Autoboot Linux in terminal
Added by Yan Yandoff almost 8 years ago
Hello! I have a development board OMAPL138-F, version of kernel linux - 3.2. I have some questions: 1) how can autoboot Linux without entering a user name, 2) what commands are needed and where should they be prescribed?
Thanks!
Replies (5)
RE: Autoboot Linux in terminal - Added by Jonathan Cormier almost 8 years ago
Here you go.
https://stackoverflow.com/questions/10282981/automatic-login-on-angstrom-linux
# vim /etc/systemd/system/getty.target.wants/serial-getty@ttyS1.service
ExecStart=-/sbin/agetty --autologin root -s %I -L 115200
RE: Autoboot Linux in terminal - Added by Yan Yandoff almost 8 years ago
It works!
Thanks!
RE: Autoboot Linux in terminal - Added by Demon Demonof over 3 years ago
Hello!
I have a service "myApp.service". I want to autostart Linux myApp in terminal without background mode.
[Unit]
Description=myApp
After=network.service
[Service]
Type=simple
WorkingDirectory=/home/root
ExecStart={terminal} -e /home/root/myApp
[Install]
WantedBy=multi-user.target
What should be instead {terminal}?
Example: ExecStart=-/sbin/getty -e /home/root/myApp
RE: Autoboot Linux in terminal - Added by Jonathan Cormier over 3 years ago
Demon Demonof wrote in RE: Autoboot Linux in terminal:
Hello!
[Unit]
Description=myApp
[Service]
Type=simple
[Install]
Hi sorry for the late response. What you are asking for is pretty unusual. Why do you want your app to auto-run in the terminal on boot? Maybe we can find a better solution
Hi Demon, Just noticed you posted in an old thread. Could you create a new one describing what your trying to accomplish so it doesn't get mixed up with this one? It's fine to link to this one.
    (1-5/5)
