Building DspHelloWorld MDK 2018
Added by Tom Riddle over 6 years ago
I'm setting up a native Ubuntu 16.04 hosted machine for the MDK 2018. CCS v7.3 is installed with the recommended tools and have followed these instructions.
https://support.criticallink.com/redmine/projects/arm9-platforms/wiki/DSP_Hello_World
got the project setup and seems to compile main_dsp.cpp but fails assembly afterwards, log is below. Any thoughts? Thanks in advance Tom
Finished building: ../main_dsp.cpp
Building file: RURIDSP4cfg.s??
Invoking: C6000 Compiler
"/export/software/mitydsp/ccsv7/tools/compiler/c6000_7.4.24/bin/cl6x" -mv6740 --abi=coffabi -g --include_path="/export/software/mitydsp/mdkextrafiles/lib/DSP/Debug" --include_path="/export/software/mitydsp/mdkextrafiles/sw/DSP/lib" --include_path="/export/software/mitydsp/mdkextrafiles/sw/3rdparty/edma3lld_01_11_00_03/packages/" --include_path="/export/software/mitydsp/mdkextrafiles/sw/3rdparty/edma3lld_01_11_00_03/packages/ti/sdo/edma3" --include_path="/export/software/mitydsp/workspace_v7/RURIDSP4" --include_path="/export/software/mitydsp/ccsv7/tools/compiler/c6000_7.4.24/include" --include_path="/export/software/mitydsp/workspace_v7/RURIDSP4/Debug" --include_path="/export/software/mitydsp/bios_5_42_02_10/packages/ti/bios/include" --include_path="/export/software/mitydsp/bios_5_42_02_10/packages/ti/rtdx/include/c6000" --diag_warning=225 --diag_wrap=off --display_error_number --preproc_with_compile --preproc_dependency="RURIDSP4cfg.d_raw" "RURIDSP4cfg.s62"
3 Assembly Errors, No Assembly Warnings
Compilation failure
subdir_rules.mk:24: recipe for target 'RURIDSP4cfg.obj' failed
"RURIDSP4cfg.s62", ERROR! at line 2160: [E0003] Invalid constant specification
SWI_Obj 1, KNL_swi, 0, _function, _pri, _mailbox, _arg0, _arg1, _dorta, _Order, _filter, _maxformat, _sumformat, _avgformat, _filtmaxmult, _filtsummult, _unittype
"RURIDSP4cfg.s62", REMARK at line 2160: [R0001] After symbol substitution the line became:
SWI_Obj 1, KNL_swi, 0, _KNL_run, 00H, 00H, 00H, 00H, 01H, 00H, 02H, %g inst, %g inst, %.2f inst, _filtmaxmult, _filtsummult, _unittype
"RURIDSP4cfg.s62", ERROR! at line 2193: [E0003] Invalid constant specification
TSK_Obj 1, TSK_idle, 0, _iFXN, _iARG0, _iARG1, _iARG2, _iARG3, _iARG4, _iARG5, _iARG6, _iARG7, _iAUTOSTK, _iMANSTK, _iSTKSZ, _iSTKSEG, _iPRI, _iENV, _iEXITFLAG, _iUSETSKNAME, _iSTATREG, _Order, _filter, _maxformat, _sumformat, _avgformat, _filtmaxmult, _filtsummult, _unittype
"RURIDSP4cfg.s62", REMARK at line 2193: [R0001] After symbol substitution the line became:
TSK_Obj 1, TSK_idle, 0, IDL_F_loop, 00H, 00H, 00H, 00H, 00H, 00H, 00H, 00H, 01H, null, 0400H, DDR, 00H, 00H, 01H, 00H, 00H, 00H, 02H, %g inst, %g inst, %.2f inst, _filtmaxmult, _filtsummult, _unittype
"RURIDSP4cfg.s62", ERROR! at line 2250: [E0003] Invalid constant specification
STS_Obj 1, IDL_busyObj, 0, _prev, _filter, _maxformat, _sumformat, _avgformat, _op, _uType, _iA, _iB, _iC, _prevlow
"RURIDSP4cfg.s62", REMARK at line 2250: [R0001] After symbol substitution the line became:
STS_Obj 1, IDL_busyObj, 0, 00H, 01H, %g, %g, %.2f, _op, _uType, _iA, _iB, _iC, _prevlow
Errors in Source - Assembler Aborted
gmake: *** [RURIDSP4cfg.obj] Error 1
gmake: Target 'all' not remade because of errors.
  • Build Finished **
RE: Building DspHelloWorld MDK 2018 - Added by Gregory Gluszek over 6 years ago
Hi Tom,
I believe the DSP MDK core library you are linking against was built with Code Composer 6.1. I would recommend using CCS v6.1 to build the DSP Hello World application.
\Greg
RE: Building DspHelloWorld MDK 2018 - Added by Tom Riddle over 6 years ago
Greg, thanks... So the other option (assuming untested) would be to rebuild DSPlink libs with the XDC Tools version on the CCS v7.3? regs, Tom
    (1-2/2)
