Ethernet on MitySoM
Added by Jonas Mair about 4 years ago
I have a MitySoM Module and the accompanying dev kit.
To use ssh and scp, i wanted to enable ethernet. For that I configured a static ip address but no connection is established.
Has someone an idea, what else should be configured?
Tell me, if you need more info than what is attached.
Regards
Jonas
Some Outputs:
Bootup:
U-Boot SPL 2020.04-06638-ga08578af64-dirty (May 04 2021 - 14:25:32 +0200)
DDRCAL: Scrubbing ECC RAM (1024 MiB).
DDRCAL: SDRAM-ECC initialized success with 623 ms
Trying to boot from MMC1
U-Boot 2020.04-06638-ga08578af64-dirty (May 04 2021 - 14:25:32 +0200)
CPU: Altera SoCFPGA Platform
FPGA: Altera Cyclone V, SE/A6 or SX/C6 or ST/D6, version 0x0
BOOT: SD/MMC Internal Transceiver (3.0V)
Watchdog enabled
DRAM: 1 GiB
MMC: dwmmc0@ff704000: 0
Loading Environment from MMC... OK
In: serial
Out: serial
Err: serial
Model: Altera SOCFPGA Cyclone V SoC Development Kit
Net:
Warning: ethernet@ff702000 (eth0) using random MAC address - 02:52:6d:74:7f:bb
eth0: ethernet@ff702000
switch to partitions #0, OK
mmc0 is current device
Scanning mmc 0:1...
Found U-Boot script /boot.scr
2564 bytes read in 3 ms (834 KiB/s)
## Executing script at 02100000
gpio: pin 53 (gpio 53) value is 1
## Resetting to default environment
--- Set the kernel image ---
--- Set the devicetree image --
--- set kernel boot arguments, then boot the kernel
--- load linux kernel image and device tree to memory
--- command to be executed to read from sdcard ---
--- sdcard fat32 partition number ---
--- sdcard ext3 identifier ---
--- standard input/output ---
Saving Environment to MMC... Writing to MMC(0)... OK
--- Programming FPGA ---
--- load FPGA config to memory
7007204 bytes read in 358 ms (18.7 MiB/s)
--- write the FPGA configuration ---
--- enable HPS-to-FPGA, FPGA-to-HPS, LWHPS-to-FPGA bridges ---
--- enable FPGA2HPS peripherals access --
for I2C,CAN,UART,TIM
for GPIO
for OSC
for SPI
for on-chip RAM
Reset Bridges
--- Booting the Yocto Linux ---
-> load linux kernel image and device tree to memory
5257888 bytes read in 271 ms (18.5 MiB/s)
20956 bytes read in 5 ms (4 MiB/s)
--- set kernel boot arguments, then boot the kernel ---
*** leaving the u-boot boot sequence script (boot.script) ***
## Flattened Device Tree blob at 02000000
Booting using the fdt blob at 0x2000000
Loading Device Tree to 09ff7000, end 09fff1db ... OK
Starting kernel ...
Deasserting all peripheral resets
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 5.8.0-altera (oe-user@oe-host) (arm-poky-linux-gnueabi-gcc (GCC) 9.3.0, GNU ld (GNU Binutils) 2.34.0.20200220) #1 SMP Thu Aug 27 15:07:27 UTC 2020
[ 0.000000] CPU: ARMv7 Processor [413fc090] revision 0 (ARMv7), cr=10c5387d
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[ 0.000000] OF: fdt: Machine model: Altera SOCFPGA Cyclone V
[ 0.000000] Memory policy: Data cache writealloc
[ 0.000000] Zone ranges:
[ 0.000000] Normal [mem 0x0000000000000000-0x000000002fffffff]
[ 0.000000] HighMem [mem 0x0000000030000000-0x000000003fffffff]
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000000000000-0x000000003fffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x000000003fffffff]
[ 0.000000] percpu: Embedded 18 pages/cpu s44876 r8192 d20660 u73728
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 260608
[ 0.000000] Kernel command line: mem=1024M console=ttyS0,115200 root=/dev/mmcblk0p2 rw rootwait
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[ 0.000000] Memory: 1027272K/1048576K available (8192K kernel code, 663K rwdata, 1808K rodata, 1024K init, 146K bss, 21304K reserved, 0K cma-reserved, 262144K highmem)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
[ 0.000000] ftrace: allocating 28244 entries in 56 pages
[ 0.000000] ftrace: allocated 56 pages with 3 groups
[ 0.000000] rcu: Hierarchical RCU implementation.
[ 0.000000] rcu: RCU event tracing is enabled.
[ 0.000000] Rude variant of Tasks RCU enabled.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies.
[ 0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[ 0.000000] L2C-310 erratum 769419 enabled
[ 0.000000] L2C-310 enabling early BRESP for Cortex-A9
[ 0.000000] L2C-310 full line of zeros enabled for Cortex-A9
[ 0.000000] L2C-310 ID prefetch enabled, offset 1 lines
[ 0.000000] L2C-310 dynamic clock gating enabled, standby mode enabled
[ 0.000000] L2C-310 cache controller enabled, 8 ways, 512 kB
[ 0.000000] L2C-310: CACHE_ID 0x410030c9, AUX_CTRL 0x76460001
[ 0.000000] random: get_random_bytes called from start_kernel+0x384/0x524 with crng_init=0
[ 0.000000] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604467 ns
[ 0.000006] sched_clock: 32 bits at 100MHz, resolution 10ns, wraps every 21474836475ns
[ 0.000017] Switching to timer-based delay loop, resolution 10ns
[ 0.000347] GIC: PPI13 is secure or misconfigured
[ 0.000379] GIC: PPI13 is secure or misconfigured
[ 0.000543] Console: colour dummy device 80x30
[ 0.000579] Calibrating delay loop (skipped), value calculated using timer frequency.. 200.00 BogoMIPS (lpj=1000000)
[ 0.000593] pid_max: default: 32768 minimum: 301
[ 0.000734] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
[ 0.000748] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
[ 0.001411] CPU: Testing write buffer coherency: ok
[ 0.001443] CPU0: Spectre v2: using BPIALL workaround
[ 0.001635] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.002102] Setting up static identity map for 0x100000 - 0x100060
[ 0.002235] rcu: Hierarchical SRCU implementation.
[ 0.002547] smp: Bringing up secondary CPUs ...
[ 0.003007] smp: Brought up 1 node, 1 CPU
[ 0.003018] SMP: Total of 1 processors activated (200.00 BogoMIPS).
[ 0.003026] CPU: All CPU(s) started in SVC mode.
[ 0.003505] devtmpfs: initialized
[ 0.007677] VFP support v0.3: implementor 41 architecture 3 part 30 variant 9 rev 4
[ 0.007990] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.008010] futex hash table entries: 512 (order: 3, 32768 bytes, linear)
[ 0.008864] NET: Registered protocol family 16
[ 0.009565] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.010513] hw-breakpoint: found 5 (+1 reserved) breakpoint and 1 watchpoint registers.
[ 0.010523] hw-breakpoint: maximum watchpoint size is 4 bytes.
[ 0.018645] OF: /sopc@0/gpio@0xff708000/gpio-controller@0: could not get #gpio-cells for /sopc@0/clkmgr@0xffd04000/clock_tree/sdram_pll/s2f_usr2_clk
[ 0.018731] OF: /sopc@0/gpio@0xff709000/gpio-controller@0: could not get #gpio-cells for /sopc@0/clkmgr@0xffd04000/clock_tree/sdram_pll/s2f_usr2_clk
[ 0.018814] OF: /sopc@0/gpio@0xff70a000/gpio-controller@0: could not get #gpio-cells for /sopc@0/clkmgr@0xffd04000/clock_tree/sdram_pll/ddr_2x_dqs_clk
[ 0.020463] OF: /sopc@0/gpio@0xff708000/gpio-controller@0: could not get #gpio-cells for /sopc@0/clkmgr@0xffd04000/clock_tree/sdram_pll/s2f_usr2_clk
[ 0.020548] OF: /sopc@0/gpio@0xff709000/gpio-controller@0: could not get #gpio-cells for /sopc@0/clkmgr@0xffd04000/clock_tree/sdram_pll/s2f_usr2_clk
[ 0.020631] OF: /sopc@0/gpio@0xff70a000/gpio-controller@0: could not get #gpio-cells for /sopc@0/clkmgr@0xffd04000/clock_tree/sdram_pll/ddr_2x_dqs_clk
[ 0.029427] vgaarb: loaded
[ 0.029687] SCSI subsystem initialized
[ 0.029874] usbcore: registered new interface driver usbfs
[ 0.029919] usbcore: registered new interface driver hub
[ 0.029975] usbcore: registered new device driver usb
[ 0.030162] usb_phy_generic sopc@0:usbphy@0: supply vcc not found, using dummy regulator
[ 0.031207] pps_core: LinuxPPS API ver. 1 registered
[ 0.031217] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.031237] PTP clock support registered
[ 0.031396] FPGA manager framework
[ 0.032431] clocksource: Switched to clocksource timer
[ 0.672383] NET: Registered protocol family 2
[ 0.673025] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
[ 0.673055] TCP established hash table entries: 8192 (order: 3, 32768 bytes, linear)
[ 0.673131] TCP bind hash table entries: 8192 (order: 4, 65536 bytes, linear)
[ 0.673252] TCP: Hash tables configured (established 8192 bind 8192)
[ 0.673364] UDP hash table entries: 512 (order: 2, 16384 bytes, linear)
[ 0.673414] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear)
[ 0.673608] NET: Registered protocol family 1
[ 0.674129] RPC: Registered named UNIX socket transport module.
[ 0.674140] RPC: Registered udp transport module.
[ 0.674147] RPC: Registered tcp transport module.
[ 0.674153] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.674166] PCI: CLS 0 bytes, default 64
[ 0.674805] hw perfevents: no interrupt-affinity property for /sopc@0/pmu0, guessing.
[ 0.675000] hw perfevents: enabled with armv7_cortex_a9 PMU driver, 7 counters available
[ 0.676071] workingset: timestamp_bits=30 max_order=18 bucket_order=0
[ 0.682258] NFS: Registering the id_resolver key type
[ 0.682287] Key type id_resolver registered
[ 0.682294] Key type id_legacy registered
[ 0.682309] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
[ 0.683031] ntfs: driver 2.1.32 [Flags: R/W].
[ 0.683226] jffs2: version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
[ 0.683807] bounce: pool size: 64 pages
[ 0.683824] io scheduler mq-deadline registered
[ 0.683832] io scheduler kyber registered
[ 0.690673] dma-pl330 ffe01000.dma: Loaded driver for PL330 DMAC-341330
[ 0.690691] dma-pl330 ffe01000.dma: DBUFF-512x8bytes Num_Chans-8 Num_Peri-32 Num_Events-8
[ 0.694179] Serial: 8250/16550 driver, 2 ports, IRQ sharing disabled
[ 0.695168] printk: console [ttyS0] disabled
[ 0.695243] ffc02000.serial: ttyS0 at MMIO 0xffc02000 (irq = 23, base_baud = 6250000) is a 16550A
[ 1.401422] printk: console [ttyS0] enabled
[ 1.407075] brd: module loaded
[ 1.417216] loop: module loaded
[ 1.420966] cadence-qspi ff705000.flash: couldn't determine fifo-depth
[ 1.427541] cadence-qspi ff705000.flash: Cannot get mandatory OF data.
[ 1.434878] libphy: Fixed MDIO Bus: probed
[ 1.439540] CAN device driver interface
[ 1.444073] c_can_platform ffc00000.can: c_can_platform device registered (regs=(ptrval), irq=35)
[ 1.453491] c_can_platform ffc01000.can: c_can_platform device registered (regs=(ptrval), irq=37)
[ 1.462633] socfpga-dwmac ff702000.ethernet: IRQ eth_wake_irq not found
[ 1.469225] socfpga-dwmac ff702000.ethernet: IRQ eth_lpi not found
[ 1.475452] socfpga-dwmac ff702000.ethernet: snps,phy-addr property is deprecated
[ 1.483002] socfpga-dwmac ff702000.ethernet: PTP uses main clock
[ 1.489224] socfpga-dwmac ff702000.ethernet: Version ID not available
[ 1.495684] socfpga-dwmac ff702000.ethernet: DWMAC1000
[ 1.500891] socfpga-dwmac ff702000.ethernet: DMA HW capability register supported
[ 1.508361] socfpga-dwmac ff702000.ethernet: RX Checksum Offload Engine supported
[ 1.515827] socfpga-dwmac ff702000.ethernet: COE Type 2
[ 1.521031] socfpga-dwmac ff702000.ethernet: TX Checksum insertion supported
[ 1.528063] socfpga-dwmac ff702000.ethernet: Enhanced/Alternate descriptors
[ 1.535008] socfpga-dwmac ff702000.ethernet: Extended descriptors not supported
[ 1.542287] socfpga-dwmac ff702000.ethernet: Ring mode enabled
[ 1.548113] socfpga-dwmac ff702000.ethernet: device MAC address e2:63:72:57:5d:ee
[ 1.563796] libphy: stmmac: probed
[ 1.567200] Micrel KSZ9031 Gigabit PHY stmmac-0:1f: attached PHY driver [Micrel KSZ9031 Gigabit PHY] (mii_bus:phy_addr=stmmac-0:1f, irq=POLL)
[ 1.581105] dwc2 ffb40000.usb: supply vusb_d not found, using dummy regulator
[ 1.588340] dwc2 ffb40000.usb: supply vusb_a not found, using dummy regulator
[ 1.595676] dwc2 ffb40000.usb: Bad value for GSNPSID: 0x00000000
[ 1.602028] usbcore: registered new interface driver usb-storage
[ 1.608259] i2c /dev entries driver
[ 1.612988] Synopsys Designware Multimedia Card Interface Driver
[ 1.619240] dw_mmc ff704000.flash: IDMAC supports 32-bit address mode.
[ 1.625817] dw_mmc ff704000.flash: Using internal DMA controller.
[ 1.631892] dw_mmc ff704000.flash: Version ID is 240a
[ 1.636997] dw_mmc ff704000.flash: DW MMC controller at irq 32,32 bit host data width,1024 deep fifo
[ 1.646231] mmc_host mmc0: card is polling.
[ 1.662433] mmc_host mmc0: Bus speed (slot 0) = 200000000Hz (slot req 400000Hz, actual 400000HZ div = 250)
[ 1.682896] ledtrig-cpu: registered to indicate activity on CPUs
[ 1.689043] usbcore: registered new interface driver usbhid
[ 1.694618] usbhid: USB HID core driver
[ 1.698706] fpga_manager fpga0: Altera SOCFPGA FPGA Manager registered
[ 1.705864] altera_hps2fpga_bridge sopc@0:fpgabridge@0: fpga bridge [hps2fpga] registered
[ 1.714284] altera_hps2fpga_bridge sopc@0:fpgabridge@1: fpga bridge [lwhps2fpga] registered
[ 1.722781] altera_hps2fpga_bridge sopc@0:fpgabridge@2: fpga bridge [fpga2hps] registered
[ 1.731817] NET: Registered protocol family 10
[ 1.737136] Segment Routing with IPv6
[ 1.740881] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
[ 1.747360] NET: Registered protocol family 17
[ 1.751807] NET: Registered protocol family 15
[ 1.756260] can: controller area network core (rev 20170425 abi 9)
[ 1.762493] NET: Registered protocol family 29
[ 1.766922] can: raw protocol (rev 20170425)
[ 1.771173] can: broadcast manager protocol (rev 20170425 t)
[ 1.776832] can: netlink gateway (rev 20190810) max_hops=1
[ 1.782477] 8021q: 802.1Q VLAN Support v1.8
[ 1.786683] Key type dns_resolver registered
[ 1.791154] oprofile: using arm/armv7-ca9
[ 1.795273] ThumbEE CPU extension supported.
[ 1.799532] Registering SWP/SWPB emulation handler
[ 1.808243] of_cfs_init
[ 1.810799] of_cfs_init: OK
[ 1.814153] dw-apb-uart ffc02000.serial: forbid DMA for kernel console
[ 1.820892] Waiting for root device /dev/mmcblk0p2...
[ 1.905833] mmc_host mmc0: Bus speed (slot 0) = 200000000Hz (slot req 25000000Hz, actual 25000000HZ div = 4)
[ 1.915657] mmc0: new SDHC card at address aaaa
[ 1.920816] mmcblk0: mmc0:aaaa SB32G 29.7 GiB
[ 1.935051] mmcblk0: p1 p2 p3
[ 1.946288] EXT4-fs (mmcblk0p2): mounting ext3 file system using the ext4 subsystem
[ 3.528098] random: fast init done
[ 3.908780] EXT4-fs (mmcblk0p2): recovery complete
[ 3.920355] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 3.928487] VFS: Mounted root (ext3 filesystem) on device 179:2.
[ 4.117614] devtmpfs: mounted
[ 4.123740] Freeing unused kernel memory: 1024K
[ 4.128449] Run /sbin/init as init process
INIT: version 2.96 booting
Starting udev
[ 11.697398] udevd[72]: starting version 3.2.9
[ 11.719788] random: udevd: uninitialized urandom read (16 bytes read)
[ 11.738088] random: udevd: uninitialized urandom read (16 bytes read)
[ 11.744639] random: udevd: uninitialized urandom read (16 bytes read)
[ 11.986880] udevd[73]: starting eudev-3.2.9
[ 16.214000] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
sysctl: cannot stat /proc/sys/net/ipv4/tcp_syncookies: No such file or directory
hwclock: Cannot access the Hardware Clock via any known method.
hwclock: Use the --verbose option to see the details of our search for an access method.
Fri Mar 9 12:34:56 UTC 2018
[ 18.444985] urandom_read: 1 callbacks suppressed
[ 18.444992] random: dd: uninitialized urandom read (512 bytes read)
INIT: Entering runlevel: 5
Configuring network interfaces... [ 19.500625] socfpga-dwmac ff702000.ethernet eth0: PHY [stmmac-0:1f] driver [Micrel KSZ9031 Gigabit PHY] (irq=POLL)
[ 19.511763] socfpga-dwmac ff702000.ethernet eth0: No Safety Features support found
[ 19.519565] socfpga-dwmac ff702000.ethernet eth0: registered PTP clock
[ 19.526097] socfpga-dwmac ff702000.ethernet eth0: configuring for phy/rgmii link mode
done.
Starting rpcbind daemon...done.
starting statd: done
Starting atd: OK
starting 8 nfsd kernel threads: [ 21.742688] NFSD: Using /var/lib/nfs/v4recovery as the NFSv4 state recovery directory
[ 21.758319] NFSD: Using legacy client tracking operations.
[ 21.763821] NFSD: starting 90-second grace period (net f0000039)
done
starting mountd: done
Starting system log daemon...0
Starting crond: OK
Starting tcf-agent: OK
Poky (Yocto Project Reference Distro) 3.1.6 cyclone5 ttyS0
ethtool:
root@cyclone5:~# ethtool eth0
Settings for eth0:
Supported ports: [ TP MII ]
Supported link modes: 10baseT/Half 10baseT/Full
100baseT/Half 100baseT/Full
1000baseT/Half 1000baseT/Full
Supported pause frame use: Symmetric
Supports auto-negotiation: Yes
Supported FEC modes: Not reported
Advertised link modes: 10baseT/Half 10baseT/Full
Advertised pause frame use: Symmetric
Advertised auto-negotiation: Yes
Advertised FEC modes: Not reported
Speed: Unknown!
Duplex: Unknown! (255)
Port: MII
PHYAD: 31
Transceiver: internal
Auto-negotiation: on
Supports Wake-on: d
Wake-on: d
Current message level: 0x0000003f (63)
drv probe link timer ifdown ifup
Link detected: no
ifconfig:
root@cyclone5:~# ifconfig
eth0: flags=4099<UP,BROADCAST,MULTICAST> mtu 1500 metric 1
inet 192.168.3.55 netmask 255.255.255.0 broadcast 0.0.0.0
ether e2:63:72:57:5d:ee txqueuelen 1000 (Ethernet)
RX packets 0 bytes 0 (0.0 B)
RX errors 0 dropped 0 overruns 0 frame 0
TX packets 0 bytes 0 (0.0 B)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
device interrupt 34 base 0x2000
lo: flags=73<UP,LOOPBACK,RUNNING> mtu 65536 metric 1
inet 127.0.0.1 netmask 255.0.0.0
inet6 ::1 prefixlen 128 scopeid 0x10<host>
loop txqueuelen 1000 (Local Loopback)
RX packets 2 bytes 140 (140.0 B)
TX packets 2 bytes 140 (140.0 B)
Replies (16)
RE: Ethernet on MitySoM - Added by Daniel Vincelette about 4 years ago
Hi Jonas,
From looking at your boot log it looks like the kernel incorrectly found a PHY at address 31, where it should of found it at address 3. This could be caused by the kernel or u-boot not taking the PHY out of reset.
In our reference design we have the kernel take the phy out of reset with the following device tree node (socfpga_mitysom5csx_devkit.dts):
&gmac1 { status = "okay"; phy-mode = "rgmii"; txd0-skew-ps = <0>; txd1-skew-ps = <0>; txd2-skew-ps = <0>; txd3-skew-ps = <0>; rxd0-skew-ps = <420>; rxd1-skew-ps = <420>; rxd2-skew-ps = <420>; rxd3-skew-ps = <420>; txen-skew-ps = <0>; txc-skew-ps = <1860>; rxdv-skew-ps = <420>; rxc-skew-ps = <1680>; max-frame-size = <3800>; snps,reset-delays-us = <0 10000 1000000>; snps,reset-gpio = <&porta 28 1>; snps,reset-active-low; };
The snps,reset-gpio element is telling the kernel which reset to use. Please note that our reference uses the 4.9 kernel, where you are using the 5.8 kernel so the syntax might have changed.
Dan
RE: Ethernet on MitySoM - Added by Jonas Mair about 4 years ago
Hey Dan,
thanks for the reply.
I created my dts with the sopc2dts tool, but appended the information given in your example, which currently does not seem to help.
Before that i already got it running roughly by calling ethtool -s eth0 speed 10 duplex full autoneg off, basically forcing the interface to use the lowest possible speed. Due to this working (but also intermittingly failing), I am suspecting
the clock skews are either configured wrong or not configured at all (i tried to read out the clock skews of the mmd registers in the micrelksz9031 chip, and they do not seem correct, but it's hard to tell).
You also mentioned an unexpected PHY address, what could be the reason for that, how could i check that? Could that be related to a wrong configuration of the clock skews?
Here is my (modified) device tree node:
hps_0_gmac1: ethernet@0xff702000 {
compatible = "synopsrstmgrys,dwmac-20.1", "altr,socfpga-stmmac", "snps,dwmac-3.70a", "snps,dwmac";
reg = <0xff702000 0x00002000>;
interrupt-parent = <&hps_0_arm_gic_0>;
interrupts = <0 120 4>;
clocks = <&emac1_clk>;
clock-names = "stmmaceth"; /* embeddedsw.dts.params.clock-names type STRING */
interrupt-names = "macirq"; /* embeddedsw.dts.params.interrupt-names type STRING */
rx-fifo-depth = <4096>; /* embeddedsw.dts.params.rx-fifo-depth type NUMBER */
snps,multicast-filter-bins = <256>; /* embeddedsw.dts.params.snps,multicast-filter-bins type NUMBER */
snps,perfect-filter-entries = <128>; /* embeddedsw.dts.params.snps,perfect-filter-entries type NUMBER */
status = "okay"; /* embeddedsw.dts.params.status type STRING */
tx-fifo-depth = <4096>; /* embeddedsw.dts.params.tx-fifo-depth type NUMBER */
address-bits = <48>;
max-frame-size = <3800>; /* appended from boardinfo */
local-mac-address = [08 15 ba de af fe];
phy-mode = "rgmii"; /* appended from boardinfo */
phy-addr = <0x1f>; /* appended from boardinfo */
txd0-skew-ps = <0>;
txd1-skew-ps = <0>;
txd2-skew-ps = <0>;
txd3-skew-ps = <0>;
txen-skew-ps = <0>;
altr,sysmgr-syscon = <&hps_0_sysmgr 0x00000060 2>; /* appended from boardinfo */
reset-names = "stmmaceth"; /* appended from boardinfo */
resets = <&hps_0_rstmgr 33>; /* appended from boardinfo */
reset-gpio = <&hps_0_gpio1_porta 28 1>;
reset-active-low;
}; //end ethernet@0xff702000 (hps_0_gmac1)
Thanks for the help!
Jonas
I apparently used the wrong gpio port, now the reset seems to be working correctly (ethtool shows a PHYAD of 3), but unfortunately i still can't get a higher speed than 10Mbs with sometimes high packet losses.
Jonas
Hi Jonas,
You might not have the phy driver built into your kernel, so the phy skews aren't being set. I believe the config is: CONFIG_MICREL_PHY.
Dan
Hey Dan,
I checked the kernel configuration in menuconfig and directly in the .config of my kernel and the config was enabled.
Also it seems like the device is detected properly and the correct driver is chosen:
[ 1.567200] Micrel KSZ9031 Gigabit PHY stmmac-0:03: attached PHY driver [Micrel KSZ9031 Gigabit PHY] (mii_bus:phy_addr=stmmac-0:03, irq=POLL)
and
Configuring network interfaces... [ 19.500625] socfpga-dwmac ff702000.ethernet eth0: PHY [stmmac-0:03] driver [Micrel KSZ9031 Gigabit PHY] (irq=POLL)
I still have the feeling it's something in the device tree, is there something special to configure in Quartus besides the Pin Configuration?
Jonas
Hi Jonas,
Looking at the device-tree binding doc for the phy it looks like if you specify the phy address you need to put the skews in their own phy node instead of in the MAC node. Take a look at the example here: https://support.criticallink.com/gitweb/?p=linux-socfpga.git;a=blob;f=Documentation/devicetree/bindings/net/micrel-ksz90x1.txt;h=a35558cf3af66b97de28fa61822fcd9021ea1177;hb=refs/heads/socfpga-4.9.78-ltsi
I looked in the 5.8 bindings doc for the phy and they removed the example of the autodetect phy, I'm not sure why.
I would recommend removing the phy-addr line from your dts, which should cause it to autodetect the phy and would match the example in the 4.9 bindings doc.
Dan
RE: Ethernet on MitySoM - Added by Jonas Mair almost 4 years ago
Hey Dan,
I tried the device tree configurations you mentioned and also the generic ones adapted to my hardware from
https://elixir.bootlin.com/linux/v5.8.18/source/Documentation/devicetree/bindings/net
(also your example is listed there under micrel), but to no avail.
I also tried removing the phy-addr line, which didn't change the behaviour for me. I also now tried to set the timing skews on bootup (in the boot script), but i am guessing in between there is another reset anyway. I also further confirmed, that the correct micrel driver is on the device and also used:
root@cyclone5:/sys/bus/mdio_bus/drivers/Micrel KSZ9031 Gigabit PHY# ls
bind stmmac-0:03 uevent unbind
I also compared my device to your device tree, which you posted in your first reply, also considering the other part of the emac in socfpga.dtsi (included down the line in your devicetree):
gmac1: ethernet@ff702000 {
compatible = "altr,socfpga-stmmac", "snps,dwmac-3.70a", "snps,dwmac";
altr,sysmgr-syscon = <&sysmgr 0x60 2>;
reg = <0xff702000 0x2000>;
mac-address = [00 00 00 00 00 00];/* Filled in by U-Boot */
clocks = <&emac_1_clk>;
resets = <&rst EMAC1_RESET>;
status = "disabled";
To me they also look pretty similar.
I also tried to check the clocks, at least how they are configured in quartus and that also seemed okay.
One thing, which I should've tried much earlier, is, running your provided image, which also doesn't seem to work besides the 10Mbps, which now leads me to think it's a hardware issue or an issue in the router.
I will update, if I find anything new. Thanks for the help!
Regards
Jonas
Okay an update:
Skews are set correctly, I read them out with [[ https://github.com/wkz/phytool ]] and could confirm the values set in the device tree after kernel boot.
I measured the clock GTX_CLK, supplied from the MAC to the PHY. It starts out at 125 MHz (which is configured in Quartus), but after "Configuring network interfaces" it falls back to 2.5MHz, which is not fit for more than 10Mbps.
The RX_CLK, which is generated by the KSZ9031 based on the GTX_CLK (with an internal PLL), produces an 125MHz Signal (or 25 or 2.5, depending on what I set it with ethtool).
So the current suspect is the GTX_CLK or whatever controls it, do you have any idea regarding that?
Regards
Jonas
RE: Ethernet on MitySoM - Added by Daniel Vincelette almost 4 years ago
Hi Jonas,
If you are also witnessing this issue with our stock SD card image then it sounds like there could be a hardware problem with dev kit. Could you provide me the serial number of both the SOM and baseboard?
The serial numbers are on white stickers that have QR codes on them. The serial number is the second line and should look something like 19039000.
The SOM serial number is on the back of the SOM.
The baseboard serial number should be on the top of the baseboard by the partial HSMC connector.
Thank you,
Dan
Sure,
Baseboard: 1701 8998
SoM: 1803 5616
It's an 5CSX-H6-42A-RC Module
Regards
Jonas
Hi Jonas,
Thank you for providing the serial numbers. I've double checked our production logs and that development kit did link up at 1Gbps speeds and was able to send and receive ethernet packets before shipping out.
Can you boot again using the reference SD card and post a console log of the following:- Boot up
- ethtool of eth0
- pinging a device on your network
Reference SD card image: https://support.criticallink.com/redmine/attachments/download/27161/sdcard_5csx_h6_42a_20201116.zip
Also just to double check have you tried connecting up another device instead of the dev kit using the same ethernet cable/end point and check if that device links up and works at 1Gbps? I'm guessing this was part of your debugging of your router but I just wanted to double check.
Regards,
Dan
Hi Dan,
my plan was to take the board home over the weekend to test out a different router, in the office i tested with 2 different cables and 2 different router plugs, which worked fine for 100Mbps at least (only confirmed it with a quick speed test).
Bootup:
U-Boot SPL 2013.01.01 (Nov 17 2020 - 00:43:58)
BOARD : Critical Link MitySOM-5CSx Module
CLOCK: EOSC1 clock 25000 KHz
CLOCK: EOSC2 clock 25000 KHz
CLOCK: F2S_SDR_REF clock 0 KHz
CLOCK: F2S_PER_REF clock 0 KHz
CLOCK: MPU clock 800 MHz
CLOCK: DDR clock 400 MHz
CLOCK: UART clock 100000 KHz
CLOCK: MMC clock 50000 KHz
CLOCK: QSPI clock 400000 KHz
RESET: COLD
SDRAM: Initializing MMR registers
SDRAM: Calibrating PHY
SEQ.C: Preparing to start memory calibration
SEQ.C: CALIBRATION PASSED
SDRAM: 1024 MiB
SDRAM: Initializing SDRAM ECC
SDRAM: ECC initialized successfully with 1554 ms
SDRAM: ECC Enabled
ALTERA DWMMC: 0
U-Boot 2013.01.01 (Nov 17 2020 - 00:44:13) Critical Link MitySOM-5CSx
CPU : Altera SOCFPGA Platform
I2C: ready
DRAM: 1 GiB
MMC: ALTERA DWMMC: 0
In: serial
Out: serial
Err: serial
Info - Didn't find block
Net: mii0
gpio: pin 0 (bank/mask = 0/0x00000001)
gpio: pin 0 (gpio 0) value is 1
4078608 bytes read in 223 ms (17.4 MiB/s)
21795 bytes read in 30 ms (709 KiB/s)
reading /dev_5cs.rbf
7007204 bytes read in 325 ms (20.6 MiB/s)
## Starting application at 0x3FF76598 ...
## Application terminated, rc = 0x0
## Flattened Device Tree blob at 00000100
Booting using the fdt blob at 0x00000100
Loading Device Tree to 03ff7000, end 03fff522 ... OK
Starting kernel ...
Linux version 4.9.78-ltsi-yocto-standard (oe-user@oe-host) (gcc version 7.3.0 (GCC) ) #1 SMP Mon Nov 16 22:09:17 UTC 2020
OF: fdt:Machine model: MitySOM-5CSX Altera SOCFPGA Cyclone V
percpu: Embedded 14 pages/cpu @bf7ca000 s26764 r8192 d22388 u57344
Built 1 zonelists in Zone order, mobility grouping on. Total pages: 260096
Kernel command line: console=ttyS0,115200 root=/dev/mmcblk0p3 rw rootwait
PID hash table entries: 4096 (order: 2, 16384 bytes)
Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
Memory: 1029524K/1048576K available (6144K kernel code, 445K rwdata, 1392K rodata, 1024K init, 153K bss, 19052K reserved, 0K cma-reserved, 0K highmem)
Virtual kernel memory layout:
vector : 0xffff0000 - 0xffff1000 ( 4 kB)
fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
vmalloc : 0xc0800000 - 0xff800000 (1008 MB)
lowmem : 0x80000000 - 0xc0000000 (1024 MB)
pkmap : 0x7fe00000 - 0x80000000 ( 2 MB)
modules : 0x7f000000 - 0x7fe00000 ( 14 MB)
.text : 0x80008000 - 0x80700000 (7136 kB)
.init : 0x80900000 - 0x80a00000 (1024 kB)
.data : 0x80a00000 - 0x80a6f76c ( 446 kB)
.bss : 0x80a6f76c - 0x80a95da4 ( 154 kB)
Build-time adjustment of leaf fanout to 32.
NR_IRQS:16 nr_irqs:16 16
L2C: DT/platform modifies aux control register: 0x02060000 -> 0x02460000
clocksource: timer1: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604467 ns
Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
ftrace: allocating 21441 entries in 63 pages
Setting up static identity map for 0x100000 - 0x100058
CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
Brought up 2 CPUs
SMP: Total of 2 processors activated (400.00 BogoMIPS).
futex hash table entries: 512 (order: 3, 32768 bytes)
pinctrl core: initialized pinctrl subsystem
vgaarb: loaded
EDAC MC: Ver: 3.0.0
fpga-region soc:base-fpga-region: FPGA Region probed
clocksource: Switched to clocksource timer1
TCP established hash table entries: 8192 (order: 3, 32768 bytes)
TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
UDP hash table entries: 512 (order: 2, 16384 bytes)
UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
dma-pl330 ffe01000.pdma: Loaded driver for PL330 DMAC-341330
dma-pl330 ffe01000.pdma: DBUFF-512x8bytes Num_Chans-8 Num_Peri-32 Num_Events-8
ffc02000.serial0: ttyS0 at MMIO 0xffc02000 (irq = 45, base_baud = 6250000) is a 16550A
brd: module loaded
at24 0-0050: 2048 byte 24c16 EEPROM, writable, 1 bytes/write
cadence-qspi ff705000.spi: n25q128a11 (16384 Kbytes)
6 ofpart partitions found on MTD device ff705000.spi.0
Creating 6 MTD partitions on "ff705000.spi.0":
0x000000000000-0x000000040000 : "Preloader Image 0-3"
0x000000040000-0x000000050000 : "U-Boot Env"
0x000000050000-0x000000060000 : "DTB"
0x000000060000-0x0000000e0000 : "U-Boot"
0x0000000e0000-0x0000008e0000 : "Kernel"
0x0000008e0000-0x000001000000 : "FPGA"
1 ofpart partitions found on MTD device ff705000.spi.1
Creating 1 MTD partitions on "ff705000.spi.1":
0x000000000000-0x000001000000 : "Data"
c_can_platform ffc00000.can: c_can_platform device registered (regs=c08eb000, irq=26)
c_can_platform ffc01000.can: c_can_platform device registered (regs=c08ed000, irq=30)
stmmac - user ID: 0x10, Synopsys ID: 0x37
Ring mode enabled
DMA HW capability register supported Enhanced/Alternate descriptors
Enabled extended descriptors
COE Type 2
Enable RX Mitigation via HW Watchdog Timer
eth%d: PHY ID 00221622 at 3 IRQ POLL (stmmac-0:03) active
dwc2 ffb40000.usb: EPs: 16, dedicated fifos, 8064 entries in SPRAM
dwc2 ffb40000.usb: DWC OTG Controller
dwc2 ffb40000.usb: new USB bus registered, assigned bus number 1
dwc2 ffb40000.usb: irq 47, io mem 0x00000000
usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
usb usb1: Product: DWC OTG Controller
usb usb1: Manufacturer: Linux 4.9.78-ltsi-yocto-standard dwc2_hsotg
usb usb1: SerialNumber: ffb40000.usb
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 1 port detected
rtc-abx80x 0-0069: model 1805, revision 2.3, lot e, wafer 11, uid 1ad0
rtc-abx80x 0-0069: rtc core: registered abx8xx as rtc0
lm73 0-004c: sensor 'lm73'
EDAC MC0: Giving out device to module altera_edac controller soc:sdramedac: DEV soc:sdramedac (INTERRUPT)
dw_mmc ff704000.dwmmc0: IDMAC supports 32-bit address mode.
dw_mmc ff704000.dwmmc0: Using internal DMA controller.
dw_mmc ff704000.dwmmc0: Version ID is 240a
dw_mmc ff704000.dwmmc0: DW MMC controller at irq 39,32 bit host data width,1024 deep fifo
mmc_host mmc0: Bus speed (slot 0) = 50000000Hz (slot req 400000Hz, actual 396825HZ div = 63)
dw_mmc ff704000.dwmmc0: 1 slots initialized
lp5562 0-0030: internal clock used
altera_hps2fpga_bridge ff400000.fpga_bridge: fpga bridge [lwhps2fpga] registered
altera_hps2fpga_bridge ff500000.fpga_bridge: fpga bridge [hps2fpga] registered
oprofile: no performance counters
oprofile: using timer interrupt.
can: controller area network core (rev 20120528 abi 9)
can: raw protocol (rev 20120528)
can: broadcast manager protocol (rev 20161123 t)
can: netlink gateway (rev 20130117) max_hops=1
input: gpio_keys as /devices/platform/gpio_keys/input/input0
ttyS0 - failed to request DMA
Waiting for root device /dev/mmcblk0p3...
mmc_host mmc0: Bus speed (slot 0) = 50000000Hz (slot req 50000000Hz, actual 50000000HZ div = 0)
mmc0: new high speed SDHC card at address aaaa
mmcblk0: p1 p2 p3
EXT4-fs (mmcblk0p3): mounting ext3 file system using the ext4 subsystem
EXT4-fs (mmcblk0p3): mounted filesystem with ordered data mode. Opts: (null)
VFS: Mounted root (ext3 filesystem) on device 179:3.
devtmpfs: mounted
INIT: version 2.88 booting
Starting udev
udevd[82]: starting version 3.2.2
udevd[83]: starting eudev-3.2.2
EXT4-fs (mmcblk0p3): re-mounted. Opts: (null)
Configuring network interfaces... socfpga-dwmac ff702000.ethernet eth0: IEEE 1588-2008 Advanced Timestamp supported
udhcpc (v1.24.1) started
Sending discover...
Sending discover...
Sending discover...
No lease, forking to background
done.
Starting system message bus: dbus.
Starting OpenBSD Secure Shell server: sshd
generating ssh RSA key...
generating ssh ECDSA key...
generating ssh DSA key...
generating ssh ED25519 key...
random: crng init done
IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
done.
Starting atd: OK
exportfs: can't open /etc/exports for reading
NFS daemon support not enabled in kernel
loading RTC calibration values from /etc/abrtc.cal ...
Starting kernel log daemon...0
Starting crond: OK
Starting Network Interface Plugging Daemon: eth0.
Poky (Yocto Project Reference Distro) 2.4.4 mitysom-c5 /dev/ttyS0
mitysom-c5 login: root
Ethtool and ping:
root@mitysom-c5:~# ethtool eth0
Settings for eth0:
Supported pause frame use: Symmetric Receive-only
Advertised pause frame use: No
Speed: 10Mb/s
Duplex: Half
Port: MII
PHYAD: 3
Transceiver: external
Supports Wake-on: d
Wake-on: d
Link detected: no
root@mitysom-c5:~# ping 192.168.3.1
connect: Network is unreachable
Forcing it again on 10Mbps, will make it work. Forcing it on more than that, and it won't.
root@mitysom-c5:~# ethtool -s eth0 speed 10 duplex full autoneg off
root@mitysom-c5:~# socfpga-dwmac ff702000.ethernet eth0: Link is Up - 10Mbps/Full - flow control off
IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
ethtool -s eth0 speed 100 duplex full autoneg off
root@mitysom-c5:~# socfpga-dwmac ff702000.ethernet eth0: Link is Down
Regards
Jonas
I also tried it at home now (with your image) and I can reproduce the same behavior. So it points directly towards the hardware. Are there some hardware configurations, which might affect the behavior, e.g. the CSEL switches?
Regards
Jonas
Hi Jonas,
The CSEL switches shouldn't have an effect on the ethernet interface, they are more used during the early boot process.
It sounds to me like there is a hardware defect with the development kit. Someone will contact you via email on processing an RMA for that board.
Best regards,
Dan
Hey Dan,
I just received the new board and ethernet worked instantly without any problems!
Thanks again for the help.
Regards Jonas
Hi Jonas,
Awesome, I'm glad to hear it!
Best regards,
Dan
