Development Board Schematics and Revision Information
Links to the Development Kit board schematics are included below. Board revisions are included in the part number "dash" number. E.g., 80-001748RC-1 would be a "dash one" or first revision of the board.
MitySOM-A5E Mini Development Kit Carrier Board
Board Part Number Link to Schematics / BOM Rework Notes / Known Issues PCN
80-001748RI-2 80-001748RI-2RevA.PDF
80-001748RI-2RevA_BOM.xlsx
1. Updates for Mechanical Changes.
2. USB-C fixes.
3. Misc whitewire corrections.
4. See last sheet for additional information.
N/A
80-001748RI-1 80-001748RI-1RevA_SCH.PDF
80-001748RI-1RevA_BOM.xlsx
1. pullup resistors changed on SD-card level translater to 500 Ohms.
2. U6 Pin 1 disconnected from 1.8V and grounded.
3. +5V Supply Underdesigned (larger current capacity needed)
N/A
MitySOM-A5E Standard Development Kit Carrier Board
Board Part Number Link to Schematics Rework Notes / Known Issues PCN
80-001828RI-1 80-001828RI-1_RevA_SCH.PDF
80-001828RI-1RevA_BOM.xlsx
1. Removed R64
2. Reworked / Swapped I2C1 SCL/SDA on U42 pins 2 and 3
3. Added 0.1" 2 pin header to fan powering
4. FMC_MUX_EN signal should be pulled up, currently floating
5. C322, C323, C324, C325 replaced with 0 Ohm resistors
6. Added pullup resistors on UART lines of U8
N/A
