Hello World¶
An SDK is provided for creating custom applications to run on the MitySOM-QC6490 Devkit.
Setup the SDK¶
- Download our SDK files here TODO LINK.
- Change into the downloaded directory and run the installer:
./qcom-wayland-x86_64-qcom-multimedia-image-armv8-2a-qcs6490-mitysom-devkit-toolchain-1.5-ver.1.1.sh
- You will be prompted to choose the install location. Choose your desired location or accept the default.
- Once the installation is complete, the toolchain environment setup script will be available for sourcing:
source {YOUR_INSTALL_DIRECTORY}/environment-setup-armv8-2a-qcom-linux
Note: This must be done each time you wish to use the SDK in a new shell session. - The toolchain is now ready to be used. You can verify the toolchain is setup by ensuring the CC environment variable has been set to the cross compiler:
echo ${CC}
should outputaarch64-qcom-linux-gcc -march=armv8.2-a+crypto -mbranch-protection=standard -fstack-protector-strong -O2 -D_FORTIFY_SOURCE=2 -Wformat -Wformat-security -Werror=format-security --sysroot=/usr/local/oecore-x86_64/sysroots/armv8-2a-qcom-linux
Create and compile a program¶
- Open your favorite text editor and create a file named "hello.c" with the following contents
#include <stdio.h> int main() { printf("Hello, World!\n"); return 0; }
- The toolchain can used directly with Makefile based projects. Lets create a Makefile to compile our hello.c program.
- In the same location as the hello.c file, download this Makefile with the following contents:
all: hello.o ${CC} hello.o -o hello hello.o: hello.c ${CC} -I . -c hello.c clean: rm -rf *.o rm hello
Note: The CC environment variable is the gcc cross compiler targeting the MitySOM-QC6490. For C++ projects, the CXX variable should be substituted in its place to use the g++ cross compiler. - Source the toolchain setup script if you have not already done so, and run the Makefile:
make all
- You should now have an executable named "hello" in the current directory.
Load and run a program¶
There are numerous methods for moving files onto the MitySOM-QC6940 Devkit file system. We will use adb for this example.
- Connect the host machine to the MitySOM-QC6490 Devkit using the onboard USB-C port. It must be connected at boot time in order for adb to work properly, so reboot if necessary.
- Move the "hello" executable created in the previous step to the MitySOM-QC6490:
adb push hello /root/hello
- In a terminal on the MitySOM-QC6490, run the program:
./hello
You should see the outputHello, World!
Additional Information¶
The provided SDK is a Yocto Standard SDK, not an Extensible SDK (eSDK).
https://docs.yoctoproject.org/sdk-manual/
