yocto meta-mitysom-335x no recipes and files.
Added by Niko Stan about 8 years ago
I have the MitySOM-335x Development Kit and I would like to create a custom linux system.
I search on your website if there is some layers which can be used with yocto and I found the "meta-mitysom-335x" layer (this is the link where I found it : https://support.criticallink.com/gitweb/?a=project_list&s=335x&btnS=Search).
I done a "git clone git://support.criticallink.com/home/git/meta-mitysom-335x.git", but when git finished to clone I got only a empty folder.
Here there is where I got the link to clone this layer : https://support.criticallink.com/gitweb/?p=meta-mitysom-335x.git;a=summary
I would like to now if there is an other link to clone a layer for the MitySOM-335x Development Kit which contain all necessary recipes to be able to use this layer in my yocto project and to build my custom linux system.
RE: yocto meta-mitysom-335x no recipes and files. - Added by Bob Duke about 8 years ago
Hi Niko,
We are in the process of releasing the associated files for our MitySOM-335x Yocto MDK build (we should have everything completed by the end of the month). In the interest of helping you, I have pushed the daisy branch to the repository you just cloned, but there are still some links to our internal build servers that you will need to work-around (specifically, references to svnsrv). We are currently working to remove those dependencies.
In any case, the meta-mitysom-335x layer and meta-criticallink layers have what you need if you are trying to create your own build environment and they are what we use to create our Yocto-based MDK.
RE: yocto meta-mitysom-335x no recipes and files. - Added by Niko Stan about 8 years ago
Hi Bob,
thank you for this explanations and for pushing the daisy branch.
I will wait the release for the layer MitySOM-335x if I can't use succeed to create my own build environment with the layers of the daisy branch.
    (1-2/2)
