FPGA example source
Added by Brian Rasmussen over 14 years ago
Hi
I am trying to get the EMIF interface up and running between the uC and the FPGA on a OMAP-L138F Profibus Dev kit board.
At first I would like to verify, I can program the FPGA from the uC using the board support package supplied fpga driver for linux. Somewhere in these pages I came across a sample FPGA file ready to download to a CPU platform connected to an "IndustrialIO" dev kit. Will this sample file fit my board too?
Next step will be to create my own FPGA image. In case I can use the file from above, is it then possible to get the Xilinx project for this file, or does it not implement the EMIF interface?
I have found "Hello world" examples for the uC and for the DSP but not for the FPGA. Is it possible also to provide a simple "Hello World" example project for the FPGA where the EMIF interface is included? I have tried to import the *.vhd files in the board support package into Xilinx ISE 12.1, but I was not able to create a working image... I will try again tomorrow, but any help, hints, guides etc. will be appreciated.
Thanks in advance.
Best regards
Brian
RE: FPGA example source - Added by Michael Williamson over 14 years ago
Hi Brian,
I can provide you with an example project if you are still stuck. Sorry for the delay. Please advise what you need.
RE: FPGA example source - Added by Brian Rasmussen over 14 years ago
Hi Mike,
thanks for your response. I would like a simple gpio example for the fpga using the fpga_gpio.ko driver from your board support package. If I am able to toggle an IO pin it would be enough for this test.
I have tried to download the IndustrialIO.bin file to the fpga and the download worked. It would be nice to verify the FPGA could run and communicate too...
Best regards,
Brian
    (1-2/2)
