HWAM62A: Getting the Splash Screen to Appear Earlier
Added by Holden Wozniak 2 months ago
Good morning,
I am finding that the psplash screen comes up very late while the kernel is initializing to the point where it sometimes does not appear because it is started as the kernel boot is completed.
After running systemd-analyze I found that /dev/fb0 is created very late in the kernel initialization
root@mitysom-am62ax:~# systemd-analyze critical-chain psplash-start.service
The time when unit became active or started is printed after the "@" character.
The time the unit took to start is printed after the "+" character.
psplash-start.service +105ms
`-dev-fb0.device @5.487s
What I have tried doing so far is to build the display drivers into the kernel instead of modules but it does not appear to have much effect on the time the splash screen appears
root@mitysom-am62ax:~# zcat /proc/config.gz | grep -E "TIDSS|KMS_HELPER|PANEL_SIMPLE"
CONFIG_DRM_KMS_HELPER=y
CONFIG_DRM_PANEL_SIMPLE=y
CONFIG_DRM_TIDSS=y
root@mitysom-am62ax:~# dmesg | grep -E "tidss|drm|fb0"
[ 1.772009] systemd[1]: Expecting device /dev/fb0...
[ 1.886444] systemd[1]: Starting Load Kernel Module drm...
[ 2.017347] systemd[1]: modprobe@drm.service: Deactivated successfully.
[ 2.018395] systemd[1]: Finished Load Kernel Module drm.
[ 4.427148] [drm] Initialized tidss 1.0.0 20180215 for 30200000.dss on minor 0
[ 4.482835] tidss 30200000.dss: [drm] fb0: tidssdrmfb frame buffer device
I was wondering if anyone ever looked into this and had any insight on how to bring up the display quicker? I found U-boot SPL takes ~2-3 seconds to get through and U-boot takes another ~2 seconds eith the bootdelay set to -2 to skip the prompt altogether. With the delay in /dev/fb0 being created the splash screen does not show up for ~10 seconds. Some ti documentation I'm looking at now seems to suggest a framebuffer can be created before the kernel starts and then handed off make the display earlier sooner? https://software-dl.ti.com/processor-sdk-linux/esd/AM62X/latest/exports/docs/linux/Foundational_Components/U-Boot/UG-Splash-Screen.html
Holden
Replies (19)
JC RE: Getting the Splash Screen to Appear Earlier - Added by Jonathan Cormier 2 months ago
There was some change I think around TI's SDK 9, that greatly delayed the /dev/fb0 creation. I didn't dig into it at the time, but I agree its not ideal.
I do think that getting the u-boot splash screen support working would make the most sense. I integrated some of TI's changes when they started adding the feature but haven't tried testing it to see what parts I'm missing to get it fully supported. I'm probably only missing a few small changes.
If your looking into it, i'd be happy to review and integrate any fixes you find. If you'd like me to look into it, we just need to look into getting it on my schedule as I have a few urgent tasks i'm working on.
HW RE: Getting the Splash Screen to Appear Earlier - Added by Holden Wozniak 2 months ago
Sounds good. Getting an early image on the display is one of the last big things I need to do to get our device in a good state so I'll be looking at it a lot this week. My initial plan was to just try and get the framebuffer created by U-boot that the Linux kernel can use as soon as it's started but if it ends up not being too much more to get the splash screen started in U-boot then that would be even better.
I'll leave updates here once I get some things functional
Holden Wozniak wrote in RE: Getting the Splash Screen to Appear Earlier:
From my read of their doc and my own experience, usually getting u-boot to show the splash screen is the first step. Getting u-boot to gently pass that frame buffer to linux (so the screen doesn't flicker when linux takes over) is trickier and usually happens later, though they do document how to do it.
Sounds good
If you run into any roadblocks, let me know. We can schedule a working meeting if needed.
Just for some clarification, the documentation says to modify board/ti/am62ax/evm.c to change the SPL init function and enable video even in custom boards based on the am62ax SoC. Is all board configuration contained within the board/cl directory and a new evm.c should be created here or does it ever reference files in board/ti/am62ax?
When searching the build directory, the only "evm" files I see are from ti-linux-firmware which is part of the build dependencies.
I was able to create nodes in the u-boot device tree for my panel, pwm-backlight, and the video driver (dss).
In drivers/video/tidss/tidss_drv.c added the compatible line for the am62a7 so the tidss driver can bind properly
static const struct udevice_id tidss_drv_ids[] = {
{ .compatible = "ti,am625-dss" },
{ .compatible = "ti,am62a7-dss" },
In U-boot, the dm tree and dm uclass commands show those nodes with drivers bound to them but they do not probe (likely because I have not written any code to trigger them to yet) but
=> dm tree
Class Seq Probed Driver Name
root 0 [ + ] root_driver root_driver
rsa_mod_ex 0 [ ] mod_exp_sw |-- mod_exp_sw
simple_bus 0 [ + ] simple_bus |-- bus@f0000
simple_bus 1 [ ] simple_bus | |-- bus@4000000
video 0 [ ] tidss_drv | |-- dss@30200000
remoteproc 2 [ ] k3_dsp | `-- dsp@7e000000
regulator 12 [ + ] regulator_fixed |-- vdd_mmc1
regulator 13 [ + ] gpio regulator |-- som_vdd_sd_dv
regulator 14 [ ] regulator_fixed |-- wlan_en
clk 1 [ ] fixed_clock |-- clk-0
backlight 0 [ ] pwm_backlight |-- pwm-backlight
panel 0 [ ] simple_panel |-- panel
firmware 1 [ ] psci |-- psci
=> dm uclass panel
uclass 81: panel
0 panel @ fd5c9db0, seq 0
=> dm uclass backlight
uclass 82: backlight
0 pwm-backlight @ fd5c9cd0, seq 0
=> dm uclass video
uclass 130: video
0 dss@30200000 @ fd5c88c0, seq 0
Despite having drivers listed the devices are never probed so I am unable to test putting an image to the display with bmp (though I can load a bmp to the loadaddr and print out its info). Does the probing have to be done in u-boot code or do you know of any way to probe these kind of devices from the uboot command line?
Can you share the changes you've made so far as a patch/diff?
I am also attaching the Linux dts, I know the bindings are a little different for the u-boot drivers so I tried to match as closely as possible for the panel and backlight nodes
Note one thing I ran into is the ti-dss driver in 2025 u-boot, doesn't currently support switching to video port 1 (where the 62a connected the VOUT pins). There is a upstream patch to add this support so I'm testing if it can be backported.
https://github.com/u-boot/u-boot/commit/209c5d9da18375a6ea320786254803d28486e739
I have made some good progress on this today. I've got to do some cleanup but i'll try to push a test branch for you to test. Note i'm using our devkit with the hdmi output but I believe switching to your touchscreen should be straight forward.
Here are my changes so far, pushed to a test branch, please test it and let me know.
This loads a splash.bmp.gz from the boot partition of the sdcard and loads it during the A53 SPL. Note splash.bmp needs to be <1M uncompressed. There may be a config to increase this limit. I didn't bother enabling the bmp cmd or splash screen support during u-boot proper, but I did test to verify the SPL will handoff the framebuffer to u-boot proper when it is enabled.
I haven't tried to get the linux framebuffer handoff working yet, so a couple seconds into the linux boot, the framebuffer gets a bit scrambled before it draws its own splashscreen. But I wanted to give you at least some progress.
HW RE: AM62A: Getting the Splash Screen to Appear Earlier - Added by Holden Wozniak 2 months ago
The changes work great, got it working with our display no problem!
I see what you mean with the scrambled splashscreen, I was going to start following the documentation for handing the frame buffer off to Linux and see what happens with that
JC RE: AM62A: Getting the Splash Screen to Appear Earlier - Added by Jonathan Cormier 2 months ago
Okay good to hear.
JC RE: AM62A: Getting the Splash Screen to Appear Earlier - Added by Jonathan Cormier about 2 months ago
How is linux framebuffer hand off going?
HW RE: AM62A: Getting the Splash Screen to Appear Earlier - Added by Holden Wozniak about 2 months ago
The display after U-boot resets so the splash screen right now does not persist and the display does not come back on until just before the display manager starts.
The framebuffer handoff however seems to work. Adding the framebuffer node/memory region to the kernel and disabling DRM framebuffer emulation worked to get rid of the garbage right when the kernel starts. The contents of /dev/fb0 show the data of the splash screen as well.
This wasn't included in the documentation I originally linked, but there may need to be changes to the source code I have not looked into yet. TI sent this to me and said it should work for AM62A as well https://www.ti.com/lit/an/spradk8/spradk8.pdf
I wonder if the biggest piece were missing is the disabling CONFIG_DRM_FBDEV_EMULATION step they highlight.
I explicitly set CONFIG_DRM_FBDEV_EMULATION=n and that was what worked to get rid of the trash since the display does not reset until a little bit into the kernel starting. At this point it seems more an issue with the way the panel driver is brought up when the kernel starts which I'm looking into
JC RE: AM62A: Getting the Splash Screen to Appear Earlier - Added by Jonathan Cormier 24 days ago
AM62A splashscreen changes have been merged into https://support.criticallink.com/gitweb/?p=u-boot-ti.git;a=shortlog;h=refs/heads/mitysom-u-boot-2025.01
