UBIFS Nand Boot
Description of UBIFS
http://tree.celinuxforum.org/CelfPubWiki/KoreaTechJamboree5_kor?action=AttachFile&do=get&target=CELF_KJ5th_UBI.ppt
TI has instructions on creating and flashing a UBIFS image. Please read these instructions as this page will reference them were ever possible.
source: http://processors.wiki.ti.com/index.php/UBIFS_Support
Reference: TIs AM335x ARM Cortex-A8 Microprocessors (MPUs) Technical Reference Manual (Rev. H) Table 26-7: SYSBOOT Configuration Pins http://www.ti.com/product/am3359
Important
Kernel Notes
It is recommended to use the latest critical link 3.2 kernel when using nand. The 3.1 kernel was found to be susceptible to power loss corruption in the ubifs filesystem. mityarm-linux-3.2
For the 4.4 kernels and newer use device tree overlays to configure the correct nand. When booting from a fitimage, u-boot selects the correct overlay.
If you are using kernel 4.4+, make sure fitImage's size is less than the NAND space designated for the kernel (via menuconfig subtraction of interfaces), 5MB.
Testing ECC bitflip correction
UBoot/MLO Version Notes
It is recommended that the version of UBoot be U-Boot 2013.10-g6c6a700 (Nov 20 2013 - 16:56:02) or newer. These files can be found from the following wiki (https://support.criticallink.com/redmine/projects/armc8-platforms/wiki/Creating_an_SD_Card) page.
Ubuntu packages
$ sudo apt-get install mtd-utils
Boot Config Pins
NOTE: When switching boot pins, you need to cycle power for changes to be detected. Hitting the reset button will not work.
  • To boot from Nand: Pins 2,3,8,9,10,11
    BOOTCONFIG [0..11]
  • To boot from MMC: Pins 3 Note: Pins 8-11 can be on or off
    BOOTCONFIG [0..11]
Choose the following wiki page based on your modules nand size, for valid partition and commands
256MB NAND UBIFS Nand Boot
512MB NAND UBIFS Nand Boot
1GB NAND UBIFS Nand Boot
Saving uImage on ubifs partition
http://support.criticallink.com/redmine/boards/28/topics/2893?r=3199#message-3199
Pros: Give ubifs more space for wear leveling and bad block handling.
Cons: Slows down boot time.
TODO: Create guide using instructions from forum post.
