Problems with custom board
Added by Mary Frantz over 12 years ago
I built a new kernel based on MDK_2012-08-10 starting with baseboard-industrialio.c and making a new baseboard file for our hardware. I mainly cut what we don't need and added support for SPI1, CS1.
I booted on the industrial io board and booted ok with the following exception. After adding a script to init.d and rebooting, the boot log showed the following:
Starting sys9000.service... nfsserver[1311]: starting statd: done sys9000[2253]: Changing cpu clock to 456MHz sys9000[2253]: /etc/init.d/sys9000: line 3: can't create /sys/devices/system/cpu /cpu0/cpufreq/scaling_setspeed: nonexistent directory
The script file contains:
#!/bin/sh echo "Changing cpu clock to 456MHz" echo 456000 > /sys/devices/system/cpu/cpu0/cpufreq/scaling_setspeed echo "Inserting cmem module" insmod /lib/modules/3.2.0/extra/cmemk.ko pools=1x33554432 phys_start=0xC4000000 phys_end=0xC5FFFFFF echo "Inserting dsplink module" insmod /lib/modules/3.2.0/extra/dsplinkk.ko exit 0
After booting, indeed /sys/devices/system/cpu/cpu0/ contains only cpuidle.
Second problem:
Attempting to boot on our hardware yields the bootlog below. We did not pullup any of the MII_RXDn lines on the board.
I2C:   ready
DRAM:  128 MB
NAND:  256 MiB
MMC:   davinci: 0
In:    serial
Out:   serial
Err:   serial
ARM    Clock : 300000000 Hz
DDR    Clock : 150000000 Hz
EMIFA  CLock : 100000000 Hz
DSP    Clock : 300000000 Hz
ASYNC3 Clock : 150000000 Hz
Enet  config : 2
MMC 0 Enable : 0
Resetting ethernet phy
Net:   Ethernet PHY: GENERIC @ 0x01 [0x2]
U-Boot > printenv
bootdelay=3
baudrate=115200
bootfile="uImage"
flashuboot=tftp 0xc0700000 mityomap/u-boot-ubl.bin; sf probe 0; sf erase 0x10000
 0x80000; sf write 0xc0700000 0x10000 ${filesize}
flashkernel=tftp 0xc0700000 mityomap/uImage; sf probe 0; sf erase 0x100000 0x280
000; sf write 0xc0700000 0x100000 ${filesize}
flashubl=tftp 0xc0700000 mityomap/UBL_SPI_MEM.ais; sf probe 0; sf erase 0 0x1000
0; sf write 0xc0700000 0 0x10000
flashrootfs=tftp 0xc2000000 mityomap/mityomap-base-mityomapl138.jffs2; nand eras
e 0 0x08000000; nand write.jffs2 0xc2000000 0 ${filesize}
mtdids=nand0=nand
flashargs=setenv bootargs ${bootargsbase} ${mtdparts} root=/dev/mtdblock0 rw,noa
time rootfstype=jffs2
autoload=no
filesize=26E198
fileaddr=C0700000
ipaddr=192.168.1.120
serverip=10.0.0.23
bootcmd=sf probe 0; sf read 0xC0700000 0x100000 0x280000;bootm 0xC0700000
stdin=serial
stdout=serial
stderr=serial
ethaddr=00:50:c2:bf:8c:0d
ver=U-Boot 2009.11 (Mar 31 2011 - 19:39:18)
Environment size: 1034/65532 bytes
U-Boot > print bootcmd
U-Boot > print bootargs
## Error: "bootargs" not defined
U-Boot > setenv bootargs mem=64M console=ttyS1,115200n8 mtdparts=nand:128M(rootf
s),-(userfs) root=/dev/mtdblock0 rw,noatime rootfstype=jffs2 ip=dhcp
bootargs=mem=64M console=ttyS1,115200n8 mtdparts=nand:128M(rootfs),-(userfs) roo
U-Boot > saveenv
Saving Environment to SPI Flash...
Erasing SPI flash...Writing to SPI flash...done
U-Boot > run bootcmd
## Booting kernel from Legacy Image at c0700000 ...
   Image Name:   Linux-3.2.0
   Image Type:   ARM Linux Kernel Image (uncompressed)
   Data Size:    2548056 Bytes =  2.4 MB
   Load Address: c0008000
   Entry Point:  c0008000
   Verifying Checksum ... OK
   Loading Kernel Image ... OK
OK
Starting kernel ...
Linux version 3.2.0 (mitydsp@mitydsp-dev) (gcc version 4.5.4 20120305 (prereleas
e) (GCC) ) #2 PREEMPT Thu Jul 25 10:31:32 EDT 2013
Machine: MityDSP-L138/MityARM-1808
Ignoring unrecognised tag 0x42000101
DaVinci da850/omap-l138/am18x variant 0x1
Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 16256
Kernel command line: mem=64M console=ttyS1,115200n8 mtdparts=nand:128M(rootfs),-
PID hash table entries: 256 (order: -2, 1024 bytes)
Dentry cache hash table entries: 8192 (order: 3, 32768 bytes)
Inode-cache hash table entries: 4096 (order: 2, 16384 bytes)
Memory: 64MB = 64MB total
Memory: 58872k/58872k available, 6664k reserved, 0K highmem
Virtual kernel memory layout:
    vector  : 0xffff0000 - 0xffff1000   (   4 kB)
    fixmap  : 0xfff00000 - 0xfffe0000   ( 896 kB)
    vmalloc : 0xc4800000 - 0xfea00000   ( 930 MB)
    lowmem  : 0xc0000000 - 0xc4000000   (  64 MB)
    modules : 0xbf000000 - 0xc0000000   (  16 MB)
      .text : 0xc0008000 - 0xc0535920   (5303 kB)
      .init : 0xc0536000 - 0xc055e000   ( 160 kB)
      .data : 0xc055e000 - 0xc05bdf80   ( 384 kB)
       .bss : 0xc05bdfa4 - 0xc05ea9b0   ( 179 kB)
NR_IRQS:245
Calibrating delay loop... 148.88 BogoMIPS (lpj=744448)
pid_max: default: 32768 minimum: 301
devtmpfs: initialized
DaVinci: 144 gpio irqs
print_constraints: dummy:
baseboard_pre_init: Entered
mityomapl138_setup_nand: using 16 bit data
baseboard_init [System9000]...
bio: create slab <bio-0> at 0
SCSI subsystem initialized
i2c_davinci i2c_davinci.1: controller timed out
i2c_davinci i2c_davinci.1: initiating i2c bus recovery
set_machine_constraints: VDCDC1: failed to enable
tps65023 1-0048: failed to register tps65023
tps65023: probe of 1-0048 failed with error -110
Advanced Linux Sound Architecture Driver Version 1.0.24.
musb-hdrc: version 6.0, ?dma?, otg (peripheral+host)
TCP established hash table entries: 2048 (order: 2, 16384 bytes)
TCP bind hash table entries: 2048 (order: 1, 8192 bytes)
TCP: Hash tables configured (established 2048 bind 2048)
TCP reno registered
RPC: Registered named UNIX socket transport module.
JFFS2 version 2.2. (NAND) B) 2001-2006 Red Hat, Inc.
msgmni has been set to 114
start plist test
end plist test
console [ttyS1] enabled
brd: module loaded
at24 1-0050: 256 byte 24c02 EEPROM, read-only, 0 bytes/write
MityOMAPL138: Read Factory Config Failed: -110
ahci ahci: forcing PORTS_IMPL to 0x1
ahci ahci: AHCI 0001.0100 32 slots 1 ports 3 Gbps 0x1 impl platform mode
ahci ahci: flags: ncq sntf pm led clo only pmp pio slum part ccc
scsi0 : ahci_platform
ata1: SATA max UDMA/133 mmio [mem 0x01e18000-0x01e19fff] port 0x100 irq 67
NAND device: Manufacturer ID: 0x2c, Chip ID: 0xca (Micron NAND 256MiB 3,3V 16-bi
t)
Bad block table found at page 131008, version 0x01
Bad block table found at page 130944, version 0x01
nand_read_bbt: bad block at 0x000000ce0000
0x000008000000-0x000010000000 : "homefs"
spi_davinci spi_davinci.1: DMA: supported
spi_davinci spi_davinci.1: DMA: RX channel: 18, TX channel: 19, event queue: 0
m25p80 spi1.0: m25p64-nonjedec (8192 Kbytes)
Creating 8 MTD partitions on "m25p80":
0x000000000000-0x000000010000 : "ubl"
0x000000010000-0x000000090000 : "u-boot"
0x000000090000-0x0000000a0000 : "u-boot-env"
0x0000000a0000-0x0000000b0000 : "periph-config"
MII PHY configured
0x0000000b0000-0x000000100000 : "reserved"
0x000000100000-0x000000400000 : "kernel"
0x000000400000-0x000000600000 : "fpga"
0x000000600000-0x000000800000 : "spare"
CAN device driver interface
davinci_mdio davinci_mdio.0: davinci mdio revision 1.5
davinci_mdio davinci_mdio.0: detected phy mask fffffffd
davinci_mdio.0: probed
davinci_mdio davinci_mdio.0: phy[1]: device 0:01, driver unknown
Initializing USB Mass Storage driver...
USB Mass Storage support registered.
omap_rtc: already running
i2c /dev entries driver
cpuidle: using governor menu
usbhid: USB HID core driver
ata1: SATA link down (SStatus 0 SControl 300)
ALSA device list:
  No soundcards found.
TCP cubic registered
can: controller area network core (rev 20090105 abi 8)
NET: Registered protocol family 29
can: raw protocol (rev 20090105)
------------[ cut here ]------------
WARNING: at arch/arm/mach-davinci/da850.c:1096 da850_regulator_init+0x30/0x54()
Unable to obtain voltage regulator for CVDD; voltage scaling unsupported
Modules linked in:
[<c000d518>] (unwind_backtrace+0x0/0xe0) from [<c001cdc0>] (warn_slowpath_common
+0x4c/0x64)
[<c001cdc0>] (warn_slowpath_common+0x4c/0x64) from [<c001ce58>] (warn_slowpath_f
mt+0x2c/0x3c)
[<c001ce58>] (warn_slowpath_fmt+0x2c/0x3c) from [<c0013c34>] (da850_regulator_in
it+0x30/0x54)
[<c0013c34>] (da850_regulator_init+0x30/0x54) from [<c00145b8>] (davinci_cpu_ini
t+0x34/0xbc)
[<c00145b8>] (davinci_cpu_init+0x34/0xbc) from [<c0223ca0>] (cpufreq_add_dev+0x1
20/0x220)
[<c0223ca0>] (cpufreq_add_dev+0x120/0x220) from [<c0193a0c>] (sysdev_driver_regi
ster+0xb0/0x128)
[<c0193a0c>] (sysdev_driver_register+0xb0/0x128) from [<c02230a8>] (cpufreq_regi
ster_driver+0xd0/0x17c)
[<c02230a8>] (cpufreq_register_driver+0xd0/0x17c) from [<c019609c>] (platform_dr
v_probe+0x14/0x18)
[<c019609c>] (platform_drv_probe+0x14/0x18) from [<c0194f8c>] (driver_probe_devi
ce+0xd4/0x198)
[<c0194f8c>] (driver_probe_device+0xd4/0x198) from [<c01950b0>] (__driver_attach
+0x60/0x84)
[<c01950b0>] (__driver_attach+0x60/0x84) from [<c0194220>] (bus_for_each_dev+0x4
c/0x78)
[<c0194220>] (bus_for_each_dev+0x4c/0x78) from [<c0194898>] (bus_add_driver+0x98
/0x214)
[<c0194898>] (bus_add_driver+0x98/0x214) from [<c0195614>] (driver_register+0xa0
/0x120)
[<c0195614>] (driver_register+0xa0/0x120) from [<c01964a8>] (platform_driver_pro
be+0x18/0x98)
[<c01964a8>] (platform_driver_probe+0x18/0x98) from [<c000887c>] (do_one_initcal
l+0x90/0x168)
[<c000887c>] (do_one_initcall+0x90/0x168) from [<c05367e8>] (kernel_init+0x78/0x
11c)
[<c05367e8>] (kernel_init+0x78/0x11c) from [<c0009cb8>] (kernel_thread_exit+0x0/
0x8)
---[ end trace 056dabec374b0ca5 ]---
console [netcon0] enabled
davinci_emac davinci_emac.1: using random MAC addr: 8a:7c:a7:16:cd:a5
omap_rtc omap_rtc: setting system clock to 2000-01-01 00:03:27 UTC (946685007)
PHY 0:03 not found
net eth0: could not connect to phy 0:03
Sending DHCP requests ...... timed out!
IP-Config: Reopening network devices...
PHY 0:03 not found
	U-Boot works fine and connects to ethernet. I was able to transfer files via tftp from my development host.
Attached is our baseboard file.
Mary
| baseboard-sys9000.c (4.36 KB) baseboard-sys9000.c | Baseboard file for custom hw |
Replies (8)
RE: Problems with custom board - Added by Jonathan Cormier over 12 years ago
According to your bootlog the following errors would cause the cpufreq directory to be missing as cvdd is needed.
set_machine_constraints: VDCDC1: failed to enable tps65023 1-0048: failed to register tps65023 tps65023: probe of 1-0048 failed with error -110
This is enabled in mityomapl138_init() via pmic_tps65023_init(). I'm unclear how your changes to the baseboard file would create this problem but perhaps one of the GPIO pins you changed was needed for this?
-Jonathan
RE: Problems with custom board - Added by Michael Williamson over 12 years ago
You may not have the proper configuration options set for the Power Management and Voltage Regulators set in the kernel configuration. If those options aren't set, the voltage regulators won't be found and dynamic scaling will not work. Or, if dynamic frequency scaling isn't enabled, same thing.
Can you post you kernel .config file?
RE: Problems with custom board - Added by Mary Frantz over 12 years ago
Thanks for the reply. We fixed the ethernet problem with a pullup on MII_RXD0, as was done on the industrial io board.
Attached is the .config file (renamed config).
Mary
diff arch/arm/configs/industrialio_defconfig ~/Downloads/config 287c287,288 < CONFIG_BASEBOARD_INDUSTRIALIO=y --- > # CONFIG_BASEBOARD_INDUSTRIALIO is not set > CONFIG_BASEBOARD_SYS9000=y 290a292,293 > # CONFIG_BASEBOARD_WIU is not set > # CONFIG_BASEBOARD_CIS10XX is not set 828c831 < CONFIG_SATA_PMP=y --- > # CONFIG_SATA_PMP is not set 1914a1918 > # CONFIG_AUFS_FS is not set
The two baseboard entries don't sound like a problem:
These are other baseboard choices that I'm not using.
The SATA entries are OK. This is needed to enable the SATA.
What does the last one mean?
Mary
Mary,
AUFS is a filesystem. It isn't a problem. Your .config file matches ours so doesn't appear to be the issue.
-Jonathan
RE: Problems with custom board - Added by Mary Frantz about 12 years ago
The problem was the GPIO. We had set the two I2C io pins as GPIO. I removed these from the list in the custom board support file, and it boots normally.
Mary
RE: Problems with custom board - Added by Jonathan Cormier about 12 years ago
Thanks for the update.
-Jonathan
