Command Console¶
The command console can be found under Controls -> Command Console
Sensor registers¶
The sensor registers can be viewed and changed with the PEEK/POKE commands.
PEEK ---- PEEK - Used to read a sensor register. PEEK <address> POKE ---- POKE - Used to write a sensor register. POKE <address> <value>
Note: Both address and value can be specified in base 10 or in base 16 if proceeded by 0x.
Example:
PEEK 16 PEEK 0x10 POKE 0x10 10 POKE 0x10 0xA
Command scripting¶
A series of commands can be run by creating a script text file. The file should be a list of commands to run separated by newline.
To run the script, go to GenICam -> Run script. And navigate to the script file you created.
