MitySOM-5CSX-H6-42A files generation issues
Added by Dario Russo over 6 years ago
I recently bought a MitySOM-5CSX-H6-42A development kit and I have some problems to generate the files needed. First, I checked the configuration pin, that are set as described in the guide (0x05). I started by simply recompiling the example project and try to re-generate all the files (preloader, uboot, ubootenv, rbf) and write them in the SD card given with the kit (the dtb should be the same of the one stored in the SD card). I carefully followed the instruction in the Wiki links, checking the SDRAM_SCRUBBING and the PRELOADER_TGZ in the bsp-editor, downloading the “uboot-socfpga.tar.gz” for the uboot compilation and updating the single files to the SD card as described in https://support.criticallink.com/redmine/projects/mityarm-5cs/wiki/Building_SD_Card_Image. Unfortunately, linux doesn’t start and stuck on “starting kernel”. What am I doing wrong?
And when I modify the qsys, how can I generate the dtb? I don’t have the board xml file.
Thank you in advance.
Dario
RE: MitySOM-5CSX-H6-42A files generation issues - Added by Alexander Block over 6 years ago
Dario,
It sounds like you may need to modify some of your environment variables to properly boot from the new Kernel/device tree images you have created.
Can you please provide a complete boot log including the output of your environment variables?
We'll review those and provide further followup.
Alex
RE: MitySOM-5CSX-H6-42A files generation issues - Added by Dario Russo over 6 years ago
Hi Alex,
attached you can find two files with the boot log and the environment variables.
Dario
| boot-log.txt (2.08 KB) boot-log.txt | |||
| env-var.txt (2.5 KB) env-var.txt |
