Boot Pins? (Posted on behalf of a customer.)
Added by Angela Newman about 12 years ago
I am actually design an eval board using your L138 module. I am wondering if I need to care about the BOOT pins (muxed with others fonctionalities), so that your L138 module will properly boot, or is that done within your L138 module.
Do you have a schematic of your module?
RE: Boot Pins? (Posted on behalf of a customer.) - Added by Michael Williamson almost 12 years ago
Are you using just the MityDSP-L138, or the MityDSP-L138F.
Both modules currently include pull-up/pull-down resistors (2K, I believe) on the SOM. So the unit should boot OK as long as you leave the boot pins connected to high impedance signals (or floating).
We don't normally provide module schematics.
