CLKUSR - Oscillator Specs?
Added by Sean Youngblood 4 days ago
What is the frequency tolerance and stability (in PPM) of the 100 MHz oscillator used to drive the CLKUSR pin on the SOM? I cannot seem to find this information in the SOM datasheet.
For context, my design contains an elastic FIFO used to compensate for clock drift between a remote transmitter and receiver. The local CLKUSR oscillator drives the read-side of this FIFO, so without specs, I cannot calculate the required FIFO depth as I do not know what the maximum frequency deviation will be.
RE: CLKUSR - Oscillator Specs? - Added by Mike Fiorenza 4 days ago
Hi Sean,
The oscillator that is driving the CLKUSR pin is KC2520Z100.000C15XXK. Per the datasheet, this is a 30 ppm oscillator.
- Mike
RE: CLKUSR - Oscillator Specs? - Added by Sean Youngblood about 22 hours ago
Hi Mike,
Thanks for providing the oscillator part number, this is very helpful!
- Sean
