SFP Fabric Intel Ethernet GTS Example¶
Overview¶
This design enables the Intel Ethernet GTS IP in the sfp_fabric_subsys and brings a single 10G serial lane out to the SFP1 cage. The Intel Ethernet GTS example source files used by this design come from $QUARTUS_ROOTDIR/../ip/altera/ethernet/intel_eth_gts/example_project/common. In the generated system, the GTS IP is instantiated as intel_eth_gts_0 and the example packet source/sink is instantiated as intel_eth_gts_packet_client_0. The serial TX/RX pins from intel_eth_gts_0 connect directly to SFP1_TX_P/N and SFP1_RX_P/N.
The data path is intentionally set up for external loopback. Packets return only when the SFP path is looped externally through the module/media. The packet client is the traffic source and sink for this example: it generates packets on the TX side, hands them to the GTS IP, and then counts the packets that return on the RX side after the external loopback path.
| intel_eth_gts_packet_client_0 |
| packet generator |
| packet counters |
| Avalon-ST TX/RX
v
| intel_eth_gts_0|
| serial TX/RX
v
| SFP1 |
| cage |
external loopback
Building the FPGA SFP Fabric Example¶
Refer to Building_fpga_2531pro for building the FPGA design. Navigate into the mitysom-a5e[-mini]-ref-sfp-fabric example project before compiling the design.
- Ensure to flash the resulting a5e.hps.jic onto the hardware
- Ensure to replace the a5e.core.rbf on the SD card
Exercising the Example¶
The packet client control register is accessed over the lightweight bridge at address 0x30000000.
Register Map¶
The packet counters are 64-bit values split into low/high 32-bit words.
| Absolute Address | Offset | Register | Access | Description |
0x30000000 |
0x0000 |
Packet client control | RW | Bit 0 = start packet generation, bit 2 = continuous mode, bit 4 = select RX loopback path into TX when set, bit 6 = snapshot counters, bit 7 = clear shadow counters, bit 8 = clear TX/RX counters (self-clearing). |
0x30000004 |
0x0004 |
Test loop count | RW | Packet-generator loop count. |
0x30000008 |
0x0008 |
ROM start/end address | RW | Low field = ROM start address, upper field = ROM end address. |
0x3000000C |
0x000C |
Packet client status | R | Bit 0 = loopback FIFO write-full error, bit 1 = loopback FIFO read-empty error. |
0x30000010 |
0x0010 |
Latency count | RW | Read returns the measured latency count in bits [7:0]; bit 31 is used to trigger a latency measurement. |
0x30000014 |
0x0014 |
Custom destination address low | RW | Lower 32 bits of the packet-generator destination-address field. |
0x30000018 |
0x0018 |
Custom destination address high | RW | Upper destination-address bits in [16:0]. |
0x3000001C |
0x001C |
Packet gap | RW | Packet-gap setting for the ROM-based packet generator. |
0x30000020 |
0x0020 |
TX SOP count low | R | Low 32 bits of transmitted start-of-packet count. |
0x30000024 |
0x0024 |
TX SOP count high | R | High 32 bits of transmitted start-of-packet count. |
0x30000028 |
0x0028 |
TX EOP count low | R | Low 32 bits of transmitted end-of-packet count. One EOP corresponds to one transmitted packet. |
0x3000002C |
0x002C |
TX EOP count high | R | High 32 bits of transmitted end-of-packet count. |
0x30000030 |
0x0030 |
TX error count low | R | Low 32 bits of transmitted error count. |
0x30000034 |
0x0034 |
TX error count high | R | High 32 bits of transmitted error count. |
0x30000038 |
0x0038 |
RX SOP count low | R | Low 32 bits of received start-of-packet count. |
0x3000003C |
0x003C |
RX SOP count high | R | High 32 bits of received start-of-packet count. |
0x30000040 |
0x0040 |
RX EOP count low | R | Low 32 bits of received end-of-packet count. One EOP corresponds to one received packet. |
0x30000044 |
0x0044 |
RX EOP count high | R | High 32 bits of received end-of-packet count. |
0x30000048 |
0x0048 |
RX error count low | R | Low 32 bits of received error count. |
0x3000004C |
0x004C |
RX error count high | R | High 32 bits of received error count. |
0x30900000 |
0x00900000 |
Clock status PIO | R | See bit definitions below. |
0x30900010 |
0x00900010 |
Reset status PIO | R | See bit definitions below. |
0x30900020 |
0x00900020 |
Link status PIO | R/W | See bit definitions below. |
0x30900030 |
0x00900030 |
System PLL lock PIO | R | See bit definitions below. |
0x30900040 |
0x00900040 |
SFP input PIO | R | Only for the MitySOM-Mini. See bit definitions below. |
0x30900050 |
0x00900050 |
SFP output PIO | RW | Only for the MitySOM-Mini. See bit definitions below. |
Status PIO Bit Definitions¶
Clock status PIO (0x30900000)¶
| Bit | Name | Description |
| 0 | o_cdr_lock |
RX CDR lock status. |
| 1 | o_tx_pll_locked |
TX PLL lock status. |
| 2 | o_tx_lanes_stable |
TX lane-stability indication. |
| 3 | o_rx_pcs_ready |
RX PCS ready indication. |
Reset status PIO (0x30900010)¶
| 0 | o_rst_ack_n |
Active-low overall reset acknowledge from the GTS reset logic. |
| 1 | o_tx_rst_ack_n |
Active-low TX reset acknowledge from the GTS reset logic. |
| 2 | o_rx_rst_ack_n |
Active-low RX reset acknowledge from the GTS reset logic. |
Link status PIO (0x30900020)¶
| 0 | o_rx_block_lock |
RX block lock indication. |
| 1 | o_local_fault_status |
Local fault indication. |
| 2 | o_remote_fault_status |
Remote fault indication. |
| 3 | i_stats_snapshot |
Software-controlled snapshot bit driven from the PIO toward the GTS status interface. |
| 4 | o_rx_hi_ber |
RX high-BER indication. |
| 5 | o_rx_pcs_fully_aligned |
RX PCS fully aligned indication. |
System PLL lock PIO (0x30900030)¶
| 0 | o_sys_pll_locked |
System PLL lock indication. |
SFP input PIO (0x30900040, only for the MitySOM-Mini)¶
| 0 | SFP1_TX_FLT_N |
SFP transmitter fault input. |
| 1 | SFP1_MOD_PRSNT_N |
SFP module-present input. |
| 2 | SFP1_LOS |
SFP loss-of-signal input. |
For the MitySOM, these values can be read from the PCAL6416A on I2C bus 3 at address 0x20.
SFP output PIO (0x30900050, only for the MitySOM-Mini)¶
| 0 | SFP1_TX_DIS |
SFP transmitter-disable output. |
| 1 | SFP1_RS0 |
SFP rate-select output. |
Hardware Setup¶
This example can be run on either the MitySOM Development Kit or the MitySOM-Mini Development Kit.
It can be exercised using either two development kits connected together or a single development kit with the SFP interface looped back.
- Program a design that includes this SFP fabric example.
- Install the SFP module(s) on
SFP1and create the external TX-to-RX path. For a two-kit setup, connect the two SFP1 interfaces together. For a single-kit setup, use an external loopback onSFP1. - Boot Linux on the HPS so
memtoolcan access the lightweight bridge.
Note: For the MitySOM, the TX Disable line must be configured low for the loopback to work. This can be done by running the following:
i2cset -y 3 0x20 0x06 0xFD i2cset -y 3 0x20 0x02 0xFD
Note: For the MitySOM, the SFP cage must be installed into J5.
Optional Pre-Check¶
Before starting traffic, it is useful to confirm the clocks and link-side status bits are alive:
memtool 0x30900000 1 memtool 0x30900010 1 memtool 0x30900020 1 memtool 0x30900030 1
The reset-status PIO is mainly a debug aid because its bits are active-low acknowledge signals.
Typical signs of a healthy path are:
- Clock status shows the lock/ready bits asserted.
- System PLL lock is asserted.
- Link status shows RX block lock / alignment once the external loopback path is in place.
Start Packet Generation¶
Start the packet generator with:
memtool 0x30000000=5
In this example, 5 means:
- bit 0 = start transmitting packets
- bit 2 = keep running in continuous mode
Verify TX/RX Packet Activity¶
Read the TX/RX packet counters and the TX/RX error counters:
memtool 0x30000028 1 memtool 0x30000030 1 memtool 0x30000040 1 memtool 0x30000048 1
For a full 64-bit snapshot, read the 12 words starting at 0x30000020:
memtool 0x30000020 12
To watch the key TX/RX count and error registers in one read, read the 10 words starting at 0x30000028, wait a moment, and read them again. The packet counters should keep increasing if the example is working and the SFP path is looped back correctly:
memtool 0x30000028 10 sleep 1 memtool 0x30000028 10
Expected behavior:
0x30000028increments as packets are transmitted by the packet client.0x30000040increments as those packets return through the external SFP loopback path.0x30000030and0x30000048should remain at zero during a clean run.- RX should track TX closely in steady state.
If TX counts increase but RX counts stay at zero, the packet generator is running but the serial link is not looping back. In that case, re-check the external loopback path and the status PIO registers at 0x30900000, 0x30900020, and 0x30900030.
Stop Packet Generation¶
To stop the example:
memtool 0x30000000=0
