VJeMMC and bus width 8
Added by V J over 2 years ago
Hi
Has anyone managed to interface an eMMC using 8 bit?
According to Cyclone V HPS "MMC Support matrix": https://www.intel.com/content/www/us/en/docs/programmable/683126/21-2/mmc-support-matrix.html 8 bit bus and 50MHz clock is supported, i.e. 50Mbytes/s.
I have updated the HPS with 8 bit for the SD/MMC controller and generated a new preloader and bootloader.
In the dts file I have changed from 4 to 8 bit:
&mmc {
status = "okay";
num-slots = <1>;
broken-cd;
cap-mmc-highspeed;
cap-sd-highspeed;
vmmc-supply = <®ulator_3_3v>;
vwmmc-supply= <®ulator_3_3v>;
bus-width = <8>;
The kernel starts but hangs after a few secs with "mmcblk0: error -115 sending stop command, original cmd response 0x900, card status 0xe00"
... ... [ 2.621256] Synopsys Designware Multimedia Card Interface Driver [ 2.627673] dw_mmc ff704000.dwmmc0: IDMAC supports 32-bit address mode. [ 2.634385] dw_mmc ff704000.dwmmc0: Using internal DMA controller. [ 2.640553] dw_mmc ff704000.dwmmc0: Version ID is 240a [ 2.645835] dw_mmc ff704000.dwmmc0: DW MMC controller at irq 40,32 bit host data width,1024 deep fifo [ 2.678808] mmc_host mmc0: Bus speed (slot 0) = 50000000Hz (slot req 400000Hz, actual 396825HZ div = 63) [ 2.708825] mmc0: mmc_rescan_try_freq: trying to init card at 400000 Hz [ 2.715508] dw_mmc ff704000.dwmmc0: 1 slots initialized ... ... [ 2.887583] Waiting for root device /dev/mmcblk0p2... [ 2.893099] mmc_host mmc0: Bus speed (slot 0) = 50000000Hz (slot req 52000000Hz, actual 50000000HZ div = 0) [ 2.903395] mmc0: new high speed MMC card at address 0001 [ 2.909521] mmcblk0: mmc0:0001 VM020 3.58 GiB [ 2.914200] mmcblk0boot0: mmc0:0001 VM020 partition 1 4.00 MiB [ 2.920256] mmcblk0boot1: mmc0:0001 VM020 partition 2 4.00 MiB [ 2.927269] mmcblk0: p2 p4 [ 3.034702] mmcblk0: error -115 sending stop command, original cmd response 0x900, card status 0xe00
Any suggestions on how to get the 8 bit interface up and running?
We are using the Rocko branch with kernel 4.9 RT.
BR
VJ
DV RE: eMMC and bus width 8 - Added by Daniel Vincelette over 2 years ago
We haven't tried interfacing to a 8 bit eMMC with the 5CSx SOM. Just to double check did you rebuild your preloader and u-boot when you made the 4 bit to 8 bit change in platform designer? Also are you able to boot to Linux if you use this eMMC in 4 bit mode?
Best regards,
Dan
VJ RE: eMMC and bus width 8 - Added by V J over 2 years ago
Hi Dan
Yes, the preloader and uboot has been rebuild after changing the interface in platform designer. If I change to 4 bit in the dts file everything works fine.
We are using Quartus 17.1.
BR
VJ
Now it is working, there was something wrong with the pinning.
Steps:
1. Update Platform designer.
2. Update IO pinning for the four extra bits and compile the new FPGA code.
3. Rebuild preloader and bootloader.
4. Update device tree.
cat /sys/kernel/debug/mmc0/ios clock: 52000000 Hz vdd: 21 (3.3 ~ 3.4 V) bus mode: 2 (push-pull) chip select: 0 (don't care) power mode: 2 (on) bus width: 3 (8 bits) timing spec: 1 (mmc high-speed) signal voltage: 0 (3.30 V) driver type: 0 (driver type B)
BR
VJ
