RTC issue?
Added by Kevin Robertson about 11 years ago
We are seeing an issue with the L138 RTC not running on our custom board - using hwclock we never see the time change.
I did some investigation and it looks like the SET32COUNTER bit in the RTC CTRL REG is always set after boot: I added some debug prints to omap_rtc.c, omap_rtc_probe(). I modified omap_rtc_probe() to reset this bit and the RTC starts operating as expected.
My issue is that I can't see where this bit would be set? Looking at omap_L138 Technical manual this bit should reset to 0.
I tested the same L138 module on a Critical Industrial IO Base Board and this bit isn't set - hwclock operates as expected.
The only difference(I can think of) is that the Critical has a Controlled POR using U104 where as our custom board doesn't. I did try an experiment holding our reset button while powering on to simulate Industrial IO but didn't see any change in behavior.
Thanks
Kevin
RE: RTC issue? - Added by Michael Williamson about 11 years ago
Have you measured the Battery Backup voltage on your board through a power cycle? If the backup voltage drops below the required threshold, I think the RTC CTRL register resets to a disabled state.
RE: RTC issue? - Added by Kevin Robertson about 11 years ago
I've check with the HW designer and he thinks it should be OK, see his info below
"The 3V_RTC pin of the L138 Module is at 2.7V when powered off. The design worst case should be 2.6V.
This is greater than the 2.5V that I believe is required to ensure that there is sufficient headroom for the 1V2 LDO on the board that powers the RTC circuitry."
Thanks
Kevin
Hi Kevin,
Would you be willing (offline) to share your schematics so that we might take a peek?
It's not obvious why you are having issues here.
