I2C Board Support Package
Added by John Mladenik about 14 years ago
Our software guy is trying to use your I2C board support to drive the I2C devices we have connected to the OMAP's I2C bis. Is this for the I2C on the OMAP or for the I2C driver in the FPGA? We have our hardware connected to the I2C port on the OMAP and do not have an I2C in our FPGA.
Replies (37)
RE: I2C Board Support Package - Added by Michael Williamson about 14 years ago
Which I2C port are you trying to use, I2C0 or I2C1? If you are trying to use I2C0, then you should be able to use the i2c-tools (i2cset, i2cdump, etc) and direct access to bus 1. If you are using I2C1, then the kernel will need to be modified to disable the UART (2 I believe) and enable the I2C peripheral driver for the port.
root@mityomapl138:~# i2cdump 1 0x37
(the above example would dump I2c device at address 0x37)
If you don't have the commands then do an "opkg install i2c-tools".
RE: I2C Board Support Package - Added by Thomas Catalino about 14 years ago
Hi John -
I believe you are looking at using the I2C driver we provide under the FPGA directory. This driver is indeed used for an FPGA based I2C core and not the I2C provided on the OMAP itself.
See Mike's post about how to get to the I2C driver for the onboard OMAP I2C driver ...
Tom
RE: I2C Board Support Package - Added by John Mladenik about 14 years ago
Mike
We are using the TI I2C tools and our hardware uses I2C0 but we get all X's when doing a dump from the I2C address of one of our devices on the I2C0 bus.
I have not been able to get the TI tool onto my system so I can instrument the hardware to see if the I2C buss is even toggling at all. I get this when I run the install commands:
root@john2:~# opkg upgrade
root@john2:~# opkg install i2c-tools
Collected errors: * opkg_install_cmd: Cannot install package i2c-tools.
I am on a PC and the board is connected to my switch.
John
Ok. Sounds like you have i2cdump, right? What is the device you are using? The address is sometimes non-obvious to pass to the i2c utilities. My guess is that the address field is not what the tools/driver is looking for.
Well our software guy has the i2cdump, I have not been able to get it loaded on m system yet as I indicated in my previous post.
We are trying to talk to the TI Audio chip the TLV320DAC3120 which has an I2C address of 0011 000. The I2C address is a 7 bit address and the LSB bit is the read/write bit to fill in the 8 bit field. The I2Cdump limits the address from 0x3-0x77 so I think that it wants the 7 bit address which makes it 0x18. When doing a dump from 0x18 the software returns all X's.
I want to instrument the I2C bus but I can not get the tools to load on my platform.
Ok I got the I2C tools loaded and working. Out issue is that the SYS_RESET_N ( GP514 )signal that comes from the OMAP is always lowing holding the Audio chip in reset. I connected this to our audio chip only because you connected it to your audio chip. Does your audio driver pull this high?
It seems like you would want this to be pulled high immediately after power-up.
John
If you look in the most recent version of the kernel in the arch/arm/mach-davinci/board-mityomapl138.c, the gpio pin is being asserted and then pulled high in the mityomapl138_set_mcasp() routine.
Look for the text "SYSTEM_RESET" and you should see the pin setup and gpio calls. You will need these calls in your port.
RE: I2C Board Support Package - Added by Dennis Volper about 14 years ago
Tried to patch the changes from that file into the kernel posted under Files on this site. Syntax errors on DA850_GPI05_14 and SYSTEM_RESET. Since I still can't "git" could you post a copy of the "most recent version of the kernel". I'll patch our changes for the LCDC into the new version.
Hi Simon -
The latest version of our kernel is included in the tarball on the BSP wiki page located here:
http://support.criticallink.com/redmine/projects/arm9-platforms/wiki/Board_Support_Package
Tom
Got the new kernel. Compiled and loaded it onto the board. Most things work, but i2cdump seems to have changed. My hardware person (aka John) indicates that his analyzer no longer sees the bus toggle when the dump command is run. /sys/devices/platform/i2c_davinci.1 is there. Any hints on what we've done wrong?
I tried the following experiment. On an Industrial I/O board I replaced the Rev A OMAP card with a fresh out of the package card with a white tag "L138F". Verified the existance of /dev/i2c-1, enabled the network, opkg'd in the i2c-tools, ran "i2cdump 1 0x38" (we dumped this address when working on getting the LCD running). The dump gave me all X's; no timeout messages. Any hints where I should be looking?
RE: I2C Board Support Package - Added by Michael Williamson almost 14 years ago
Hi Dennis,
Which Revision of the Industrial I/O are you using? Rev A Industrial I/O boards have the I2C port of the video hooked through the FPGA, not I2C0 on the OMAP, so you won't get a valid response if you are using a Rev A industrial I/O board.
When u-Boot loads up (on power up or on reset), the I2C0 bus is read to get the factory configuration data (serial number, MAC address, etc.) from a small onboard prom. You can dump this information out in u-boot ("factoryconfig") as well as use the i2c utilities in u-Boot to forcibly probe i2c0 ("i2c probe") to find local addresses attached to the bus (48-57 show up due to the onboard prom and the on-board power controller). You can also use this to query devices on the bus. This might shed some light as to what the i2c0 device thinks it can see (and John can look at the bus lines as well).
If you have success using u-Boot, then at least we know it's a software problem (the kernel). I haven't seen this behavior with any other board sets here, so I'm not entirely sure yet how to trouble shoot it.
RE: I2C Board Support Package - Added by Dennis Volper almost 14 years ago
factoryconfig
               Our (John's board)                I I/O board
Config version     0.0                             1.1
Mac Addr        00:00:00:00:00:00                00:50:c2:BF:84:4D
Serial#            0                             100280
FPGA Type          0                             2 [XC6SUX16]
Part #                                           80-000258RC-1 Rev B
i2c probe
               48, 50,...57                      48,50...57
Looks like we don't have an onboard prom on the board. The MAC our board shows to other systems is 0E:4A:ED:65:F7:F9, which is probably coming out of the chip controller. The old kernel (circa July) John was seeing activity on the bus lines and had determined that the reset line was being held high. I switched to the new kernel because it had the reset stuff in it, but the new kernel shows no activity on any of the i2c lines. Could it be something like pinmux used to be done in the kernel and is now supposed to be done in uboot?
My guess is that the MAC is a random MAC generated by the kernel because all zeros is an illegal MAC (check the kernel messages with `dmesg`, there may be a message about using a random MAC address).
The factory configuration is stored on the MityDSP-L138 part itself (on the I2C PROM). Can you switch the two MityDSP's and see if you can dump out the configuration data on the other MityDSP on the Industrial I/O board? If you can, then something on the other board must be contending either with the I2C lines (driving the low) or with the EPROM address. If the values are still zero, then something more sinister has happened as the factory config PROM would appear to have been corrupted.
For the other board, can you dump the entire uBoot startup text?
Also, for formatting on the forums, if you enclose your output with the pre html tags like:
<pre>
Your Formatted Code here
</pre>
it will look right on the site.
Oh... and as far as the pinmux, the u-Boot should be configuring the pinmux for I2C0. It will always do that as it needs to read the I2C for the factory configuration, so the kernel should not need to mess with the I2C pins for pinmux.
Odd:
              Old card in Our board      New card in IIO board     Retry of New card in our board
Config version  1.1                          1.1                       1.1
MAC addr       00:50:c2:BF:DF:FF          00:50:C2:BF:83:28          00:50:C2:BF:83:28
Serial         100001                     100230                     100230
FPGA           2 [XC6SUX16]               2 [XC6SUX16]               2 [XC6SUX16]
Part #         80-000258RC-1 Rev B        80-000258RC-1 Rev B        80-000258RC-1 Rev B
So I swapped the card's back and forth a couple times. The numbers followed the card (not the board). I clueless as to why I got the first set of numbers, possibly power-cycling to swap the cards around reset something. The i2c probe still shows the same as the first try, no matter what card is in what board. Yes, there was a message about random MAC address in dmesg.
What uboot text do you want dumped. IIO board, our board, new card old card? (If that's the rev # of the card they are both the
same rev, but the connectors on them are quite different.) Do you want the dump just of the few lines before the countdown or do you want a dump of the entire boot sequence until the Linux prompt?
Hello Mr. Volper,
Are you still stuck on this issue, or did reseating the card resolve the I2C problems?
Still stuck. The dump of the entire set of boot messages is attached. There are only two i2c messages in the boot (1) indicating the /dev entries have been set up and another indicating the Clock is disabled because it is unused. The manual says the entries for the i2c should be in PINMUX 4, I don't entries for that PINMUX in the boot. Is there a utility to check what the PINMUX settings are? Possibly I've missed something else.
OMAP-L138 initialization passed!
Booting TI User Boot Loader
    UBL Version: 1.65
    UBL Flashtype: SPI
Starting SPI Memory Copy...
   DONE
U-Boot 2009.11-00162-g649c446 (Jun 28 2010 - 08:12:30)
I2C:   ready
DRAM:  128 MB
NAND:  256 MiB
In:    serial
Out:   serial
Err:   serial
ARM    Clock : 300000000 Hz
DDR    Clock : 132000000 Hz
EMIFA  CLock : 100000000 Hz
DSP    Clock : 300000000 Hz
ASYNC3 Clock : 150000000 Hz
Enet config  : 2
Resetting ethernet phy
Net:   Ethernet PHY: GENERIC @ 0x03 [0x8]
Hit any key to stop autoboot:  3  2  1  0
## Booting kernel from Legacy Image at c0700000 ...
   Image Name:   Linux-2.6.34-rc1
   Image Type:   ARM Linux Kernel Image (uncompressed)
   Data Size:    1818168 Bytes =  1.7 MB
   Load Address: c0008000
   Entry Point:  c0008000
   Verifying Checksum ... OK
   Loading Kernel Image ... OK
OK
Starting kernel ...
Linux version 2.6.34-rc1 (root@cianna) (gcc version 4.3.3 (GCC) ) #32 PREEMPT Tue Oct 26 17:51:28 PDT 2010
Machine: MityDSP-L138
Peripheral Config Block Found
Enet_Config = 2
EMAC = 00:50:C2:BF:83:28
PHYMask = 0x8
LCD Configured : COM57H5M06XRC
UART[0] = 0, 0, 0, 115200
UART[1] = 1, 1, 0, 115200
UART[2] = 0, 0, 0, 115200
SPI[0] = 0, 0, 00, 0, 0
SPI[1] = 1, 1, 01, 0, 30000000
DaVinci da850/omap-l138 variant 0x0
Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 24384
Kernel command line: mem=96M console=ttyS1,115200n8 mtdparts=nand:128M(rootfs),-(userfs) root=/dev/mtdblock0 rw rootfstype=jffs2
PID hash table entries: 512 (order: -1, 2048 bytes)
Memory: 96MB = 96MB total
Memory: 93652k/93652k available, 4652k reserved, 0K highmem
Virtual kernel memory layout:
    vector  : 0xffff0000 - 0xffff1000   (   4 kB)
    fixmap  : 0xfff00000 - 0xfffe0000   ( 896 kB)
    DMA     : 0xff000000 - 0xffe00000   (  14 MB)
    vmalloc : 0xc6800000 - 0xfea00000   ( 898 MB)
    lowmem  : 0xc0000000 - 0xc6000000   (  96 MB)
    modules : 0xbf000000 - 0xc0000000   (  16 MB)
      .init : 0xc0008000 - 0xc0028000   ( 128 kB)
      .text : 0xc0028000 - 0xc034d000   (3220 kB)
      .data : 0xc0364000 - 0xc0385020   ( 133 kB)
SLUB: Genslabs=11, HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
Hierarchical RCU implementation.
NR_IRQS:245
start_kernel(): bug: interrupts were enabled early
Calibrating delay loop... 149.50 BogoMIPS (lpj=747520)
DaVinci: 144 gpio irqs
regulator: core version 0.5
mityomapl138_init...
MUX: initialized LCD_D_0
MUX: Setting register LCD_D_0
       PINMUX17 (0x00000044) = 0x00000000 -> 0x00000020
MUX: initialized LCD_D_1
MUX: Setting register LCD_D_1
       PINMUX17 (0x00000044) = 0x00000020 -> 0x00000022
MUX: initialized LCD_D_2
MUX: Setting register LCD_D_2
       PINMUX16 (0x00000040) = 0x00000000 -> 0x20000000
MUX: initialized LCD_D_3
MUX: Setting register LCD_D_3
       PINMUX16 (0x00000040) = 0x20000000 -> 0x22000000
MUX: initialized LCD_D_4
MUX: Setting register LCD_D_4
       PINMUX16 (0x00000040) = 0x22000000 -> 0x22200000
MUX: initialized LCD_D_5
MUX: Setting register LCD_D_5
       PINMUX16 (0x00000040) = 0x22200000 -> 0x22220000
MUX: initialized LCD_D_6
MUX: Setting register LCD_D_6
       PINMUX16 (0x00000040) = 0x22220000 -> 0x22222000
MUX: initialized LCD_D_7
MUX: Setting register LCD_D_7
       PINMUX16 (0x00000040) = 0x22222000 -> 0x22222200
MUX: initialized LCD_D_8
MUX: Setting register LCD_D_8
       PINMUX18 (0x00000048) = 0x00000000 -> 0x00000020
MUX: initialized LCD_D_9
MUX: Setting register LCD_D_9
       PINMUX18 (0x00000048) = 0x00000020 -> 0x00000022
MUX: initialized LCD_D_10
MUX: Setting register LCD_D_10
       PINMUX17 (0x00000044) = 0x00000022 -> 0x20000022
MUX: initialized LCD_D_11
MUX: Setting register LCD_D_11
       PINMUX17 (0x00000044) = 0x20000022 -> 0x22000022
MUX: initialized LCD_D_12
MUX: Setting register LCD_D_12
       PINMUX17 (0x00000044) = 0x22000022 -> 0x22200022
MUX: initialized LCD_D_13
MUX: Setting register LCD_D_13
       PINMUX17 (0x00000044) = 0x22200022 -> 0x22220022
MUX: initialized LCD_D_14
MUX: Setting register LCD_D_14
       PINMUX17 (0x00000044) = 0x22220022 -> 0x22222022
MUX: initialized LCD_D_15
MUX: Setting register LCD_D_15
       PINMUX17 (0x00000044) = 0x22222022 -> 0x22222222
MUX: initialized LCD_PCLK
MUX: Setting register LCD_PCLK
       PINMUX18 (0x00000048) = 0x00000022 -> 0x02000022
MUX: initialized LCD_MCLK
MUX: Setting register LCD_MCLK
       PINMUX18 (0x00000048) = 0x02000022 -> 0x22000022
MUX: initialized LCD_HSYNC
MUX: Setting register LCD_HSYNC
       PINMUX19 (0x0000004c) = 0x00000000 -> 0x00000002
MUX: initialized LCD_VSYNC
MUX: Setting register LCD_VSYNC
       PINMUX19 (0x0000004c) = 0x00000002 -> 0x00000022
MUX: initialized NLCD_AC_ENB_CS
MUX: Setting register NLCD_AC_ENB_CS
       PINMUX19 (0x0000004c) = 0x00000022 -> 0x02000022
MUX: initialized MMCSD0_DAT_0
MUX: Setting register MMCSD0_DAT_0
       PINMUX10 (0x00000028) = 0x00000000 -> 0x00000200
MUX: initialized MMCSD0_DAT_1
MUX: Setting register MMCSD0_DAT_1
       PINMUX10 (0x00000028) = 0x00000200 -> 0x00002200
MUX: initialized MMCSD0_DAT_2
MUX: Setting register MMCSD0_DAT_2
       PINMUX10 (0x00000028) = 0x00002200 -> 0x00022200
MUX: initialized MMCSD0_DAT_3
MUX: Setting register MMCSD0_DAT_3
       PINMUX10 (0x00000028) = 0x00022200 -> 0x00222200
MUX: initialized MMCSD0_CLK
MUX: Setting register MMCSD0_CLK
       PINMUX10 (0x00000028) = 0x00222200 -> 0x00222202
MUX: initialized MMCSD0_CMD
MUX: Setting register MMCSD0_CMD
       PINMUX10 (0x00000028) = 0x00222202 -> 0x00222222
MUX: initialized GPIO4_0
MUX: Setting register GPIO4_0
       PINMUX10 (0x00000028) = 0x00222222 -> 0x80222222
MUX: initialized GPIO4_1
MUX: Setting register GPIO4_1
       PINMUX10 (0x00000028) = 0x80222222 -> 0x88222222
MUX: initialized AHCLKX
MUX: Setting register AHCLKX
       PINMUX0 (0x00000000) = 0x00440000 -> 0x00140000
MUX: initialized ACLKX
MUX: Setting register ACLKX
       PINMUX0 (0x00000000) = 0x00140000 -> 0x00140010
MUX: initialized AFSX
MUX: Setting register AFSX
       PINMUX0 (0x00000000) = 0x00140010 -> 0x00141010
MUX: initialized AHCLKR
MUX: Setting register AHCLKR
       PINMUX0 (0x00000000) = 0x00141010 -> 0x00111010
MUX: initialized ACLKR
MUX: Setting register ACLKR
       PINMUX0 (0x00000000) = 0x00111010 -> 0x00111011
MUX: initialized AFSR
MUX: Setting register AFSR
       PINMUX0 (0x00000000) = 0x00111011 -> 0x00111111
MUX: initialized AMUTE
MUX: Setting register AMUTE
       PINMUX0 (0x00000000) = 0x00111111 -> 0x01111111
MUX: initialized AXR_13
MUX: Setting register AXR_13
       PINMUX1 (0x00000004) = 0x00000000 -> 0x00000100
bio: create slab <bio-0> at 0
regulator: VDCDC1: 1150 <--> 1350 mV at 1200 mV
regulator: VDCDC2: 1710 <--> 1910 mV at 3300 mV
regulator: VDCDC3: 1120 <--> 1320 mV at 1800 mV
regulator: LDO1: 1800 mV
regulator: LDO2: 3300 mV
TCP established hash table entries: 4096 (order: 3, 32768 bytes)
TCP bind hash table entries: 4096 (order: 2, 16384 bytes)
TCP: Hash tables configured (established 4096 bind 4096)
TCP reno registered
EMAC: MII PHY configured, RMII PHY will not be functional
mityomapl138_init: setting phy_mask to 8
JFFS2 version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
msgmni has been set to 182
da8xx_lcdc da8xx_lcdc.0: GLCD: Found COM57H5M06XRC panel
Console: switching to colour frame buffer device 40x30
console [ttyS1] enabled
brd: module loaded
at24 1-0050: 256 byte 24c02 EEPROM (writable)
NAND device: Manufacturer ID: 0x2c, Chip ID: 0xca (Micron NAND 256MiB 3,3V 16-bit)
Creating 2 MTD partitions on "davinci_nand.0":
mtd: Giving out device 0 to rootfs
ftl_cs: FTL header not found.
0x000008000000-0x000010000000 : "homefs"
mtd: Giving out device 1 to homefs
davinci_nand davinci_nand.0: controller rev. 2.5
m25p80 spi1.0: m25p64 (8192 Kbytes)
Creating 3 MTD partitions on "m25p80":
0x000000000000-0x000000010000 : "UBL"
mtd: Giving out device 2 to UBL
0x000000010000-0x000000090000 : "U-Boot"
mtd: Giving out device 3 to U-Boot
0x000000090000-0x000000800000 : "Spare"
mtd: Giving out device 4 to Spare
console [netcon0] enabled
ohci ohci.0: DA8xx OHCI
usb usb1: New USB device found, idVendor=1d6b, idProduct=0001
usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
usb usb1: Product: DA8xx OHCI
usb usb1: Manufacturer: Linux 2.6.34-rc1 ohci_hcd
usb usb1: SerialNumber: ohci.0
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 1 port detected
mice: PS/2 mouse device common for all mice
omap_rtc: already running
i2c /dev entries driver
watchdog watchdog: heartbeat 60 sec
cpuidle: using governor menu
usbhid: USB HID core driver
TCP cubic registered
Clocks: disable unused i2c1
Clocks: disable unused emac
Clocks: disable unused mcasp
Clocks: disable unused mmcsd
Clocks: disable unused spi0
Clocks: disable unused mcbsp0
Clocks: disable unused mcbsp1
Clocks: disable unused vpif
regulator_init_complete: incomplete constraints, leaving LDO2 on
regulator_init_complete: incomplete constraints, leaving LDO1 on
regulator_init_complete: incomplete constraints, leaving VDCDC3 on
regulator_init_complete: incomplete constraints, leaving VDCDC2 on
regulator_init_complete: incomplete constraints, leaving VDCDC1 on
emac-mii: probed
omap_rtc omap_rtc: setting system clock to 2000-01-01 00:40:16 UTC (946687216)
Empty flash at 0x02cbd8ac ends at 0x02cbe000
VFS: Mounted root (jffs2 filesystem) on device 31:0.
Freeing init memory: 128K
INIT: version 2.86 booting
Please wait: booting...
Starting udev
udev: starting version 151
Remounting root file system...
Caching udev devnodes
Populating dev cache
root: mount: mount point /proc/bus/usb does not exist
Configuring network interfaces... eth0: attached PHY driver [Generic PHY] (mii_bus:phy_addr=1:03, id=40005201)
done.
Starting portmap daemon: portmap.
net.ipv4.conf.default.rp_filter = 1
net.ipv4.conf.all.rp_filter = 1
Thu Jun  3 22:25:00 UTC 2010
INIT: Entering runlevel: 5
Starting system message bus: dbus.
Starting Dropbear SSH server: dropbear.
Starting syslogd/klogd: done
PHY: 1:03 - Link is Up - 100/Half
 * Starting Avahi mDNS/DNS-SD Daemon: avahi-daemon
   ...done.
|       |     | __  |  ---'| '--.|  .-'|     |     |
The Angstrom Distribution cianna3 ttyS1
Angstrom 2010.4-test-20100508 cianna3 ttyS1
cianna3 login:
There are 2 I2C devices on the OMAP. I2C0 and I2C1. Both are brought out to the edge connector, Which are you using?
If you are getting valid factory configuration data, then u-Boot used I2C0 successfully to read the on board EPROM and the pinmuxing is fine for the I2C0 port. If you have a scope hooked on the SDAT or SCLK lines for I2C0 during boot up (when u-Boot is starting) you should see activity on the lines.
I2C1 clocks will get shut down if the I2C1 device is not used in the kernel. That is the message you are seeing. You won't see any other messages related to i2c unless you configure a specific device for it and add it to the kernel (see the board-mityomapl138.c file for details about this, there is a regulator also attached to the I2C0 that is connected to the bus in this file).
I'll try to add more information shortly.
RE: I2C Board Support Package - Added by John Mladenik almost 14 years ago
We are using I2C0 for both the Audio Chip and the Touch Screen Controller both of which have different I2C addresses than the EPROM
So my problem is I'm only seeing /dev/i2c-1 after the boot.
I2C0 is actually /dev/i2c-1 (bus numbering for i2c starts at 1 in the kernel, it's a bit arbitrary actually).
There should be 2 devices connected to i2c-1. One is at address 48. That is the voltage regulator. The second one is at address 50. That is the EEPROM containing factory config.
Let's try these commands (the output may be lengthy) which crawl through the /sys fs, which has a lot more detail than what shows up in /dev.
root@mitydsp # find /sys/devices/platform/i2c_davinci.1
root@mitydsp # dd if=/sys/devices/platform/i2c_davinci.1/i2c-1/1-0050/eeprom bs=1 count=128 | od -c
Below are the outputs that I get on my unit on an Indi board (though that should not matter). If your results are similar, then the i2c device has been installed by the kernel and it is capable of seeing the voltage regulator and the eeprom on board. You then need to add your audio chip and touch screen controller to the board-mityomapl138.c file in the kernel and rebuild to have your devices show up.
Please post what you get from the two commands above. Thanks.
root@mityomapl138:/sys/devices/platform/i2c_davinci.1/i2c-1/1-0050# find /sys/de
/sys/devices/platform/i2c_davinci.1/uevent
/sys/devices/platform/i2c_davinci.1/modalias
/sys/devices/platform/i2c_davinci.1/subsystem
/sys/devices/platform/i2c_davinci.1/driver
/sys/devices/platform/i2c_davinci.1/i2c-1/uevent
/sys/devices/platform/i2c_davinci.1/i2c-1/name
/sys/devices/platform/i2c_davinci.1/i2c-1/new_device
/sys/devices/platform/i2c_davinci.1/i2c-1/delete_device
/sys/devices/platform/i2c_davinci.1/i2c-1/subsystem
/sys/devices/platform/i2c_davinci.1/i2c-1/device
/sys/devices/platform/i2c_davinci.1/i2c-1/1-0048
/sys/devices/platform/i2c_davinci.1/i2c-1/1-0048/uevent
/sys/devices/platform/i2c_davinci.1/i2c-1/1-0048/name
/sys/devices/platform/i2c_davinci.1/i2c-1/1-0048/modalias
/sys/devices/platform/i2c_davinci.1/i2c-1/1-0048/subsystem
/sys/devices/platform/i2c_davinci.1/i2c-1/1-0048/driver
/sys/devices/platform/i2c_davinci.1/i2c-1/1-0048/regulator
/sys/devices/platform/i2c_davinci.1/i2c-1/1-0048/regulator/regulator.0
/sys/devices/platform/i2c_davinci.1/i2c-1/1-0048/regulator/regulator.0/uevent
/sys/devices/platform/i2c_davinci.1/i2c-1/1-0048/regulator/regulator.0/subsystem
/sys/devices/platform/i2c_davinci.1/i2c-1/1-0048/regulator/regulator.0/device
/sys/devices/platform/i2c_davinci.1/i2c-1/1-0048/regulator/regulator.0/name
/sys/devices/platform/i2c_davinci.1/i2c-1/1-0048/regulator/regulator.0/num_users
/sys/devices/platform/i2c_davinci.1/i2c-1/1-0048/regulator/regulator.0/type
/sys/devices/platform/i2c_davinci.1/i2c-1/1-0048/regulator/regulator.0/microvolts
/sys/devices/platform/i2c_davinci.1/i2c-1/1-0048/regulator/regulator.0/state
/sys/devices/platform/i2c_davinci.1/i2c-1/1-0048/regulator/regulator.0/min_microvolts
/sys/devices/platform/i2c_davinci.1/i2c-1/1-0048/regulator/regulator.0/max_microvolts
/sys/devices/platform/i2c_davinci.1/i2c-1/1-0048/regulator/regulator.1
/sys/devices/platform/i2c_davinci.1/i2c-1/1-0048/regulator/regulator.1/uevent
/sys/devices/platform/i2c_davinci.1/i2c-1/1-0048/regulator/regulator.1/subsystem
/sys/devices/platform/i2c_davinci.1/i2c-1/1-0048/regulator/regulator.1/device
/sys/devices/platform/i2c_davinci.1/i2c-1/1-0048/regulator/regulator.1/name
/sys/devices/platform/i2c_davinci.1/i2c-1/1-0048/regulator/regulator.1/num_users
/sys/devices/platform/i2c_davinci.1/i2c-1/1-0048/regulator/regulator.1/type
/sys/devices/platform/i2c_davinci.1/i2c-1/1-0048/regulator/regulator.1/microvolts
/sys/devices/platform/i2c_davinci.1/i2c-1/1-0048/regulator/regulator.1/state
/sys/devices/platform/i2c_davinci.1/i2c-1/1-0048/regulator/regulator.1/min_microvolts
/sys/devices/platform/i2c_davinci.1/i2c-1/1-0048/regulator/regulator.1/max_microvolts
/sys/devices/platform/i2c_davinci.1/i2c-1/1-0048/regulator/regulator.2
/sys/devices/platform/i2c_davinci.1/i2c-1/1-0048/regulator/regulator.2/uevent
/sys/devices/platform/i2c_davinci.1/i2c-1/1-0048/regulator/regulator.2/subsystem
/sys/devices/platform/i2c_davinci.1/i2c-1/1-0048/regulator/regulator.2/device
/sys/devices/platform/i2c_davinci.1/i2c-1/1-0048/regulator/regulator.2/name
/sys/devices/platform/i2c_davinci.1/i2c-1/1-0048/regulator/regulator.2/num_users
/sys/devices/platform/i2c_davinci.1/i2c-1/1-0048/regulator/regulator.2/type
/sys/devices/platform/i2c_davinci.1/i2c-1/1-0048/regulator/regulator.2/microvolts
/sys/devices/platform/i2c_davinci.1/i2c-1/1-0048/regulator/regulator.2/state
/sys/devices/platform/i2c_davinci.1/i2c-1/1-0048/regulator/regulator.2/min_microvolts
/sys/devices/platform/i2c_davinci.1/i2c-1/1-0048/regulator/regulator.2/max_microvolts
/sys/devices/platform/i2c_davinci.1/i2c-1/1-0048/regulator/regulator.3
/sys/devices/platform/i2c_davinci.1/i2c-1/1-0048/regulator/regulator.3/uevent
/sys/devices/platform/i2c_davinci.1/i2c-1/1-0048/regulator/regulator.3/subsystem
/sys/devices/platform/i2c_davinci.1/i2c-1/1-0048/regulator/regulator.3/device
/sys/devices/platform/i2c_davinci.1/i2c-1/1-0048/regulator/regulator.3/name
/sys/devices/platform/i2c_davinci.1/i2c-1/1-0048/regulator/regulator.3/num_users
/sys/devices/platform/i2c_davinci.1/i2c-1/1-0048/regulator/regulator.3/type
/sys/devices/platform/i2c_davinci.1/i2c-1/1-0048/regulator/regulator.3/microvolts
/sys/devices/platform/i2c_davinci.1/i2c-1/1-0048/regulator/regulator.3/state
/sys/devices/platform/i2c_davinci.1/i2c-1/1-0048/regulator/regulator.3/min_microvolts
/sys/devices/platform/i2c_davinci.1/i2c-1/1-0048/regulator/regulator.3/max_microvolts
/sys/devices/platform/i2c_davinci.1/i2c-1/1-0048/regulator/regulator.4
/sys/devices/platform/i2c_davinci.1/i2c-1/1-0048/regulator/regulator.4/uevent
/sys/devices/platform/i2c_davinci.1/i2c-1/1-0048/regulator/regulator.4/subsystem
/sys/devices/platform/i2c_davinci.1/i2c-1/1-0048/regulator/regulator.4/device
/sys/devices/platform/i2c_davinci.1/i2c-1/1-0048/regulator/regulator.4/name
/sys/devices/platform/i2c_davinci.1/i2c-1/1-0048/regulator/regulator.4/num_users
/sys/devices/platform/i2c_davinci.1/i2c-1/1-0048/regulator/regulator.4/type
/sys/devices/platform/i2c_davinci.1/i2c-1/1-0048/regulator/regulator.4/microvolts
/sys/devices/platform/i2c_davinci.1/i2c-1/1-0048/regulator/regulator.4/state
/sys/devices/platform/i2c_davinci.1/i2c-1/1-0048/regulator/regulator.4/min_microvolts
/sys/devices/platform/i2c_davinci.1/i2c-1/1-0048/regulator/regulator.4/max_microvolts
/sys/devices/platform/i2c_davinci.1/i2c-1/1-0050/uevent
/sys/devices/platform/i2c_davinci.1/i2c-1/1-0050/name
/sys/devices/platform/i2c_davinci.1/i2c-1/1-0050/modalias
/sys/devices/platform/i2c_davinci.1/i2c-1/1-0050/subsystem
/sys/devices/platform/i2c_davinci.1/i2c-1/1-0050/driver
/sys/devices/platform/i2c_davinci.1/i2c-1/i2c-dev
/sys/devices/platform/i2c_davinci.1/i2c-1/i2c-dev/i2c-1
/sys/devices/platform/i2c_davinci.1/i2c-1/i2c-dev/i2c-1/uevent
/sys/devices/platform/i2c_davinci.1/i2c-1/i2c-dev/i2c-1/dev
/sys/devices/platform/i2c_davinci.1/i2c-1/i2c-dev/i2c-1/subsystem
/sys/devices/platform/i2c_davinci.1/i2c-1/i2c-dev/i2c-1/device
/sys/devices/platform/i2c_davinci.1/i2c-1/i2c-dev/i2c-1/name
root@mityomapl138:/sys/devices/platform/i2c_davinci.1/i2c-1/1-0050# dd if=/sys/d
0000000    8 001   , 001 001  \0 001  \0  \0   P 302 277 203      \0  \0
0000020  002  \0  \0  \0  \0  \0  \0  \0 266 206 001  \0   8   0   -   0
0000040    0   0   2   5   8   R   C   -   1       R   e   v       B  \0
0000060  005  \0  \0  \0  \0  \0  \0  \0  \0  \0  \0  \0 206  \b 377 377
0000100  377 377 377 377 377 377 377 377 377 377 377 377 377 377 377 377
0000200
128+0 records in
128+0 records out
Here it is:
root@cianna2:~# find /sys/devices/platform/i2c_davinci.1
root@cianna2:~# dd if=/sys/devices/platform/i2c_davinci.1/i2c-1/1-0050/eeprom bs
0000000    8 001   , 001 001  \0 001  \0  \0   P 302 277 205   M  \0  \0
0000020  002  \0  \0  \0  \0  \0  \0  \0 270 207 001  \0   8   0   -   0
0000060   \0  \0   (  \0   3 376 366 300   ( 027 370  \0 371  \b 377 377
0000200
128+0 records in
128+0 records out
<\pre>
OK. Looks like your I2C0 port is up and running and is communicating with the on-board devices in the kernel.
Try running:
root@mitydsp # i2cdump -y 1 0x51
You should see data and the board part number of revision in the ascii text at the right (see below).
If that works (and it should, because it's doing the same thing as the "dd" command in the last post), then the I2C0 bus lines should be toggling, and John should be able to see them on his analyzer, and you should be able to use your external device addresses to debug / see the devices on your mainboard. You should also have someone verify that the reset line is toggling to ensure your devices are being properly reset.
I'm not sure how else to help at this point. Is the issue with the reset, or the communication of the I2C port using i2cdump?
root@mityomapl138:/sys/devices/platform/i2c_davinci.1/i2c-1/1-0050# i2cdump -y 1
 0x51
No size specified (using byte-data access)
     0  1  2  3  4  5  6  7  8  9  a  b  c  d  e  f    0123456789abcdef
00: 38 01 2c 01 01 00 01 00 00 50 c2 bf 83 20 00 00    8?,??.?..P??? ..
10: 02 00 00 00 00 00 00 00 b6 86 01 00 38 30 2d 30    ?.......???.80-0
20: 30 30 32 35 38 52 43 2d 31 20 52 65 76 20 42 00    00258RC-1 Rev B.
30: 05 00 00 00 00 00 00 00 00 00 00 00 86 08 ff ff    ?...........??..
40: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff    ................
50: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff    ................
60: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff    ................
70: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff    ................
80: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff    ................
90: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff    ................
a0: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff    ................
b0: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff    ................
c0: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff    ................
d0: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff    ................
e0: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff    ................
f0: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff    ................
The board rev is the same, a few differences with some of the hex codes. But doesn't the 1 in that command indicate which bus should be probed? Wouldn't that probe i2c1 instead of i2c0?
(1-25/37) Go to top
