Reading contents of a file in Uboot
Added by Manjunath K S almost 6 years ago
Hi ,
How can i read or cat contents of file from uboot.
Regards,
manjunath
RE: Reading contents of a file in Uboot - Added by Jonathan Cormier almost 6 years ago
u-boot doesn't really have a lot of file io ability.
You can load a file from sd card, tftp, nfs, or nand into memory. But the only way I know to look at it would be with "md" though that will just print the hex values in memory.
If your trying to load a boot environment, check the README.txt
Example which loads a text file into the boot environment:
"bootenv=uEnv.txt"
"loadbootenv=load mmc ${mmc_dev} ${loadaddr} ${bootenv}"
"importbootenv=echo Importing environment from mmc ...; env import -t $loadaddr $filesize"
