Prerequisites For Quartus Pro 25.3.1
Needed tools
Building the FPGA
Building the bootloader, filesystem, and SD card
  • Ubuntu 22.04 LTS
  • Additional Packges
    sudo apt install bison flex python3-setuptools swig gawk wget git diffstat unzip texinfo gcc build-essential chrpath \
    socat cpio python3 python3-pip python3-pexpect xz-utils debianutils iputils-ping python3-git python3-jinja2 libegl1-mesa \
    libsdl1.2-dev pylint python3-subunit mesa-common-dev zstd liblz4-tool libssl-dev libncurses5-dev gcc-multilib \
    curl bc subversion strace ltrace tig fonts-hack-ttf locales libncurses5-dev libncursesw5-dev
  • GCC-ARM-11.2
    wget https://developer.arm.com/-/media/Files/downloads/gnu/11.2-2022.02/binrel/gcc-arm-11.2-2022.02-x86_64-aarch64-none-linux-gnu.tar.xz
    tar xf gcc-arm-11.2-2022.02-x86_64-aarch64-none-linux-gnu.tar.xz
    rm -f gcc-arm-11.2-2022.02-x86_64-aarch64-none-linux-gnu.tar.xz
    export PATH=`pwd`/gcc-arm-11.2-2022.02-x86_64-aarch64-none-linux-gnu/bin:$PATH
    export ARCH=arm64
    export CROSS_COMPILE=aarch64-none-linux-gnu-
  • OPTIONAL GCC-ARM-10.2 -- only required for older generation processors
    wget https://protection.greathorn.com/services/v2/lookupUrl/e752f176-fc6a-453b-8b33-4aef67a3fcfc/1566/a6928e7ffe2d16bc27ec5b1e9b18ebf110e8b59f?domain=developer.arm.com&path=/-/media/Files/downloads/gnu-a/10.2-2020.11/binrel/gcc-arm-10.2-2020.11-x86_64-aarch64-none-linux-gnu.tar.xz
    tar -xzf gcc-arm-10.2-2020.11-x86_64-aarch64-none-linux-gnu.tar.xz
    # only do these steps if you cannot build with GCC-ARM-11.2
    #export PATH=`pwd`/gcc-arm-11.2-2022.02-x86_64-aarch64-none-linux-gnu/bin:$PATH
    #export ARCH=arm64
    #export CROSS_COMPILE=aarch64-none-linux-gnu-
