VPFPGA coding and programming for customized board using Mity DSP L138F
Added by Vivek Ponnani over 9 years ago
We have made our own customized board using the Industrial IO board as well as the Analog Expansion board. We have the schematics attached herewith.
We are also attaching the entire FPGA package project (Mity_DSP_Analog.rar) so that it can be reviewed. We have not changed any pins between the ADC and DAC interface to the FPGA. Is it possible that somebody can review the package and let us know if there are any concerns and suggestions?
Secondly I did try to program the FPGA using the Xilinx tool (Platform Cable USB II). I initialized the chain using the IMPACT tool. The tools shows me only one Xilinx device connected. The tool then also shows a pop-up of an SPI device that seems to be associated with the FPGA. I am presently moving forward by saying no to program the SPI device.
Since we are a newbie to FPGA coding and programming, we would like to be guided for the same.
Thanks in advance for support.
VP RE: FPGA coding and programming for customized board using Mity DSP L138F - Added by Vivek Ponnani about 9 years ago
we are using ADS5560 of the analog expansion board through FPGA. We are using CLK and Data through FPGA to connect to uPP interface of the OMAP-L138.
We are using example program from the analog expansion suite.
How can we debug/check that we have received data from FPGA?
Which .ko files(MDK_2014-01-13\fs\mityomap-full\lib\modules\3.2.0\extra) related to FPGA are to be inserted using the insmod command on the board?
Also please revert back to my query put forward earlier on June 30 2017.
Thanks in advance for your support.
Vivek Ponnani
