Wi-Fi¶
The Wi-Fi/Bluetooth expansion interface (J16) is designed to be directly compatible with the Silex SX-PCEAX-M2 Wi-Fi and Bluetooth expansion card. Linux drivers are available for the expansion card.
This interface can also be used for a user-designed interface card and features a 1-channel PCIe interface, a USB 2.0 interface and a +3.3V supply.
Development Board Configuration¶
Ensure that Switch S14 is set properly.- Switch 1 should be set to enable the 3V3 WIFI from the DC supply
- Switch 2 should NOT be set for Rev 1 or 2 of the Development Board as 3.3V from the SOM may actually be a higher volage. See MitySOM-QC6490 Development Kit Datasheet
Using the Silex SX-PCEAX-M2 to connect to a Wi-Fi network¶
- If you do not already have a Silex SX-PCEAX-M2 one can be obtained here
- Make sure the antennas are connected to the SX-PCEAX
- Insert the radio module into J16 and use an M2.5 screw to secure
- Boot the Dev Kit
- Verify the PCIe device is detected using lspci (note that devices connected to J16 (PCIE0) will appear on the PCI bridge at domain 0000, bus 80, slot 00)
root@qcs6490-mitysom-devkit:~# lspci 0000:80:00.0 PCI bridge: Qualcomm Technologies, Inc SM8250 PCIe Root Complex [Snapdragon 865/870 5G] 0000:81:00.0 Network controller: Qualcomm Technologies, Inc QCNFA765 Wireless Network Adapter (rev 01)
- Make a link for the firmware (note that this will be resolved in the Yocto build in a future release):
root@qcs6490-mitysom-devkit:~# mount -o remount, rw /usr && cd /usr/lib/firmware/ath11k/ && ln -sf WCN6855 QCA2066
- Reboot the MitySOM-QC6490 and ifconfig should show wlan0
wlan0 Link encap:Ethernet HWaddr 1C:BC:EC:01:8E:B2 inet addr:10.42.0.180 Bcast:10.42.0.255 Mask:255.255.255.0 inet6 addr: fe80::f4ed:6629:f17a:72b1/64 Scope:Link UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1 RX packets:44 errors:0 dropped:0 overruns:0 frame:0 TX packets:97 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:1000 RX bytes:5152 (5.0 KiB) TX bytes:10707 (10.4 KiB)
- Verify you can see available Wi-Fi networks
nmcli device wifi list
- Connect to your desired Wi-Fi network
root@qcs6490-mitysom-devkit:~# nmcli dev wifi connect "Your Desired SSID" password "insert-password-here" Device 'wlan0' successfully activated
- If you have an iperf server running on the Wi-Fi network you connected to you can run a bandwidth test:
root@qcs6490-mitysom-devkit:~# iperf3 -c 10.0.0.111 Connecting to host 10.0.0.111, port 5201 [ 5] local 10.2.0.91 port 60878 connected to 10.0.0.111 port 5201 [ ID] Interval Transfer Bitrate Retr Cwnd [ 5] 0.00-1.00 sec 11.9 MBytes 99.5 Mbits/sec 0 550 KBytes [ 5] 1.00-2.00 sec 12.5 MBytes 105 Mbits/sec 0 820 KBytes [ 5] 2.00-3.00 sec 10.0 MBytes 84.0 Mbits/sec 0 993 KBytes [ 5] 3.00-4.00 sec 11.2 MBytes 94.3 Mbits/sec 0 1.14 MBytes [ 5] 4.00-5.00 sec 11.9 MBytes 99.6 Mbits/sec 0 1.21 MBytes [ 5] 5.00-6.00 sec 9.88 MBytes 82.8 Mbits/sec 0 1.30 MBytes [ 5] 6.00-7.00 sec 10.2 MBytes 86.0 Mbits/sec 0 1.39 MBytes [ 5] 7.00-8.00 sec 8.75 MBytes 73.4 Mbits/sec 0 1.50 MBytes [ 5] 8.00-9.00 sec 9.00 MBytes 75.5 Mbits/sec 0 1.77 MBytes [ 5] 9.00-10.00 sec 11.9 MBytes 99.4 Mbits/sec 0 1.87 MBytes - - - - - - - - - - - - - - - - - - - - - - - - - [ ID] Interval Transfer Bitrate Retr [ 5] 0.00-10.00 sec 107 MBytes 89.9 Mbits/sec 0 sender [ 5] 0.00-10.06 sec 104 MBytes 86.8 Mbits/sec receiver iperf Done.
