Building SD Card¶
Prerequisites¶
- Linux PC (Ubuntu 22.04)
- libguestfs-tools
sudo chmod a+r /boot/vmlinuz*
- Filesystem Tarball from Yocto (mitysom-image-base-mity-a5e.rootfs.tar.gz)
- FPGA Design (a5e.core.rbf)
- Bootloader from FPGA build (u-boot.itb)
- Bootloader script from FPGA build (boot.scr)
Make SD script¶
Run this script to generate an SD card image
# Make a rootfs overlay to install the RBF file
mkdir -p rootfs_overlay/usr/lib/firmware
cp output_files/a5e.core.rbf rootfs_overlay/usr/lib/firmware
./make_sd.sh \
-a \
-o sd_card.img \
-d Agilex5 \
-f path/to/u-boot.itb \
-f path/to/boot.scr \
-r rootfs_overlay \
path/to/mitysom-image-base-mity-a5e.rootfs.tar.gz
The following will generate an sd_card.img that can be flashed onto an SD card
Manually updating any binaries on an existing SD card¶
The SD card has two partitions, a FAT partition and an EXT partition.
The EXT partition contains the Linux filesystem which also contains:
- The FPGA design RBF in /lib/firmware.
- The Linux Kernel in /boot
- The Linux device tree in /boot
The FAT partition contains the rest of the binaries:
- The bootloader - u-boot.itb
- The bootloader script - boot.scr
To update any of the binaries, first mount the partition (The FAT partition is the first partition /dev/sdX1 and the EXT partition is the second partition /dev/sdX2):
sudo mount /dev/sdX1 /mnt
The /mnt directory now contains the partition and any of the binaries can now be replaced
When complete, the partition can be unmounted with the following:
sudo umount /dev/sdX1
