Module Product Change Notifications (PCN) and Errata¶
This page captures PCN's and known errata related to the MityDSP-L138F family of system on modules.
If a part / configuration option is not listed under the "Products Affected" section, then the item was not built/ordered prior to the listed change being issued by engineering.
After you create an account and login, you can use the Watch option to receive email notifications when this page changes. The Watch option will not appear until you login.
| Document Type | Document Link | Title | Release/Update Date |
| Errata | MityDSP-L138_Errata | MityDSP-L138, MitySOM-1808(F), MitySOM-1810(F) SOM Errata Sheet | 8/3/2022 |
| PCN | PCN20260923000 | U-Boot Bootloader Update and DHCP Command Fix | 9/23/2026 |
| PCN | PCN20250727000 | mDDR Synchronous DRAM Replacement | 9/9/2025 |
| PCN | PCN20230801000 | 128 Mbit NOR Flash | Initial: 8/14/2023 Revised: 8/29/2023 |
| PCN | PCN20220621000 | Remove SATA CLK Driver & JTAG Connector | 8/8/2022 |
| PCN | PCN20180209000 | Obsolete 8MB NOR Flash | 2/9/2018 |
| PCN | PCN20150626000 | Address OMAP-L138 Advisory 2.1.4 | 6/26/2015 |
| PCN | PCN20121031000 | Address OMAP-L138 Advisory 2.1.23 | 10/31/2012 |
| PCN | PCN20120612000 | RTC Power Current Reduction | 6/12/2012 |
| PCN | PCN20120524000 | SATA A/C decoupling added | 5/24/2012 |
| PCN | PCN20110711001 | Migration from 16-Bit to 8-Bit NAND | 6/11/2011 |
| PCN | PCN20110711000 | Improved CPU Reset | 6/11/2011 |
