Moving Forward with U-Boot and Quartus 22.1std
Added by Shahad Alrawi about 1 year ago
We are currently using 5CSX-H6-42A-RC with our own base board.
I have recently upgraded Quartus 18.1 to the more recent version Quartus Prime 22.1std. Additionally I made changes to the Platform designer in the HPS system.
So in order to be able to move forward with the latest Quartus version, I want to follow the workflow specified here:
https://www.rocketboards.org/foswiki/Documentation/BuildingBootloaderCycloneVAndArria10
The new workflow (latest one):
The instructions in the RocketBoards website is very well written. I was able to successfully compile it but with different device tree source (socfpga_cyclone5_socdk.dts). Now I need to modify it to be compatible with 5CSX-H6-42A-RC and my base board configuration. Since the board BSP is not included in this U-Boot, this had blocked me from compiling it.
I would like to ask if you provide a reference to start with for 5CSX-H6-42A-RC and any other hints to help us configuring the U-Boot especially for a one that is newer than in the wiki page (socfpga_v2020.04).
Looking forward for your help.
Replies (6)
RE: Moving Forward with U-Boot and Quartus 22.1std - Added by Daniel Vincelette about 1 year ago
We do have a reference for building using the newer flow for the preloader/bootloader but it's for the socfpga_v2019.10 branch and Quartus 20.1, which can be found here: https://support.criticallink.com/redmine/projects/mityarm-5cs/wiki/Building_U-Boot_and_Pre-loader_2019. We have not brought our reference up to Quartus 22.1 or socfpga_v2020.04. A good starting place would be to cherry-pick the top 4 commits from our 2019.10 branch and apply them to Intel's2020.04 branch.
Our 2019.10 u-boot branch: https://support.criticallink.com/gitweb/?p=u-boot-socfpga.git;a=shortlog;h=refs/heads/socfpga_v2019.10
Commits that we applied to intel's 2019.10 branch:
Best regards,
Dan
RE: Moving Forward with U-Boot and Quartus 22.1std - Added by Shahad Alrawi about 1 year ago
Hello Dan,
Thank you so much!
I tried to compile the criticalLink repo of U-Boot (socfpga_v2019.10) as in the instruction: https://support.criticallink.com/redmine/projects/mityarm-5cs/wiki/Building_U-Boot_and_Pre-loader_2019
I compiled my FPGA with Quartus 22.1std and not with 20.1.
However, I used the SoC EDS tool 19.1 .
Do you know if this is due to Quartus version 22.1std (FPGA compilation only) or something is broken with the repo?
I've seen this error in the linux kernel, it's due to using a newer version of GCC (I think GCC 10 was were this broke). I beleive this patch should resolve the issue: https://github.com/altera-opensource/u-boot-socfpga/commit/018921ee79d3f30893614b3b2b63b588d8544f73
Dan
Great thanks Dan,
Worked with this warning!
===================== WARNING ======================
This board does not use CONFIG_WDT (DM watchdog support).
Please update the board to use CONFIG_WDT before the
v2019.10 release.
Failure to update by the deadline may result in board removal.
See doc/driver-model/MIGRATION.txt for more info.
Is that ignorable?
Best,
Shahad
Yes, I would say that's ignorable. We don't plan on removing the driver from our 2019.10 branch. Though I'm not sure if it's still in any of the newer u-boot branches that Intel is hosting.
Dan
