Building FPGA 23.1¶
- Building FPGA 23.1
Overview¶
The provided FPGA images are given as a reference to how the FPGA can be used in unison with the HPS. The FPGA design heavily uses Qsys for connecting functional blocks together and contains the following Qsys blocks:- sysid_qsys - System ID Peripheral - This basic block stores a 32 Bit system ID and the date the FPGA was built that can be read from the HPS.
- hsmc_out_0 - PIO - This is a parallel I/O block that is connected to part of the full HSMC Connector.
- hsmc_out_1 - PIO - This is a parallel I/O block that is connected to part of the full HSMC Connector.
- hsmc_in_0 - PIO - This is a parallel I/O block that is connected to part of the full HSMC Connector.
- hsmc_in_1 - PIO - This is a parallel I/O block that is connected to part of the full HSMC Connector.
- fpga_ddr - DDR3 SDRAM Controller with UniPHY - This is the DDR controller for the DDR RAM that is attached to the FPGA, in the example it is then routed to the HPS so the HPS can access it from the HPS-to-FPGA AXI Bridge.
- clk_100Mhz - Clock Source - Allows for inputting the CLK2DDR signal into the Qsys.
- mm_clock_crossing_bridge - Avalon-MM Clock Crossing Bridge - Lets the HPS-to-FPGA bridge, running at 100Mhz, talk to the FPGA DDR Controller, running at 150Mhz.
The project also uses the Altera Source and Probe block for controlling signals on the partial HSMC connector for debug purposes. More information can be found at http://www.altera.com/literature/hb/qts/qts_qii53021.pdf.
Introduction¶
The reference project to the MitySOM-5CSx Development Kit utilizes GNU make for building the FPGA from the command line. Please note that the project can be built using the normal flow of Quartus/Platform Designer if that is desired.
These instructions have been tested with Quartus Prime 23.1
Tested host machine: Ubuntu 22.04.3
Repository¶
| Description | Repository | Branch | Web Viewer |
| Quartus Reference Project | https://support.criticallink.com/git/mitysom-5csx-ref.git | 23.1-stable | gitweb |
Checking out the repo¶
The reference projects are on Critical Link's git server, run the following command to clone the repo:
git clone https://support.criticallink.com/git/mitysom-5csx-ref.git -b 23.1-stable
Repository Structure¶
├── dev_5cse_h4_3ya [MitySOM 5CSE-H4-3YA Reference Project]
├── dev_5cse_h4_8ya [MitySOM 5CSE-H4-83YA Reference Project]
├── dev_5cse_l2_3y8 [MitySOM 5CSE-L2-3Y8 Reference Project]
├── dev_5csx_h5_4ya [MitySOM 5CSX-H5-4YA Reference Project]
├── dev_5csx_h6_42a [MitySOM 5CSX-H6-42A Reference Project]
├── dev_5csx_h6_42a_pcie [MitySOM 5CSX-H6-42A PCIe Reference Project]
├── dev_5csx_h6_4ya [MitySOM 5CSX-H6-4YA Reference Project]
├── dev_5csx_h6_53b [MitySOM 5CSX-H6-53B Reference Project]
└── README.md
Development Kit Pre-built Outputs¶
| Models | SD Card Image | FPGA/Bootloaders Binaries |
| 5CSE-H4-3YA | 5CSE-H4-3YA SD Card | 5CSE-H4-3YA Binaries |
| 5CSE-H4-8YA | 5CSE-H4-8YA SD Card | 5CSE-H4-8YA Binaries |
| 5CSE-L2-3Y8 | 5CSE-L2-3Y8 SD Card | 5CSE-L2-3Y8 Binaries |
| 5CSX-H5-4YA | 5CSX-H5-4YA SD Card | 5CSX-H5-4YA Binaries |
| 5CSX-H6-42A | 5CSX-H6-42A SD Card | 5CSX-H6-42A Binaries |
| 5CSX-H6-4YA | 5CSX-H6-4YA SD Card | 5CSX-H6-4YA Binaries |
| 5CSX-H6-53B | 5CSX-H6-53B SD Card | 5CSX-H6-53B Binaries |
Quick steps to Build¶
- Launch the Nios II Command Shell.
Linux/opt/intelFPGA/23.1/nios2eds/nios2_command_shell.sh
WindowsC:\intelfpga\23.1std\nios2eds\Nios II Command Shell.bat
- Change into the directory where project was cloned into (Example: /home/user/mitysom-5csx)
cd /home/user/mitysom-5csx
- Run the following command that will do the following: 1. Generate the qsys, 2. Compile the FPGA, 3. Convert the SOF to an RBF
make rbf
Updating the Pinout¶
Opening Platform Designer and Quartus¶
The Makefile can also be used open Quartus or Platform designer.
Opening Quartus:
- Open a terminal
- Enter the following command that will allow you to use the quartus tools from the command line:
- Open the current project with Quartus with the Makefile
make quartus_edit
Opening Platform Designer:
- Open a terminal
- Open the current project's top level qsys with Platform Designer with the Makefile
make qsys_edit
