Building the FPGA project and Bootloader with Quartus Pro 24.1
Introduction
The reference project for the MitySBC-Agilex5 requires the Quartus Pro 24.1 tools installed and in your path.
Description Repository Branch
Quartus Example Projects git://support.criticallink.com/home/git/mitysbc-a5-ref.git pro_24.1_stable
Quick steps to build
Clone the repository
git clone -b pro_24.1_stable git://support.criticallink.com/home/git/mitysbc-a5-ref.git
Navigate into the root of the Quartus project
cd mitysbc-a5-ref/base_project
Generate the project
The project is set up to be customizable from TCL. To generate the default configuration run the following:
make generate_from_tcl
Build the FPGA project and Bootloader
make jic
This will result in output_files/base_project_hps.jic. The JIC file contains the FPGA design and the preloader which is programming into the QSPI NOR.
Program the QSPI NOR with the FPGA design / Preloader
quartus_pgm -m jtag -o "ip;output_files/base_project_hps.jic@2"
Bootloader
Bootloader Environment
make uboot_script
The compiled output script will be in software/boot.scr
