile bs=64k count=10240 && sync"
10240+0 records in
10240+0 records out
671088640 bytes (671 MB) copied, 124.768 s, 5.4 MB/s
real    2m26.429s
user    0m0.110s
sys     0m18.400s
USB 2 -- Using Card 1 as the boot device
10240+0 records in
10240+0 records out
671088640 bytes (671 MB) copied, 67.6266 s, 9.9 MB/s
real    1m18.453s
user    0m0.170s
sys     0m20.010s
Read Speed Tests
Card 1
root@mitysom-335x:~# time sh -c "dd of=/dev/null if=/run/media/mmcblk0p3/outfile bs=64k count=10240 && sync"
10240+0 records in
10240+0 records out
671088640 bytes (671 MB) copied, 33.9662 s, 19.8 MB/s
real    0m34.039s
user    0m0.120s
sys     0m8.180s
Card 2
10240+0 records in
10240+0 records out
671088640 bytes (671 MB) copied, 37.0589 s, 18.1 MB/s
real    0m37.137s
user    0m0.200s
sys     0m7.880s
Card 3
10240+0 records in
10240+0 records out
671088640 bytes (671 MB) copied, 48.0956 s, 14.0 MB/s
real    0m51.886s
user    0m0.130s
sys     0m7.910s
root@mitysom-335x:~# time sh -c "dd of=/dev/null if=/run/media/sda1/outfile bs=64k count=10240 && sync"
10240+0 records in
10240+0 records out
671088640 bytes (671 MB) copied, 119.45 s, 5.6 MB/s
real    1m59.528s
user    0m0.100s
sys     0m7.400s
10240+0 records in
10240+0 records out
671088640 bytes (671 MB) copied, 113.25 s, 5.9 MB/s
real    1m53.329s
user    0m0.090s
sys     0m7.420s
Other
Throughput testing was performed to determine loading speeds from both the MMC/SD to RAM.
MMC/SD Card to RAM - UBoot
9588 KBytes/sec Average
ERASE RAM: mw.b 0x82000000 0xff 0x5000000
MMC LOAD: fatload mmc 0:1 82000000 root.jffs2
MMC/SD Card to RAM - Linux
TBD
