Unable to access Linux
Added by Anonymous almost 11 years ago
I am having trouble accessing the Linux system on the SD card, when the MityARM is connected to the PC, meaning that I can't access on putty. However, when it's not connected to the PC via the programmer board (Altera MMK), I can access the Linux system . I need to have the FPGA and my Linux program both to run.
Please help!
Jack
RE: Unable to access Linux - Added by Michael Williamson almost 11 years ago
Hi Jack,
We haven't trying using an Altera MMK, we instead us the USB Blaster or the USB Blaster II directly. Is it possible that the Altera MMK is holding the reset pin active?
You can load the FPGA via an Raw Binary File without the JTAG hooked up, but of course you will lose the ability to use Signal Tap.....
