RSMunti-function OMAP pins
Added by Rachel Shaska about 3 years ago
I would like to use the SPI1 on the OMAP with two separate devices are the pin functions in the critical link datasheet table 1 exhaustive?
For instance, could I use pin 61 as SPI1_SCS5? The OMAP documentation has it listed as a spi CS driver as one of the multi-functions, but critical link only has the UART2/I2C1
If not what would you recommend instead?
Thank you!
    (1-2/2)
