GenTL Software Package Release Notes
This page covers release notes for the GenTL Viewer and GenTL provider libraries.
Install Package 2.9.1 (2023-12-20)
GenTL provider changes
  • Fixed bug in GenTL DLL related to GigE Protocol Port Access in multi-threaded environment.
GenTL Viewer Application changes
  • None
Install Package 2.9.0 (2023-10-06)
  • Add simulation support for 10 Bit Monochrome pixel data
  • Added support for fetching GigE Timestamps and scaling based on GIGE Frequency tick counter
  • Updated logic for computing framerate when using GigE with valid timestamps.
  • Added support for cameras presenting multiple ROIS per GenICam SFNC configuration.
  • Added support for Mono10p pixel format
  • Added additional commands for scripting engine
  • Added ROI presets feature
  • Misc GUI related bug fixes.
Install Package 2.8.0 (2023-07-11)
  • Fix libusb transfers closing and cleanup. Improves application shutdown and removes a crash that occurred over 10% of the time.
  • None
Install Package 2.7.3 (2022-11-18)
  • None
  • Added SSL dll files to fix "Check for updates" help menu item being disabled.
Install Package 2.7.2 (2022-11-14)
  • Add support for BUFFER_INFO_CONTAINS_CHUNKDATA: Return false to indicate we aren't sending chunk data
  • None
Install Package 2.7.1 (2022-11-13)
  • Corrected XML in GenTL.dll local (vs. device) representation
  • supports python/harvesters as of build date
  • Present GenICam Enumerations in same order as defined in reference XML
  • Added compile time option to enable/disable updater
  • Misc cleanup of tab control on video widget.
Install Package 2.7.0 (2022-07-19)
  • Add support for BUFFER_INFO_TLTYPE
  • tcBuffer::GetInfo: Handle case where consumer passes null pBuffer to get size of buffer to allocate
  • GIGE: Append camera IP Address to DEVICE_INFO_DISPLAYNAME
  • GIGE: Release CCP register in port destructor
  • GIGE: Set recv buffer size to 256k for stream socket
  • GIGE: Don't exit heartbeat thread on error
  • U3V: No longer delete list of devices when interface is closed so we can better set &changed when device list is fetched
  • U3V: Add reference counting to open/close interface calls so USB interface isn't closed until all open calls have been closed
  • Fix mono dng images so they pass dng_validate
  • settings: Fix GenTL tab getting marked dirty on load
  • open dialog: Properly refresh device list when cameras are removed
  • open dialog: Fix invalid ID error for U3V cameras
  • open dialog: Show DEVICE_INFO_DISPLAYNAME as tooltip if available
  • mainwindow: Show DEVICE_INFO_DISPLAYNAME in title if available
  • about: Show which GenTL DLL/CTI path
Install Package 2.6.7 (2022-06-01)
Known issue: Breaks U3V connections, installer has been removed until its fixed
  • Make Buffer Queues Thread Safe
  • Improve device polling
  • Support Retrieving Interface Displayname and Type
  • GIGE: Add code block to disable polling on network interfaces not supporting GigE
  • GIGE: Keep discovery socket resources and Device List after Close()
  • mainwindow: Add indicator for camera errors
  • aqcWorker: Allow line arrays buffer height to be greater than sensor size
  • Cap sx/sy scaling factor at 8 (somewhat arbitrary) to prevent scaling line images to ridiculous sizes
  • Add more descriptive error message when XML cannot be parsed
  • Add support for QImage::Format_RGB32
  • GenTL Settings Dialog: Add Interface Enables / Timeouts Config
  • Rework scanning logic for refreshing available interface / devices.
  • Increase the poll rate a bit.
Install Package 2.6.6 (2022-05-12)
  • GigE: Back off the number of working buffers in the GEV Datastream logic
  • Installer: Opens firewall for GigE cameras
Install Package 2.6.5 (2022-04-27)
  • GigE: Implement the GCGetPortInfo for the GEV interface port object.
  • None
Install Package 2.6.4 (2022-04-20)
  • GigE: Update GigE Data Stream protocol to correct bug in packet resend request logic.
  • GigE: Corrected bug in decoding of 16 bit vs 64 bit block IDs.
  • GigE: Add packet size discover capability (attempts 9000, 4500, 4000, 3800, 1500, 1400, and 1024 packet sizes).
  • GigE: General Datastream throughput improvements
  • GigE: Dump packets received that aren't from the connected camera IP address.
  • Honor the GenTL Producer Datastream STREAM_INFO_BUF_ANNOUNCE_MIN parameter, if provided.
Install Package 2.6.3 (2022-04-07)
  • None
  • Fix issue with Bayer packed formats where they all were being debayered as RG
Install Package 2.6.2 (2022-03-25)
  • Fix Bug in GigE discovery logic that might cause an application crash.
  • None
Install Package 2.6.1 (2022-03-21)
  • None
  • Fix xml cache dir on first install (Fixes View XML button greyed out)
Install Package 2.6.0 (2022-03-21)
  • Add support for GigE ethernet cameras
    • When looking for cameras, the local network will be scanned with broadcast packets
  • Honor polling timeout for discovering cameras
  • Support Calling IFOpenDevice immediately after calling TLOpenInterface
  • Fixup broken iteration in UpdateDeviceList
  • U3V: Limit readback request sizes to honor Max Ack Transfer Length
  • U3V: Limit command write sizes to honor Max Cmd Transfer Length
  • U3V: Ensure we limit usb transfer size to within the max Windows usb transfer size
  • U3V: Fix txbuf buffer size allocation
  • U3V: Bug: Increment address when breaking write into multiple usb transfers
  • DeviceDialog: Only search for cameras when Open Device Dialog is visible
  • Try fetching GenICAM payload value if GenTL cannot provide it
  • DeviceDialog: Improve GUI lag when Open Device Dialog is visible
  • DeviceDialog: Disallow selecting interfaces "categories" in the device dialog
Install Package 2.5.1 (2022-02-17)
  • None
  • recorder: Fix issue where "Save one frame" was defaulting to Program Files directory
  • recorder: Fix issue where "Save one frame" was updating the file prefix for the regular recorder
  • Ensure GenICam based widgets are initialized in the correct order
Install Package 2.5.0 (2022-01-17)
  • None
  • plotter: Implement StdDev By Row/Column
  • plotter: Remove row/column control for Mean and StdDev ImageStats
  • plotter: Update plot stats when enabled or source is changed
  • plotter: Use full name for plot types that don't have an index
  • plotter: Trigger plot refresh when new temp data is added
Install Package 2.4.5 (2021-12-08)
  • simcamera: Improved fps accuracy. Uses Windows timeBeginPeriod to set scheduler time to 1ms while simcamera is acquiring
  • simcamera: Allow changing fps during acquisition
  • simcamera: Increase frame gen performance
  • BAE: Add Core module support
  • BAE: Improve performance for ISelector nodes
  • Handle some GenApi exceptions causing GUI crash
Install Package 2.4.4 (2021-09-29)
  • u3v: Populate BUFFER_INFO_SIZE_FILLED for each buffer so we can determine how many bytes were actually written to the buffer
  • Add Bayer 10/14/16 pixel formats
  • BAE: Update ROI presets to 1440x1100
Install Package 2.4.2 (2021-08-09)
  • None
  • BAE: Add recommended ROI presets
Install Package 2.4.0 (2021-08-04)
  • Various debug print statement changes
  • Changes to support new cameras
  • simcamera: Improve debug log ring buffer
  • Add Dark theme, auto-enabled if Windows 10 "AppsUseLightTheme = 0" is set picture521-1.png
  • Dark mode setting added to explicitly set light/dark theme
  • recorder: Add record mode options to the recorder. Allows syncing record start/stop with camera acquisition
  • recorder: Minimize recorder controls when the camera is closed
  • recorder: Add frame and pixelformat info to saved filenames. A new setting was added to disable this feature. Defaults to add extra info.
  • recorder: Allow saving raw camera data to raw file formats. A new setting to control if raw data or image data (as shown in UI) is saved. Defaults to using raw camera data, Breaking Change
Install Package 2.3.0 (2021-06-21)
  • simcamera: Add support for mono14/12/10 pixel formats
  • simcamera: Reduce code duplication in noise text pattern
  • camera settings: Ensure IIntegers, IFloats, IEnumerations are read-only when GenICam says so
  • Add support for pixel formats mono14/12/10
  • Prevent 0ms frame timeouts to avoid 100% cpu usage when at high framerate
  • AqcWorker: Check for DSStartAcquisition errors and stop frame acq on errors
  • recorder: Set recorder controls to always on top
  • mainwindow: Check plugin for toolbarActions
  • mainwindow: Show controls if they are minimized
  • recorder: Add record button to toolbar
  • recorder: Set recorder controls to always on top (window can still be minimized or closed)
Install Package 2.2.0 (2021-05-04)
  • None
  • command console: Add minimize/maximize to console window
  • video widget: Fix off by one error with pixel value picker
  • ROI: ROI rect selector stops acquisition before changing ROI
  • recorder: User can limit the number of frames recorded
  • recorder: Captured frames will start the count at 1 and no longer use frame id
  • recorder: Captured frames will by default be put in a timestamped subdirectory (configurable in settings)
  • recorder: FLF image format added
  • recorder: Populate recorder control file formats
  • recorder: Remove frame number from camera_regs.ini
  • recorder: Stop acquiring before dumping registers
  • recorder: Setup recorder control so it auto sizes itself when shown
  • geni command: Add additional register save, progress checkpoints
  • geni command: Make progress window modal to block user input
  • geni command: Allow canceling register save
  • Camera Settings: Support enumerating ISelector nodes in tree (can be disabled in settings)
  • mainwindow: Ensure GenICam menu options are disabled when no camera is loaded
  • mainwindows: Clear fps when camera is closed
  • mainwidget: Show videowidget cursor info in status bar
Install Package 2.1.1 (2021-03-03)
  • None
  • BAE: Rework look
  • BAE: Update Gaussian controls
  • BAE: Add controls for sensor binning and CFPN
  • Add REGWAIT command
  • mainwindow: Show error if XML load from camera fails
Install Package 2.1.0 (2021-02-22)
  • Sim Camera updates
  • Add spinner when opening/closing camera
  • settings: Autodetecting gentl and plugins paths
  • Introduce Sensor Register Editing Tool
  • Introduce bae plugin
  • Introduce Simple scaling control, like MityViewer, to globally enhance contrast
  • Push camera debug buffer onto the standard Log window periodically
  • Add option to recorder to save cam registers when recording stops
  • settings: On start, load default_gentle.ini if settings are empty
  • plotter: Add min/max to tools tab
  • plotter: Support plotting average across rows or average across columns
  • Add Save/Load Camera Registers action to GenICam menu
  • Show <Representation> = HexNumber as base 16
  • mainwindow: Ensure window title is consistently set
  • mainwindow: Fix case where camera doesn't load but we open video window anyways
Install Package 2.0.0 (2020-10-27)
  • Update to GenICam API 3.2.0
  • Include sim_camera.xml in install directory
  • Update to build using VS2019
  • Update to opencv 4.5.0
  • Update libusb
  • Add IR plugin support for Canon 35MMFHDXS
Install Package 1.8.1 (2020-07-29)
  • None
  • Introduce basic plugin for sequenced snapshots
  • Add option to restart the application when plugins are changed
  • Add option to restart the application from menu
  • Fix videosettings ComboBox not updating properly
  • Add 35MMFHDXS to compatible model list for IR plugin
Install Package 1.7.0 (2020-05-29)
  • None
  • Clamp IFloat to fix issue with double spinboxes min/max rounding
  • CMV50K/CSG14K: Add support for CSG14K in plugin. Add sensor details...
  • videosettings: Setup ROI presets using CSG14K and CMV50k sensor details
  • camerainterface: Clear TLParamsLocked and mpCurrentFrame after aquiring event becomes false
  • camerainterface: Ensure we set TLParamsLocked after various error cases, and...
  • videosettings: Update play/pause and camera aquiring handling
  • Cleanup various unused methods and variables
  • Introduce simple voltage/temperature tabular display widget
  • Properly configured Datastream capture for MultiFrame and Single frame data.
Install Package 1.6.0 (2020-04-07)
  • None
  • Add control to sync HDMI Gamma and White Balance terms for cameras supporting HDMI outputs.
  • Misc bug-fixes in ROI handling.
  • Added support for internal test fixture framework.
Install Package 1.5.0 (2020-02-25)
  • None
  • Fixed default recording dir settings
  • Change exposure time to microseconds to match GenTL register.
  • recorder: Handle saving images using multiple threads. Allows multiple images to be compressed/encoded simultaneously. Improves framerate when recorder is active.
  • Speedup 12bit to 16bit unpack algorithm
  • Don't subtract IR if any of the pixels are saturated. Fixes scenes with overexposed spots with an IR camera.
Known issues
  • Application crashes if camera physically disconnected while application is using it.
  • ROI rectangle selection is incorrect if an ROI is already set
Installer Package 1.4.1 (2020-01-28)
  • None
  • Fix reported version
Known issues
Installer Package 1.4.0 (2020-01-27)
  • Add grid test pattern to simulated camera
  • Add menu entries for user manual and release notes.
  • Update application icon
  • Add additional display filter to support Mirroring in X/Y on PC side.
  • Add (optional) Zoom Navigation overlay to Display View.
  • Scroll zoom updates
    • Don't support zooming out beyond "full image"
    • Allow zooming down to 0.01 size to support larger sensors
    • Save / restore click-and-drag zoom operation button when not scroll zooming
  • Fix access error when saving plot data with unequal length plot vectors.
  • Save State of Zoom Navigation, Pixel Interpolation Mode, and 1:1 checkbox.
  • Fix up panning logic and properly display pixel coordinates when zoomed.
  • Add ROI image rectangle selection to video settings plugin, so you can drag a rectangle to set ROI
  • Add ROI preset combo box
  • Disable ROI buttons when camera is acquiring
Known issues
Installer Package 1.3.0 (2019-12-04)
  • Internal updates
  • Fix memory leak
  • Reset zoom when image size changes
  • Updates to installer to provide smoother update installation
  • Update to IR plugin to subtract IR value from RGB pixels
Known issues
Installer Package 1.2.0 (2019-10-14)
  • Simulated camera updates for testing
  • Improve error handling in XML parser
  • Corrected PNG data format for high bit depth images.
  • Add support for monochrome images to DNG export.
  • Add support for Canon IR pixel format
  • Add White Balance control to UI
  • Minor user interface fixes
Known issues
Installer Package 1.1.2 (2019-08-05)
  • Advanced libusb to include changes from 1.0.22 release. Needed to support very large image transfer.
  • Updated histogram to support plotting 2^N bins for a given color bit-depth
  • Updated histogram to center pins properly when plotting
  • Fixed misc issues around exception handling for exceptions thrown by GenICAM
Installer Package 1.1.1 (2019-01-11)
  • Fix misc bugs encountered with data streaming.
  • Add XML / Port accessors for interface and system modules in the GenTL layer.
  • Simulated camera support added with bug fixes.
  • Handle proper model numbering for plugin matching with CMV and CSG based cameras.
Installer Package 1.1.0 (2018-11-12)
  • Several fixes made to support utilizing python harvester bindings.
  • Fixed Error in Revoke Buffer method when buffer was allocated by external application (vs. with the Library).
  • Return GC_ERR_NOT_IMPLEMENTED for GetPortURL related methods for non-Port Handles vs. unexpected behavior.
  • Fixed some system handle GetInfo() routines returning strings to include null termination character in returned string and size calculation.
  • Added support for digital raw negative file format for saving images.
Installer Package 1.0.0
Installer Package 0.9.0
Installer Package 0.8.0
